+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Oct 16, 2014 at 10:43 AM
    #1781
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Rears are easy but the coilovers aren't much fun because of the spring. Kind of depends on your previous mechanical knowledge. If you're going to try and tackle it, do all the research you can and watch some videos.
  2. Oct 16, 2014 at 10:46 AM
    #1782
    BradyT88
    BradyT88 Well-Known Member
  3. Oct 16, 2014 at 11:01 AM
    #1783
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I worked as a mechanic for 6 years and work on my dad's triaxle dump truck since I was old enough to be of any assistance! Plus, my uncle works on water pumps (big tow behind pickup size ones) and he already said he's sure he can do it. He rebuilt a cylinder on our backhoe last year. It seems fairly straight forward. But like you said, I can see the springs being a pain in the arse
  4. Oct 16, 2014 at 11:30 AM
    #1784
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Let me go find some credit cards....ha. i have to start saving thats for sure.
    Easy for you to say, you drive it every year. Furthest north ive been is brookings,sd
  5. Oct 16, 2014 at 12:12 PM
    #1785
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    I found King rebuild instructions which say.
    "Step 17: Set the Reservoir IFP
    Charge the reservoir with a small amount of pressure to push the internal floating piston to the bottom of the reservoir cylinder.
    Then, release the pressure from the reservoir so that it is empty."
    Is it harder than that?
  6. Oct 16, 2014 at 12:36 PM
    #1786
    BradyT88
    Nope.
  7. Oct 16, 2014 at 12:37 PM
    #1787
    NC15TRD
    Nick
    PA
    I think my only problem is where to get the shocks pressurized
  8. Oct 16, 2014 at 12:49 PM
    #1788
    BradyT88
    Yeah it helps to own your own bottle of nitrogen.
  9. Oct 16, 2014 at 12:53 PM
    #1789
    NC15TRD
    Nick
    PA
    That's where I'm gonna have to find the stuff
  10. Oct 16, 2014 at 4:29 PM
    #1790
    SconnieHailer
    Marc
    Yea Nick you'll be fine then. And setting the IFP is how you described Chris. Make sure you get all the bubbles out before you put the piston back in!!
    What do you do when you get an unexpected day off!? WHEEEEEEL!!!! Cyclone pass is looking good :D Had fun ripping up there and back today! Was about a 2.5 hour round trip.
    [​IMG]6 by sconniehailer, on Flickr
    [​IMG]7 by sconniehailer, on Flickr
    [​IMG]8 by sconniehailer, on Flickr
    [​IMG]9 by sconniehailer, on Flickr
    [​IMG]10 by sconniehailer, on Flickr
    [​IMG]11 by sconniehailer, on Flickr
  11. Oct 16, 2014 at 4:31 PM
    #1791
    BradyT88
    :jellydance: I haven't been rock crawling since Moab...
  12. Oct 16, 2014 at 6:42 PM
    #1792
    SconnieHailer
    Marc
    ooo that's rough dude! Least you've been to the dunes!
  13. Oct 16, 2014 at 6:47 PM
    #1793
    BradyT88
    Yep! 3 times now even! haha
  14. Oct 16, 2014 at 6:53 PM
    #1794
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Sounds good man! Great pics btw!
  15. Oct 24, 2014 at 9:09 PM
    #1795
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    great stuff here man, how hard was shock rebuild? I'm due for a rebuild and I need to put the extended travel spacer in myself haha
  16. Oct 24, 2014 at 9:32 PM
    #1796
    SconnieHailer
    Marc
    Do it! Like I've told others, as long as you research and take your time the only pain in the ass is getting the coils on and off... Extended is the way to go :cool: pm me if you've got questions.
  17. Oct 26, 2014 at 8:20 AM
    #1797
    NC15TRD
    Nick
    PA
    Picked up my 15 DCSB 6-speed sport the other day! Loving the transmission! It's definitely a truck though lol I'm going to switch the trans fluid to Redline MT90 at the first oil change and get a hurst shifter too. Should make everything really nice!
  18. Oct 27, 2014 at 5:54 AM
    #1798
    SconnieHailer
    Marc
    Nice! Mt90 is great in the 6 speed. And the Hurst is awesome :burnrubber:
  19. Oct 27, 2014 at 6:31 AM
    #1799
    NC15TRD
    Nick
    PA
    That's why I'm going with those choices! You and Matt's reviews of those products were enough to influence me!
  20. Nov 12, 2014 at 4:21 AM
    #1800
    NC15TRD
    Nick
    PA
    Hey Marc, when you were using the ratchet straps to remove your coils did you tie the straps together and skip using the hooks? I tried to do it last night but couldn't get the hooks between the coil and shock body. I need to crank up my driver's side before I get an alignment and don't have a spring compressor.
