+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Sep 22, 2014 at 9:04 PM
    #1761
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yes i believe king and fox are progressive...i know they are progressive valved...
  2. Sep 22, 2014 at 9:12 PM
    #1762
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah! it appears i was wrong.
    Quoted from Kings site:
    "A single rate spring is a single coil on the shock. As the coil compresses the rate increases at a linear rate. If the spring rate for that coil is 300lbs per inch then compressing that coil one inch generates 300lbs., two inches generates 600lbs., 3 inches equals 900lbs - See more at: http://www.kingshocks.com/category/king-products/springs/#sthash.ZqwIArtG.dpuf
    Okay so yea,
    All of them use a "linear" or progressive coil. So basically the more it compresses, the higher the spring rate goes.
    Icon does us digressive valving
    King/Fox/Saw use Progressive.
    Digressive valving means they are stiff at slow speeds, the faster you go, the softer they get.
    Progressive valving is the opposite, they are soft on the street or slower speeds, and the faster you go and hit shit, the softer they are.
    Different feeling to drive basically.
  3. Sep 30, 2014 at 8:33 PM
    #1763
    cgredler
    cgredler It was called thee 80s
    Cam
    Seattle, WA
    07 DCLB 4x4 like a boss
    3" lift Yakima Rack Floor Mats/Wind Defl. Cb Radio Bed Lights Tool Box
    First off let me say how I think your truck looks amazing. And that you also take some great pictures of it. I actually bought the Pelfreybilt Front Plate Bumper after looking at many pictures of your truck.
    Second off i have a few questions about your Uniden 520xl CB radio with 2' Firestik antenna and Relentless fab hood mount.
    1) How did you ground your antenna using that mount?
    2) Is the mount powder coated?
    3) How is the reception on the 2ft?
    3) And how did you mount your CB radio? (any pictures?)
    I have the same CB, and the 4ft firestik antenna is in the hood channel and i want to move it and use the Relentless fab bracket. and maybe a 3ft or 2ft antenna like you set up. Appreciate your time fellow TacomaWorld Member.
    Thanks again!
  4. Sep 30, 2014 at 8:42 PM
    #1764
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Hey Cam! Thanks :)
    1) I used the fire ring coax cable made by firestik:
    2) Nope just painted black with rustoleum flat black.
    3) The 2' is good for reception out to about 3 miles. It is a bit noisier than the 5' I have. But overall it is great and I love the short guy for getting into my garage and under everything and not looking outrageous with a crazy tall antenna.
    3 #2 :D ) Radio is mounted in the passenger footwell. Nothing fancy.
  5. Sep 30, 2014 at 10:28 PM
    #1765
    cgredler
    Cam
    Seattle, WA
    Awesome Marc! Thanks for all that, I do appreciate it.
    That's a good spot for the CB, i need to take mine out of the center console and utilize it again. I just installed a few weeks ago and its a great low budget/compact radio that does everything you need.
    Me and some of the guys on the NW meet forum went on a trip last weekend and i could hear them just great with a 4ft but it kept hitting the trees and was all over, i realized when im this close i dont need this huge one.
    Keep up the good work!
  6. Oct 1, 2014 at 7:01 AM
    #1766
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
  7. Oct 5, 2014 at 12:31 PM
    #1767
    SconnieHailer
    Marc
  8. Oct 5, 2014 at 2:38 PM
    #1768
    BradyT88
    BradyT88 Well-Known Member
    :woot: looks fun!
  9. Oct 5, 2014 at 3:45 PM
    #1769
    SconnieHailer
    Marc
    With all the packing Jen and I have been doing for our move next week it felt so good to get out and play a bit! Nothing extreme just fun whoops. About 4 in a row that have some good rythum.
  10. Oct 5, 2014 at 5:23 PM
    #1770
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bad ass!! I like it
  11. Oct 5, 2014 at 7:59 PM
    #1771
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Badass!!!:goingcrazy:
  12. Oct 5, 2014 at 8:02 PM
    #1772
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks like fun was had. :cool:
  13. Oct 15, 2014 at 8:34 PM
    #1773
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Well after a full day of reading all the pages in this thread, all i have to say is :thumbsup: looks great and just makes me want to dig into the suspension.
  14. Oct 15, 2014 at 9:05 PM
    #1774
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Man those shots are sweet! Your truck is dialed my friend :thumbsup:
  15. Oct 16, 2014 at 7:53 AM
    #1775
    SconnieHailer
    Marc
    Thanks Chris and Dave :) It's setup pretty nice for now :D
  16. Oct 16, 2014 at 8:33 AM
    #1776
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Come do mine now? Ha.
    Looks like you guys have a blast up there. Think im just stuck in the boring state with nowhere to wheel.
  17. Oct 16, 2014 at 8:55 AM
    #1777
    SconnieHailer
    Marc
    We sure try :D
    If you showed up at my place with a truck full of parts I'd help :D then we'd go wheel it while ur here!! KS isn't that far :p
  18. Oct 16, 2014 at 10:03 AM
    #1778
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea only..15 hours! If I remember right :anonymous:
  19. Oct 16, 2014 at 10:23 AM
    #1779
    SconnieHailer
    Marc
  20. Oct 16, 2014 at 10:37 AM
    #1780
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    How hard is doing the work (rebuilding etc) on your Kings?
