+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Jun 19, 2013 at 12:37 PM
    #161
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  2. Jun 19, 2013 at 12:39 PM
    #162
    SconnieHailer
    Marc
    I'll measure the same when it's back on the ground. Probably friday... Remember my 24.5 I got was with a bunch of weight in the bed.
  3. Jun 19, 2013 at 12:46 PM
    #163
    BradyT88
    BradyT88 Well-Known Member
    True. haha. I have probably 100ish lbs in my toolbox at all times, but it is at the front of the bed. My fuel tank is at about a 1/4 tank right now too. Which actually is probably why my numbers were about 1/2" higher than before. haha
  4. Jun 19, 2013 at 12:47 PM
    #164
    SconnieHailer
    Marc
    Too many variables to compare this kind of thing really.
  5. Jun 19, 2013 at 12:48 PM
    #165
    BradyT88
    There always is...
  6. Jun 19, 2013 at 12:49 PM
    #166
    SconnieHailer
    Marc
    how about we just park next to eachother at the wy meet :D
  7. Jun 19, 2013 at 12:50 PM
    #167
    BradyT88
    Sounds good! If I make it! and haven't swapped out my suspension by then. haha
    I imagine I am taller right now though just because I have 33's on. This has made me question getting expo's though... Although I have other plans at the moment.
  8. Jun 19, 2013 at 12:52 PM
    #168
    SconnieHailer
    Marc
    I see you considering SUA. Any payload concerns with SUA for u?
  9. Jun 19, 2013 at 1:08 PM
    #169
    BradyT88
    Looking for the 50T pack. It is supposed to be the All Pro expo leaf pack of the SUA setups. So I'm not too worried. I usually pack light anyway, although I am heavy from the get go... Guess we'll see what happens. I am more interested in that up travel though! It's my toy not a truck. haha
  10. Jun 19, 2013 at 1:50 PM
    #170
    SconnieHailer
    Marc
  11. Jun 19, 2013 at 2:06 PM
    #171
    BradyT88
    Hope so! haha Haven't brought it up to the wife yet though:ballchain: We'll see how that goes over... Haven't had much luck in the past...
  12. Jun 19, 2013 at 2:09 PM
    #172
    SconnieHailer
    Marc
    haha, good luck sir.
  13. Jun 19, 2013 at 2:12 PM
    #173
    BradyT88
    Thanks, if it wasn't for the fact that I would now have shocks coming through the bed she would never know I did it. haha
  14. Jun 19, 2013 at 2:13 PM
    #174
    SconnieHailer
    Marc
    hoops or bamf towers dont go thru right? Or are you wanting to run like a baller size shock!? 16's!!!!!!!!!!!!!!
  15. Jun 19, 2013 at 2:21 PM
    #175
    BradyT88
    Bamf and some shock hoops don't go through the bed.
    Going for 18's I believe. So yeah, going through the bed... haha
  16. Jun 19, 2013 at 3:02 PM
    #176
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Then she'll never notice the difference, since they install in the same place. ;)
    You can always say that you cuurent ones are worn out........shhhhh
  17. Jun 19, 2013 at 3:18 PM
    #177
    SconnieHailer
    Marc
    haha, bad ideas up in here. Always a good idea to have allowences you give yourselves every month, then neither party gets upset. childish though it may be, try it and tell me it didn't work...
  18. Jun 19, 2013 at 3:23 PM
    #178
    BradyT88
    My leafs are worn... and one of my rear shocks is leaking... haha That is what I am going to play on, plus a bunch of money I just made:D
    It would take me too long to save up $3K+ haha...
  19. Jun 20, 2013 at 10:28 AM
    #179
    SconnieHailer
    Marc
    Rear end about done, gotta trim the u-bolts and add the shocks getting here today. Superbumps bolted where they are will bump out my b110 5100's .2" before the shock bottoms out, Success!!! These 5/8th U-bolts are BEEF!
  20. Jun 20, 2013 at 1:01 PM
    #180
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Getting there!!!! Looking good Marc.
    Question though, how much will those superbumps compress?
