+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Jul 9, 2014 at 9:42 PM
    #1521
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I do t think he will...cause..:drool:
  2. Jul 9, 2014 at 9:50 PM
    #1522
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I thought Kings didn't come with the "no reservoir" option :confused:
  3. Jul 9, 2014 at 10:04 PM
    #1523
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  4. Jul 9, 2014 at 10:05 PM
    #1524
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh hell yea!
  5. Jul 9, 2014 at 10:20 PM
    #1525
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Might be a 1st gen, 2nd gen thing. I did not see one offered by DSM with a resi for 1st gens.
  6. Jul 12, 2014 at 1:36 PM
    #1526
    SconnieHailer
    Marc
    This may be a new concept for some but I thought this was worthy of posting.
    *Your tires move on your wheel*
    When aired down for some wheeling you will see some movement of the tire on your wheels. This is the movement I observed after the last weekend trip into shoshone and bombing around the lower wind river trails. I air down to about 15psi. This is why my next set will get beads instead of weights so i'll never have to worry about re-balancing because of this. I knew this existed because of my time at the track with my dads car, we never balanced his tires because they move so much, roughly a half inch every session on the track. Anyways, something to consider for your wheel and tire setup :cool:
    [​IMG]IMG_20140712_131631945_HDR by sconniehailer, on Flickr
  7. Jul 12, 2014 at 3:49 PM
    #1527
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Good to know...thanks... BTW...looking at your nice map...where does the H1 freeway (Hawaii 1) connect to Hwy 131...lmao! Google nav says I need to cross the ocean first:D
  8. Jul 12, 2014 at 7:28 PM
    #1528
    Digiratus
    Roaming the PNW
    The RedHead
    This sort of thing is also very inconsistent. Not all tire beads are created equal. Some fit much tighter that others and may not move at all in the same circumstances.
  9. Jul 12, 2014 at 8:38 PM
    #1529
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Yup gonna have to go to beads when i get new wheels :D
  10. Jul 12, 2014 at 10:43 PM
    #1530
    SconnieHailer
    Marc
    SNORKEL!
    Very true Mike! I suggest you all mark your wheel and tire like I did to see how your setup acts!
  11. Jul 13, 2014 at 7:21 PM
    #1531
    SconnieHailer
    Marc
  12. Jul 13, 2014 at 7:57 PM
    #1532
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    In a strange way...it's somewhat beautiful...:D
  13. Jul 13, 2014 at 8:07 PM
    #1533
    SconnieHailer
    Marc
    At least I know I'm getting use out of them! The most expensive investment I'm cool with destroying :D
  14. Jul 13, 2014 at 8:08 PM
    #1534
    AR15xAR10
    DAMN....hopefully threw some paint on there too :eek:
  15. Jul 13, 2014 at 8:59 PM
    #1535
    SconnieHailer
    Marc
    haha, no paint... :eek:
    Also did some investigating today. Drained my front diff to see about a vib i've had since moab and pulled the CV to check the ECGS bushing(used the big pry bar this time and the CV popped out really easy). All is well and I wiped down the seal well since it had been weeping and there was lots of dirt in it. I also discovered that my heims in the lower shock mount are toast... Tons of play and it's the noise i've been hearing on washboard thinnking it was my crappy steering column. Mike, seems i'm up for new heims too! I have about 30k on the king coilovers...
    [​IMG]IMG_20140713_173037025_HDR by sconniehailer, on Flickr
  16. Jul 13, 2014 at 9:06 PM
    #1536
    SconnieHailer
    Marc
  17. Jul 13, 2014 at 9:13 PM
    #1537
    Digiratus
    Roaming the PNW
    The RedHead
    Interesting. 30K seems a bit low, but maybe not. :notsure:
    I kno, it is a bit like apple to oragnes but a close inspection of my SAWs revealed the passenger heim was frozen which caused a deterioration of the inner race. That must have been the squeak I was hearing.
    I am curious what you actually found. Are they just very loose, lots/too much play?
    edit: just saw the video.
  18. Jul 13, 2014 at 9:29 PM
    #1538
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    When you get tired of scraping your Taco you might want to consider upgrading to an M-ATV:D It can handle scrapes and mines...so you're covered...lol
  19. Jul 13, 2014 at 9:44 PM
    #1539
    SconnieHailer
    Marc
    Those Oshkosh tank trucks are sweet!
    yea Mike, it's all up and down motion, pretty tight back and forth(front to back of truck motion) I do run it hard i guess. That's been my squeak of late as well...
  20. Jul 13, 2014 at 9:58 PM
    #1540
    Blackdawg
    Monte
    Wyoming/St. Louis
    im not THAT surpised :p haha
    i have seen you drive after you get out of the rocks :laugh:
    you go all...YES!! SMOOTH DIRT!!!
    BBBBBBBBBBBRRRRRRRRAAAAAAAAAAAPPPPPPPPPPP
    :D
