+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Feb 4, 2015 at 8:47 AM
    #1881
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Haha, I was actually coming to you next as I saw you cut some. Did they not work out, go a different route . . .
  2. Feb 4, 2015 at 3:19 PM
    #1882
    BradyT88
    BradyT88 Well-Known Member
    My superbumps easily compress shorter than the stock ones statically. They are extremely soft.
    Not the best picture but this is statically compressed (the ORI's are empty) and they are compressed smaller than the metal spacer on the OEM's. I had to add a 3/8" spacer to them because my sub frame was hitting the ground on hard hits. As I'm sure you read from Marc, he had to add a 2nd 3/8" spacer because his C/O's were bumping before the superbumps with one spacer:eek:
  3. Feb 4, 2015 at 3:53 PM
    #1883
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i wanted more cushion...they were in the rear on a ~1-1/2" metal mount that didn't give much cushion past the bump...so i went with the timbren rear setup for all bump and minimal mount..
    i have a full set of wheelers at home as well, but i'll eventually put that on the fj i'm thinking
  4. Feb 4, 2015 at 8:53 PM
    #1884
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yes I am. I just want to skip the whole tacking my cams thing. I have not tried it and it probably works fine. I've been having to run the lower arm at lots of caster which puts it at a big angle in the frame mount and the derlin doesn't like that...it wants to be flush with the mount. So I'm just pulling out all the stops and going for a solid mount and using the upper for alignment.
    Superbumps stuff compress juuuuust fine haha. I can static compress them farther than stock probably when really loaded up. I have two 3/8" spacers on top of the one that DK sends with the lowers to compensate... I still can polish the top of the fender liners under a crawling stuff.
    This is what im talking about James. Thanks Brady :wink:
  5. Feb 5, 2015 at 9:00 AM
    #1885
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks guys, sound like a good option, I was worried about the height/contact point, but sounds like a non-issue.
  6. Feb 5, 2015 at 8:17 PM
    #1886
    SconnieHailer
    Marc
    Anxious to see how the DK lowers are for you. I'm a big fan of the superbumps. They take a bit of adjustment to work with your setup but once you use them correctly they're great!
  7. Feb 6, 2015 at 9:12 AM
    #1887
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    They were backordered, supposed to ship early next week, went through and laid a bead behind of the tabs for support, had to fully replace one, and then will tack them once I get an alignment.
    Sounds link you have already done the research, I may just go with what you have done, our setups will be near identical, I have #650 though, so should be getting less coil bind.
  8. Feb 6, 2015 at 1:22 PM
    #1888
    SconnieHailer
    Marc
    They will be worth the short wait :cool: The guys or guy or gal? at DK do great work, every dime in their weld stacks were beaut! Some of the best finished products i've got on my truck, next to pelfreybilt in quality of delivered product.
    Yea i've done a fair bit of research on the alignment bs. I just didnt want to mess with tacking cams thing it since I dont have a full shop with a welder...yet. Once I get the alignment dialed with the hiemed uppers I should be golden until i bend the frame :anonymous:
    The 700 lb coils suck for bind... They're the reason i have to run two spacers under my superbumps. They're robbing me of a bit of uptravel but my front end weight would not work with anything less than 700 lb coils :pout:
  9. Feb 23, 2015 at 12:57 PM
    #1889
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Marc, that pup is only young once. I want more puppy pics ASAP.
  10. Feb 25, 2015 at 4:11 PM
    #1890
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I know you aren't long travel,but ever seen these? Thoughts?
  11. Feb 25, 2015 at 5:06 PM
    #1891
    BradyT88
    They are basically the gold standard for CV axles. Around $1K per axle though... making them twice the price of OEM's from the stealership:eek:
    They claim to be stronger, but the few people I have read about running them seemed to break them about as easy as stock:notsure: They definitely have more articulation so if you are breaking axles from binding those should help that. But if you are breaking them because you are trying to turn 35's full throttle with a front locker I can't really guarantee they will be much better than OEM...
  12. Feb 25, 2015 at 5:13 PM
    #1892
    SconnieHailer
    Marc
    Soon! On the road werkn... He's growing like a weed!!
    Yep seen em. Lots of coin for axles when the OEM work great. I'm not locked up front and don't really think 33's put tons more stress on them like 35's might. I like the design and think they're a great option if you've got the dollaz. If you're gonna be doing some hard launching in 4wd you might need em :p
  13. Feb 25, 2015 at 5:15 PM
    #1893
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    $$$$ but i've heard great things
    downfall is it then puts the weak spot inside your diff
  14. Feb 25, 2015 at 5:17 PM
    #1894
    SconnieHailer
    Marc
    Yea very good point Bob. CVS are way easier to swap than a diff...
  15. Feb 25, 2015 at 5:19 PM
    #1895
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    yup...save coin, buy some CVJ remans and get good at swapping out axles if you plan to break many
  16. Feb 25, 2015 at 5:50 PM
    #1896
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you put an arb in the diff it helps strengthen the diff.
    I'd love some of those axles...sigh...
  17. Feb 25, 2015 at 5:54 PM
    #1897
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    yea who wouldn't love some stronger axles, but at $1k/ea it's a hefty investment for us normal guys
  18. Feb 25, 2015 at 6:00 PM
    #1898
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lifetime warranty though...
  19. Feb 25, 2015 at 7:01 PM
    #1899
    SconnieHailer
    Marc
    Here you go Gage, not sure if you get on flickr much but thats a sure bet to see ones I dont post here.
    Did the dog mod a week and a half ago :D Gonna be a great trail buddy and bird dog! I'll get some updated shots this weekend.
    [​IMG]1 by sconniehailer, on Flickr
    [​IMG]1-4 by sconniehailer, on Flickr
    [​IMG]4-4 by sconniehailer, on Flickr
  20. Feb 25, 2015 at 8:53 PM
    #1900
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    That is a good looking pup, dare I say cute without incurring too much teasing. Should be lots of fun for you.
