+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Mar 2, 2016 at 9:26 PM
    #2901
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Thanks gents. Starting to wish i had heimed uppers..
  2. Mar 2, 2016 at 9:28 PM
    #2902
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I still run standard bushing uppers from Dirt King. Their original tubular ones. I beat my rig the hell up and have never really seen a justification for heimed uppers. I have never went out of camber caster alignment.
  3. Mar 2, 2016 at 9:30 PM
    #2903
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Just be easier not to fuck with cams is all. Although even normal bolts will still rust in the bushing.
  4. Mar 2, 2016 at 10:01 PM
    #2904
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Different strokes for different folks is all. It's good to have options regardless but I don't mind cams.
  5. Mar 2, 2016 at 10:29 PM
    #2905
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yea but then you'd have to invest in the tools for a self alignment.
  6. Mar 3, 2016 at 3:49 AM
    #2906
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Why? Just take it to a competent shop that knows how to adjust heims.
  7. Mar 3, 2016 at 7:42 AM
    #2907
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    DSM sell DK products as well, not all are items are listed on their website, give them a call or PM. Cheaper than direct from DK FWIW, $690 vs $750 for the heimed uppers.
    Sacrifice[QUOTED] likes this.
  8. Mar 3, 2016 at 7:45 AM
    #2908
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not exactly. I mean you literally have to remove the UCA bolt to adjust them. Which as you now know is a bit of a pain. It would take a few hours for a shop to do it. Be expensive as hell. If you could find a shop that would even do it for you.
  9. Mar 23, 2016 at 11:58 AM
    #2909
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Marc, got my uppers on order, should be here Friday, as well as the DK UCA gussets which DSM recommended over the TC ones due to fitment. Could you give me an approximate starting point for the heims, like # of threads showing on each of the four? I still plan to do the solid mounts on the lowers with the rear all the way out and the the front halfway between center and full in. Thanks!
  10. Mar 23, 2016 at 12:23 PM
    #2910
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Honestly I'd start with what dk sends them at. It will be the same as a normal uca. Reason I say that is my two arms are adjusted quite different from each other from side to side. So odds are my settings won't get you closer than what dk sends them with
    @Wishbone Runner
  11. Mar 23, 2016 at 4:31 PM
    #2911
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Ok, cool, just wondering if you made an adjustment right out of the gate. I'll start with how they come.
  12. Mar 23, 2016 at 6:55 PM
    #2912
    SconnieHailer
    Marc
    Nope I ran em how they came for a while until I got my solid mount on.
  13. Mar 29, 2016 at 10:05 PM
    #2913
    SconnieHailer
    Marc
    Sort of build related. Picked up this scooter from SLC last week with @BossFoss
    Looking forward to scouting new trail with the bike and keeping some harder miles off the truck. The bike needs some tlc but nothing i cant handle i dont think. I'll post pics of the upcoming fork rebuild (seals leaking bad), be interesting to compare to truck shocks :p
    [​IMG]1 by Marc Mayer, on Flickr
  14. Mar 29, 2016 at 10:17 PM
    #2914
    Blackdawg
    Monte
    Wyoming/St. Louis
    Booooooooooo
    :p
  15. Mar 29, 2016 at 10:24 PM
    #2915
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Marc, can you feel that weight back there? What does it do to the balance of the truck?
  16. Mar 29, 2016 at 10:45 PM
    #2916
    SconnieHailer
    Marc
    haterz gonna hate. What, like i should have got stuff for my truck instead?
    yea the ride is a bit more plush haha. Not bad though, might get fun with two back there :D my homebrew rack did great from SLC to Lander! My welding skills had me worried but i'm feeling better after this test.
    Digiratus[QUOTED] likes this.
  17. Mar 29, 2016 at 11:06 PM
    #2917
    Blackdawg
    Monte
    Wyoming/St. Louis
    Obviously...
  18. Mar 30, 2016 at 6:11 AM
    #2918
    Sacrifice
    KS
    DCSB OR 4X4 LT
    And so it begins :stirthepot:
  19. Mar 30, 2016 at 6:15 AM
    #2919
    Large
    Large Red
    weird question .. does your steering feel different than OEM when you swapped lowers?
    I swapped to LSK lowers and the steering wheel doesn't pop back in to place when i release it; if I am making a turn the steering wheel will straighten out somewhat but nothing like it was with the OEM lowers.
  20. Mar 30, 2016 at 6:20 AM
    #2920
    SconnieHailer
    Marc
    That sounds like an alignment issue. Mine doesn't do that. Or something is binding somewhere.
