+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. May 29, 2014 at 4:09 PM
    #1341
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. May 29, 2014 at 4:28 PM
    #1342
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    :spy: lets see some carnage.
  3. May 30, 2014 at 8:11 PM
    #1343
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    My Taco is gonna grow up to be yours!!!:D:D
  4. May 31, 2014 at 1:53 PM
    #1344
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Still in Moab. Gonna have lots of pics to dump tomorrow night :) truck is a champ and mtrs are great on the rock out here!
  5. Jun 1, 2014 at 10:38 PM
    #1345
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  6. Jun 1, 2014 at 10:39 PM
    #1346
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    How do you think aluminum skids would work in Moab? Like an aluminum flat belly set up
  7. Jun 1, 2014 at 10:46 PM
    #1347
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    not..great..but, depends on the trails your run really.
    you'll need like 1/4 or 3/8 aluminum to compete with 3/16s steel. Might as well just go steel for belly pans really.
  8. Jun 1, 2014 at 11:05 PM
    #1348
    Digiratus
    Roaming the PNW
    The RedHead
    :rolleyes:
  9. Jun 2, 2014 at 5:26 AM
    #1349
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    x2..when nature calls ummm NATURE CALLS :D
  10. Jun 2, 2014 at 5:50 AM
    #1350
    SconnieHailer
    Marc
    Ha! I knew that would show up in here... Errr I'm just adjusting my door actuators :D pics soon! And no to aluminum for me you'll see why when I get pics up.
    Got a few edited before work!
    A hit like this on aluminum im pretty sure would have cracked it depending on the type of aluminum. DOnt think i'll be taking the front skid off cuz it is likely not going back on haha.
    [​IMG]1-1 by sconniehailer, on Flickr
    The door damage...
    [​IMG]2-1 by sconniehailer, on Flickr
    These guys were in camp
    [​IMG]3-1 by sconniehailer, on Flickr
    [​IMG]4-1 by sconniehailer, on Flickr
    I believe we went backwards on minor threat when we took a wrong turn on strike ravine. This was the area the door got kissed and was an hour after rolling into bfe...
    [​IMG]5-1 by sconniehailer, on Flickr
    following Joe around in the Rexus!
    [​IMG]6-1 by sconniehailer, on Flickr
    [​IMG]7-1 by sconniehailer, on Flickr
    [​IMG]8-1 by sconniehailer, on Flickr
    [​IMG]9-1 by sconniehailer, on Flickr
    [​IMG]10-1 by sconniehailer, on Flickr
    [​IMG]11-1 by sconniehailer, on Flickr
    Where Joe got tippy and we brought a winch down from camp haha.
    [​IMG]12-1 by sconniehailer, on Flickr
    Helldorado in the background
    [​IMG]13-1 by sconniehailer, on Flickr
    More to come tonight
  11. Jun 2, 2014 at 9:01 AM
    #1351
    PLC721
    Patrick
    Chandler, Az
    Well I have flat belly 1/4" steel skids that weigh a ton and going LT front I want to save weight and was looking to make an aluminum flat belly set up
  12. Jun 2, 2014 at 9:08 AM
    #1352
    SconnieHailer
    Marc
    You'll just have to be careful where you push it with Al skids.
  13. Jun 2, 2014 at 9:11 AM
    #1353
    PLC721
    Patrick
    Chandler, Az
    Btw awesome pics as usual!
  14. Jun 2, 2014 at 9:13 AM
    #1354
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Awesome shots Marc. The damage doesn't look that bad in the pics. Hows the wife liking it? haha.
    Looks like a good time. Wish I would have/could have made it. Maybe next year...I would still prefer a small group though.
  15. Jun 2, 2014 at 9:14 AM
    #1355
    Large
    Large Red
    That's exactly what I did, except I crimped mine with lugs and siliconed them up to make them waterproof.
  16. Jun 2, 2014 at 9:28 AM
    #1356
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Awesome shots.
    Your door is one of the main reasons I am selling my taco. My wife would calve if I did that to my truck.
  17. Jun 2, 2014 at 11:58 AM
    #1357
    SconnieHailer
    Marc
    My wife goes "meh nice memory" lol she rocks. And why u selling ur truck!?
  18. Jun 2, 2014 at 12:08 PM
    #1358
    skidooman
    TJ
    Northern Nevada
    19 Taco
    Eh, two part deal. Going to start a family, the dd is a 2 door civic with 145k on it. Great little car, but I want something better for her. And she doesnt like me wheeling the taco. I keep wanting to do moab, fordyce and rubicon, but I would need to build the taco more. So instead of doing that, I am going to buy an older pretaco or 4runner for that. And having 3 trucks doesnt make sense, so the taco is going away. It bums me out, but I hope to still be wheeling a Toyota, just something a little more vintage.
  19. Jun 2, 2014 at 12:32 PM
    #1359
    SconnieHailer
    Marc
    ahhh and that sounds like what i would do if I had to start over. Just get a dd and an older yota to build :D Have fun starting the family :D
  20. Jun 2, 2014 at 12:35 PM
    #1360
    BajaRunner
    BajaRunner Rock magnet
    Drew
    Chino Hills, CA
    12 4wd DC Tacoma TRD OR
    Looks like your skid did a good job of protecting everything behind it.
    P.S. I ordered the exact same bumper you have over the weekend.;)
