+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Oct 29, 2013 at 8:15 PM
    #661
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  2. Oct 29, 2013 at 8:22 PM
    #662
    BradyT88
    BradyT88 Well-Known Member
    Were you a little stuck here or were you able to just back out?
  3. Oct 29, 2013 at 8:59 PM
    #663
    SconnieHailer
    Marc
    just backed out. only almost got stuck in 2wd in a wet spot.
  4. Oct 30, 2013 at 5:30 AM
    #664
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Oh sh!t. Got a little slidewayz!
  5. Oct 30, 2013 at 7:43 AM
    #665
    SconnieHailer
    Marc
    haha, just barely... tough with gear and tent onboard!
  6. Oct 30, 2013 at 7:54 AM
    #666
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    FUCK YEA!!! that's a good video!
    love the shock relocation man :thumbsup:
    i kinda like the clear coat on the upper mount too..goes good with the kings
    if i were to do a relocation, i'd be going this route for sure..but between the mount, shocks and bumps that's a pretty penny :eek:
  7. Oct 30, 2013 at 7:58 AM
    #667
    BradyT88
    Nah, just add more throttle;) haha
  8. Oct 30, 2013 at 8:03 AM
    #668
    SconnieHailer
    Marc
    Thanks Bob!
    It'd be even better if I hadn't forgotten to change my camera to hd!
    Don't forget about install... Yea, its not a quick and easy/cheap solution but damn is it awesome compared to stockish setup. It feels bottomless when romping down a good trail.
  9. Oct 30, 2013 at 8:04 AM
    #669
    SconnieHailer
    Marc
    lolz, was on the floor! I even bobbed it half corner to get the rear end to rotate a bit! Neeeed SUPCRCHARGER!!!
  10. Oct 30, 2013 at 8:04 AM
    #670
    BradyT88
    :woot: I like the sound of that! Bottomless:D
  11. Oct 30, 2013 at 8:06 AM
    #671
    BradyT88
    And/or gears ;)
  12. Oct 30, 2013 at 8:07 AM
    #672
    SconnieHailer
    Marc
    Touche
    Also, getting used to the clicking of the bumps.... Just have to think "racetruck parts make racetruck noises"...
  13. Oct 30, 2013 at 8:14 AM
    #673
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    This definitely takes some getting used to. Just think tho, when you add secondary bypasses up front to handle all that weight you will already be used to the clicking and it wont bother you at all.
  14. Oct 30, 2013 at 8:19 AM
    #674
    SconnieHailer
    Marc
    haha, "when"... By the way Tyler, this is a pic of ride height before we started chopping at CBI...
  15. Oct 30, 2013 at 8:23 AM
    #675
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I suppose the leaf pack looks a bit flat, considering its unloaded. Is there a spring shop anywhere around you? you might be able to put a little arch back in them. Mine have a bit more arch at static load than yours do unloaded. Yours may have just gone a bit flat, right pedal will do that to em sometimes
  16. Oct 30, 2013 at 8:24 AM
    #676
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Another thing, damn, CBI does some nice work. Kinda peeped around a bit at their stuff when I saw your install pictures.
  17. Oct 30, 2013 at 8:26 AM
    #677
    SconnieHailer
    Marc
    That picture is ride height with the weight I carry around all the time. near 400# with tent, rack, parts and tool tote in the bed. Closest shop i know of is alcan in grand junction CO. There might be one closer though.
  18. Oct 30, 2013 at 8:27 AM
    #678
    SconnieHailer
    Marc
    Yea, great shop and guys!
  19. Oct 30, 2013 at 8:38 AM
    #679
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Hmm, if thats loaded then they do look pretty close to correct considering the load you carry. You might call AllPro and talk to Kurtis a bit and see if they have seen any inconsistencies. They get their springs from Betts and they are a pretty good spring shop. Its odd that the shackle wont fall forward, that typically happens when the spring runs out of travel, which yours are doing so almost doesnt seem like a spring issue. Its hard to diagnose without being there, its almost like there is something hanging up or a driveline bind not allowing the axle to move slightly forward.
    Edit: If a spring pack does not droop out far enough the eye to eye length could cause the shackle to not fall forward as well. The more it droops the closer the eyes come together allowing the collapse forward
  20. Oct 30, 2013 at 8:47 AM
    #680
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    ORV that drifts?!?! Yeah....that just happened. :D
    Racetruck gears & Racetruck S/C = Monster ORV. ^_^
