+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Sep 14, 2014 at 6:06 PM
    #1721
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    And Marcs truck will begin to break down monthly :p
  2. Sep 14, 2014 at 6:07 PM
    #1722
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Who cares, I walk/bike/board to work :goingcrazy:
  3. Sep 14, 2014 at 10:22 PM
    #1723
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Thanks Marc. Good stuff.
    Man that oil was dark.
  4. Sep 19, 2014 at 11:59 AM
    #1724
    SconnieHailer
    Marc
    More small important parts to get burned on. Also one more 3/8" spacer to add to the superbumps since i'm getting a smidge of coilbind when I stuff it hard going fast with the new lower control arms.
    Oil, shim stacks, and rebuild kits should be here tonight. Gonna have the re-builds ready for some fun tomorrow I think :D
    Also, if anyone knows of a good fab shop near riverton/lander i'd love to know about it. Was going to have Monte burn the cam tabs on for me but I cant wait till xmas to get it done since the derlin bushings just totally overpower the stock tabs...
    Oh, and a plug for wheelersOR. Great folks there. Plus they send you candy with your order :laugh:
    [​IMG]IMG_20140919_092511059_HDR by sconniehailer, on Flickr
  5. Sep 19, 2014 at 12:09 PM
    #1725
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My dad could probably do it too. He is at work ATM. But be back in 2 weeks I think. Maybe bit less.
    Long drive for that though
  6. Sep 19, 2014 at 12:17 PM
    #1726
    SconnieHailer
    Marc
    Yea, bit of a drive for some welding :eek: But I really need whoever does it to not do a shitty job... I know there is someone around me who could kill it with all the oil field welders around here but since i'd have to pull the arms for them to do it, it kind of limits possibilities.
  7. Sep 19, 2014 at 12:18 PM
    #1727
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea there are definitely people around you that could do it.
    No shops around though huh? You might try going to a oil field service company shop and just asking one of the welders if they could burn them in for you on a Saturday.
  8. Sep 19, 2014 at 12:26 PM
    #1728
    SconnieHailer
    Marc
    I've still got some looking to do.
  9. Sep 19, 2014 at 12:49 PM
    #1729
    BradyT88
    BradyT88 Well-Known Member
    :woot: I still need to get my cam tabs welded on. I've yet to bend a tab though.
  10. Sep 19, 2014 at 12:50 PM
    #1730
    Large
    Large Red
    Hard to believe.. I don't wheel nearly as hard or as often as you and I bent 3 on my 2012 ..
  11. Sep 19, 2014 at 12:54 PM
    #1731
    BradyT88
    Skinny 33's and non seized cams I guess:notsure: I'm surprised I haven't. I always check them after hard hits in both the rocks and the dunes.
  12. Sep 19, 2014 at 7:15 PM
    #1732
    SconnieHailer
    Marc
  13. Sep 19, 2014 at 7:23 PM
    #1733
    BradyT88
    I got my shims in yesterday and it amazes me that that little flutter even does anything! Haha
    Nice work on the shocks! Hope you like the new valving:woot:
  14. Sep 19, 2014 at 8:11 PM
    #1734
    SconnieHailer
    Marc
    haha yea that little guy makes a big difference! Valving is nutso. Also when you go to redo your rears let me know, theres a few small tricks to follow to get it setup right when re-installing. the resi valve piston can be a problem if you dont set it right...
  15. Sep 19, 2014 at 8:20 PM
    #1735
    Digiratus
    Roaming the PNW
    The RedHead
    I had no idea there were so many pieces inside of those shocks.
  16. Sep 19, 2014 at 9:04 PM
    #1736
    BradyT88
    Good to know. I'll hit ya up.
    As for the piston, Jason said to just bottom it out.
  17. Sep 19, 2014 at 9:24 PM
    #1737
    SconnieHailer
    Marc
    yup, bottom it out is right but the process to bottom it out has to be done right. Really it's just charging the resi to seat the resi piston at the bottom and then discharging it all so the resi can move when you push the sealhead down back into the shock.
  18. Sep 20, 2014 at 9:56 AM
    #1738
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    :popcorn:
    This is some good reading and a good looking truck. Nicely done!
  19. Sep 20, 2014 at 9:26 PM
    #1739
    SconnieHailer
    Marc
    Things that got done today:
    -Finished rebuild and revalve of coilovers
    -Got the coils back on using my own super sketch ratchet method
    -Added one more 3/8" spacer puck to the superbumps (had to use a new longer bolt)
    -Got a tapemeasure out and cycled the front end without shocks in (Measured 10.25" of travel at the hub with the UCA uniball being the limiting droop factor)
    -Made a giant mess of the garage in the process...
    [​IMG]IMG_20140920_131835218_HDR by sconniehailer, on Flickr
    [​IMG]IMG_20140920_132040679_HDR by sconniehailer, on Flickr
    These compress more when stuffed hard but this is all they would compress before lifting the truck.
    [​IMG]IMG_20140920_131959966_HDR by sconniehailer, on Flickr
    [​IMG]IMG_20140920_132137346_HDR by sconniehailer, on Flickr
    [​IMG]IMG_20140920_132208068_HDR by sconniehailer, on Flickr
  20. Sep 20, 2014 at 9:29 PM
    #1740
    BradyT88
    Somebody else finally did it and got a number over 9!:woot: And that's with 2 spacers on your bumps. I measured with no spacers. What's full droop at with the C/O in?
