+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Nov 12, 2014 at 5:32 AM
    #1801
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yep took the hooks off and tied the strap to the ratchet. So no hooks at all and passed the strap thru the coil between it and the shock then back out the bottom of the coil and into the ratchet.
    I don't really recommend this and I take no responsibility if you hurt yourself! Had to say it :)
  2. Nov 12, 2014 at 5:45 AM
    #1802
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I got it now! I'm not removing the springs, just wanting to compress them a bit so I can get a few turns on the driver's side. I won't put you at fault lol I did the floor jack method of changing 5100s back in the spring and I think that was more sketchy than this haha
  3. Nov 12, 2014 at 6:01 AM
    #1803
    SconnieHailer
    Marc
    Ahh yea that's right ur just adjusting. Have fun haha
  4. Nov 12, 2014 at 6:13 AM
    #1804
    NC15TRD
    Nick
    PA
    Yeah I'm thankful I've only got 600#ers right now!
  5. Nov 12, 2014 at 6:38 AM
    #1805
    SconnieHailer
    Marc
    Yea, should make it easier to ratchet em down enough to spin that collar easier. I'd use a minimum of two ratchets opposite eachother and alternate cranking them down every few clicks. Also don't overtighten that collar pinch screw! You don't want to strip the head on one...trust me.
  6. Nov 12, 2014 at 7:00 AM
    #1806
    NC15TRD
    Nick
    PA
    I saw in here earlier you recommend changing them out. May stop at the hardware store on the way home and grab a couple new ones
  7. Nov 12, 2014 at 7:05 AM
    #1807
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    you have a hurst? how tight are the shifts? does R need a slap to get it over?
    kayla is wanting to do something with her stock shifter to get rid of some of the play... i had the URD and now TRD short throw.. i would imagine the hurst is similar to the TRD as it's a full unit versus stock shaft with replacement links..
    edit: sick pics btw...i really need to make a trip up there to explore before any moves are made...
    and this.... http://www.tacomaworld.com/forum/moab/351265-2015-rock-therapy-official-thread.html :cool:
  8. Nov 12, 2014 at 7:17 AM
    #1808
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The hurst is tight. Super awesome. Almost clicks into gears. I like the hell out of it when I drive this beast.
  9. Nov 12, 2014 at 10:11 AM
    #1809
    SconnieHailer
    Marc
    Thread is 1/4 20 I believe.
    haha that first throw from first to second you made was funny. It really shifts short and solid.
  10. Nov 12, 2014 at 2:24 PM
    #1810
    Blackdawg
    Monte
    Wyoming/St. Louis
    Oh man..I was like.....uuuuuhhhhhhhhhooommmppohhhmpppp...awesome haha
    Was like..click! So damn short compared to mine haha
  11. Nov 30, 2014 at 4:50 PM
    #1811
    SconnieHailer
    Marc
  12. Nov 30, 2014 at 4:54 PM
    #1812
    SconnieHailer
    Marc
    K I lied.... Plans to solid mount my lower control arms and run a Dirt King hiemed upper control arm are in the works.
    I'll be using LSKs solid mount tabs in conjunction with the TC cam tab gussets, and running a Dirt King upper arm just like the sets they released recently for the 05+ taco but with hiems. Finally i'll be able to keep an alignment for more than a week, well more than a week if i didn't get offroad to romp on it.
  13. Nov 30, 2014 at 6:37 PM
    #1813
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    awesome pics as usual!
  14. Nov 30, 2014 at 6:45 PM
    #1814
    SconnieHailer
    Marc
    Thanks Luke, are you one of the east coast crew headed to Moab next year?
  15. Nov 30, 2014 at 7:07 PM
    #1815
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    How the kevlars holding up? How many miles?
  16. Nov 30, 2014 at 8:05 PM
    #1816
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    I wish :( May be a while before I can afford a trip to Moab
  17. Nov 30, 2014 at 8:54 PM
    #1817
    SconnieHailer
    Marc
    MTR-K's are holding up great. Almost 15k miles on them. About half or a little under half tread left. A trip to moab, a trip to WI and back to WY, a bunch of aired down trips into the mtns near me and lots of blasted two track. Overall amazing tire in temps above freezing. Although most dirt is fine when below freezing. The beef I have with the MTR-K is on any frozen or slick road surface. They are garbage on that stuff. Which is fine, it's an MT...I wasn't expecting much more. Get them siped and they'd probably be a stellar winter tire. Or just drive slow :p They do wear fast in hot asphalt applications though so limit the time you drive around on that stuff in mid summer heat!
    No worries! It'll be there still when you can make it :wink:
  18. Nov 30, 2014 at 9:10 PM
    #1818
    BajaRunner
    BajaRunner Rock magnet
    Drew
    Chino Hills, CA
    12 4wd DC Tacoma TRD OR
    Air down to about 20-25 PSI when on packed snow or icy packed snow. Allows for a wider foot print and allows the tread to move around for better traction. My MT/Rs have about a little over 1/4 inch of tread left. I was out driving in the heavy rain today and never had issues with losing traction. I will probably buy these tires again soon. I was considering the Dura Tracs, but I might have to stay with the MT/Rs. They've served me very well.
  19. Nov 30, 2014 at 9:34 PM
    #1819
    SconnieHailer
    Marc
    Hmm I'll try it Drew. I only left them at normal psi since I was driving 150 miles to my destination over a few mtn passes and saw both "dry" pavement and hardpack/ice. I was at 32psi for that trip when i felt like they were sketchy on those conditions. In the summer on road I leave them at 40 psi fyi for those reading with great tread wear.
  20. Nov 30, 2014 at 11:05 PM
    #1820
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Hmm... maybe I will have to rethink my next tire choice? Was thinking the MTRs or KM2s. Might just go to the new AT KO2s since we running out of places to wheel here anyway...
