+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Jul 9, 2014 at 10:44 AM
    #1501
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    how often are you dudes getting your tires re-balanced? every 5000 with a rotation?
  2. Jul 9, 2014 at 10:46 AM
    #1502
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Only when i throw a weight. Or feel a shake. I rotate every 3k miles.
  3. Jul 9, 2014 at 10:54 AM
    #1503
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    gotcha...I was told to do every 3000 as well...I missed that memo :anonymous:
  4. Jul 9, 2014 at 11:31 AM
    #1504
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    3" ADS lift , Opened Exhaust, 33" Hankook, TRD Supercharger, URD Stealth 2.8" Pulley, URD CAI, UCON, DTLT, URD Y-Pipe, Demello Front Bumper, Total Chaos UCA, Satoshi Grill, Console Safe, Cobra 29 CB, Demello Sliders, DYI Rack, CVT Mt. Hood Tent, Rigid Industries LED in hood scoop, Bruteforce HC rear swingate bumper, Icom 5100A, Icom 7000, Alpine INE 920HD, Warn 8000m, 4x Inovations Skids, NItto 4.56 Gears, Diehard 31M Battery, Dual Battery Solar charge controller.
    Next time you balance if your running stock 2nd Gen wheels make sure they have the correct cones to balance them. Also instead of using weights have them put balancing beads inside the tire.
  5. Jul 9, 2014 at 11:34 AM
    #1505
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    I've heard of the beads...just never tried them. I know Mr. Grimm uses the beads as well. I went 20,000 on my MT/Rs without balancing (yes I should have known better) they were off pretty bad. Learned my lesson about getting a proper balance.
  6. Jul 9, 2014 at 11:38 AM
    #1506
    AR15xAR10
    I've never tried the beads but i keep hearing about them. I plan on getting new wheels next spring and i guess i'll have to try the beads
  7. Jul 9, 2014 at 11:43 AM
    #1507
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I've only rebalanced my tires once so far and that was after moab, all four tires were out almost an ounce... I did feel a vibe tho so i knew i needed to get them balanced. I'll just drive them until they feel that way again.
  8. Jul 9, 2014 at 11:48 AM
    #1508
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    Theororedicly with beads you shouldn't need to re-balance.
  9. Jul 9, 2014 at 11:49 AM
    #1509
    SconnieHailer
    Marc
    How are yours working out steve? How is it at low speed?
  10. Jul 9, 2014 at 11:51 AM
    #1510
    BradyT88
    BradyT88 Well-Known Member
    Hmmm... I should look into throwing beads in my front tires. They got hammered in Moab when my steering rack got jacked up and FUBAR'd my toe...
  11. Jul 9, 2014 at 11:52 AM
    #1511
    woodnick
    woodnick N7MQ
    Wyoming
    08 DCLB 4x4 Sport
    I've only had them on a month but so far so good.
  12. Jul 9, 2014 at 11:58 AM
    #1512
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Awesome photos! Looks like a great trip. I should stay out of here though, it makes me really miss my truck. :(
  13. Jul 9, 2014 at 9:17 PM
    #1513
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Marc, did your Kings come with tags that said right and left? I did not realize they would be side specific. In fact, I've never heard of that before. :confused:
  14. Jul 9, 2014 at 9:21 PM
    #1514
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Huh. Maybe for the taco lean?? :notsure:
  15. Jul 9, 2014 at 9:25 PM
    #1515
    Digiratus
    Roaming the PNW
    The RedHead
    It must be for something that isn't obvious. Valving?? But that doesn't make sense either. You've never heard of this before either?
    Visually they are identical. Same amount of pre-load and same overall length. :confused:
  16. Jul 9, 2014 at 9:26 PM
    #1516
    Blackdawg
    Monte
    Wyoming/St. Louis
    I have never heard of it. Quite odd..
  17. Jul 9, 2014 at 9:28 PM
    #1517
    Digiratus
    Roaming the PNW
    The RedHead
    They are beautiful tho. :p
  18. Jul 9, 2014 at 9:30 PM
    #1518
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Jul 9, 2014 at 9:31 PM
    #1519
    SconnieHailer
    Marc
    :drool: Mike!! So clean :D Mine did come with left and right since the reservoir elbows were turned to be side specific but since you dont have resis i'm not sure why they'd be side specific...
  20. Jul 9, 2014 at 9:39 PM
    #1520
    Digiratus
    Roaming the PNW
    The RedHead
    That is the only thing that makes sense. DSM put the coils om and of course the top bolt holes and the bottom bolt hole line up perfectly. Even the code on the coils and the nitro valve are positioned identically from side to side.
    Maybe that is all it is.
    I hope you don't mind me cluttering up your build thread with pics of my new COs, but I'm kind of excited about the whole deal. :eek:
