+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Nov 14, 2017 at 8:29 PM
    #3221
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    If it's worth anything I'm going back to 285 for my next set :thumbsup:
  2. Nov 14, 2017 at 8:29 PM
    #3222
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    A little more backspacing than you think. +12 mm of offset on a 7.5" wide wheel means 4.75" of backspacing. So if your wheels are +10 , then ~4.65" of BS.
    https://www.tacomaworld.com/threads/wheel-backspacing-and-offset-info.102992/page-30#post-8653022
    I don't know enough 2nd gen anatomy to say for sure but that much BS with a 295 mm wide tire would cause interfere at the stock UCA on a 1st gen.
    Pardon the intrusion. :oops:
  3. Nov 14, 2017 at 8:33 PM
    #3223
    SconnieHailer
    Marc
    That's another good point Mike. You're likely to get some UCA contact on full lock on the tire turned in. Mine does and I'm at about 4° caster. Gets worse as you add caster
    Edit: if you have aftermarket arms, especially box style
  4. Nov 14, 2017 at 9:16 PM
    #3224
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    booooo
  5. Nov 14, 2017 at 9:20 PM
    #3225
    SconnieHailer
    Marc
    Just works better for going fast and street driving which I do 95% of the time.
    But 295 is more fun to look at :p
    Italia234 likes this.
  6. Nov 14, 2017 at 9:30 PM
    #3226
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
    Hmmm good point I didn't think about that. I wish I could just test fit the tires before I bought them:-(
    I am running a total chaos upper makes a little more room over stock but I too am at 3.8 caster.
  7. Nov 14, 2017 at 11:29 PM
    #3227
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Even if you did test fit the tires, they might look like they clear when turned lock to lock at ride height. But they might rub the shit out of your stuff as soon as you pull into a driveway or small incline/hill. My 315's clear my UCA's at ride height with those TRD wheels but rub alot if it's turned and on a small incline. You might also rub the frame with those wheels and 295's. My 315's rub my frame with those wheels a little at full lock, and that is with a .75" wheel spacer.
  8. Nov 15, 2017 at 6:08 AM
    #3228
    Italia234
    Nick
    Tucson
    TRD offroad
    Thanks sounds like it might be too much of a hassle trying to run 295s on the trd wheels. Btw I love your truck I have followed it for a while. Do you have an IG page?
  9. Nov 15, 2017 at 7:41 AM
    #3229
    deeezy
    Dana
    Hawaii
    Thanks man, my IG page is hilodana. Might not be too bad with the 295's. You might just have to trim where it rubs and do a good cab mount chop and hammer the pinch weld flat.
