+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Aug 26, 2013 at 6:34 AM
    #401
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    King 2.5 reservoir non extended travel with 700 lb coils. Id love to hook ya up but i cant spend the 6k it would take to jump to lt right now...
  2. Aug 26, 2013 at 6:46 AM
    #402
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Do you have a shot of your cv angles in there current state? Reason being i think i need to bring my front down
    Heres my preload on the left...the one on the right is how it was for a year, it was soooo stiff
  3. Aug 26, 2013 at 7:37 AM
    #403
    SconnieHailer
    Marc
    those are 700's right? I have 1 thread of preload showing at the moment. I'm gonna bump the drivers side up a bit to level it out but nothing more than 4 threads showing. I'll take a picture when I get the truck back from getting the third member leak fixed.
  4. Aug 26, 2013 at 7:49 AM
    #404
    PLC721
    Patrick
    Chandler, Az
    The dealer is fixing it?
  5. Aug 26, 2013 at 7:53 AM
    #405
    SconnieHailer
    Marc
    Yea that is where it is right now. I dropped it off on Sat since I was near there and it was still leaking after i retorqued the 3rd mem nuts and found 2 loose... i'm still well under warranty and the guys at my dealer are all wheelers like me so I dont think they are going to hold anything against me knowing I use it like a truck.
  6. Aug 26, 2013 at 7:53 AM
    #406
    PLC721
    Patrick
    Chandler, Az
    Yeah I went and checked all of mine. I didn't "torque" them but they were tight
  7. Aug 26, 2013 at 8:23 AM
    #407
    SconnieHailer
    Marc
    good deal. Yea it was leaking near the E-locker area at the housing to 3rd member join.
  8. Aug 27, 2013 at 9:42 PM
    #408
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Did you get your truck fixed?
  9. Aug 28, 2013 at 6:19 AM
    #409
    SconnieHailer
    Marc
    Nope. Toyota said due to physical damage it's not covered... so i said i'll just pick it up today and reseal the third myself. Pissed. Should have some fun pics of the axles pulled and the third out later tonight. Sucks cuz i could be doing gears!
  10. Aug 28, 2013 at 6:29 AM
    #410
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just be careful when pulling the axles out. The seal is a spring seal, and can be messed up pretty easily.
  11. Aug 28, 2013 at 7:21 AM
    #411
    SconnieHailer
    Marc
    Yea, so I've seen and heard. I was going to have jackstands to rest them on when I get them pulled and be extra careful pulling them. Any tips tor? Thanks for the heads up.
  12. Aug 28, 2013 at 7:32 AM
    #412
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Vacuum caps for the brake lines...and they don't need to come out to far, so you shouldn't have to remove the e-brake line or remove the drum.
  13. Aug 28, 2013 at 7:58 AM
    #413
    SconnieHailer
    Marc
    Good tip on the vacuum tips ;) I used them when doing my extended lines and it helped a lot with the mess... From every thing i've seen it looks like 4 inches aught to do it? Yes drum is going to stay on.
    Should I use the toyota FIPG or Permatex gasket maker for diffs?
  14. Aug 28, 2013 at 8:04 AM
    #414
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    the Toyota FIPG is the best stuff i have used. Love it.
  15. Aug 28, 2013 at 8:08 AM
    #415
    BradyT88
    BradyT88 Well-Known Member
    I used Toyota FIPG and it is holding great. I also wasn't careful when I pulled my axles... But they've been fine after each being pulled twice now.
  16. Aug 28, 2013 at 10:40 AM
    #416
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Man that sucks! I don't think the dealership where I live would do that. But I'm also buddies with the owner. I bet I know which rock you were stuck on that caused it though! :D I guess next time you can remove all of the scraps before you take it down there.
  17. Aug 28, 2013 at 11:12 AM
    #417
    SconnieHailer
    Marc
    haha, yea Mike has a picture of it after I rolled over it. I'm heading to the dealer soon so we'll see if I can make them change their mind...
  18. Aug 28, 2013 at 8:24 PM
    #418
    SconnieHailer
    Marc
    no excitement tonight. Talked to the tech about a few things before I brought er home. It wasn't leaking as bad when I picked it up. Also had to order parts since they didn't have the studs in stock and i might need one or two. So friday night/sat morning i'll get it re-sealed with new studs to be safe. I was dressed up from an interview and the lead tech looked at me like i was a total tard for doing it myself lol! Jokes on him, they wanted over 700 to fix it... HA!
  19. Aug 28, 2013 at 8:52 PM
    #419
    Blackdawg
    Monte
    Wyoming/St. Louis
    700?! Jesus what a rip off
  20. Aug 28, 2013 at 9:01 PM
    #420
    SconnieHailer
    Marc
    Yea, I literally said "are you joking" The tech claimed 7 hours for the job. I'll time it this weekend in my garage, and I wont even hurry...
