scoop to non scoop swap compatible
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tatortot46, Jan 17, 2012.
  1. Jan 17, 2012 at 3:20 AM
    tatortot46
    tatortot46 [OP] Well-Known Member
    Downingtown PA
    09 tacoma
    Hey guys, I have been reading alot of great posts. I am talking to another member about doing the swap and I want to make sure that A: silver is the same color across the board for most year and B: there is no size difference between years? I have an 09 silver and he has a 11 silver.
    Also is the 09 a specail year? I have seen a few areas wherer they make comment about 09 having different items?..
    Thank you all, sorry if someone has already posted this but i couldnt find it after alot of searching.
    -keith
  2. Jan 17, 2012 at 9:13 AM
    tatortot46
    Downingtown PA
    09 tacoma
    If anyone can get me in the right direction, such as another post that will answer or anyone who has done this themselves; I would be very happy.
  3. Jan 17, 2012 at 9:51 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Sizes should be the same. Don't know about color. '09 and up come standard with the Star Safety System, I beleive that is the only major change, and LED tail lights
  4. Jan 17, 2012 at 9:53 AM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    09+ had different features than previous years but nothing to do with the hood. The size will be the same from 2005-2011. They are also all 1E7 - Silver Streak Mica.
  5. Jan 17, 2012 at 11:03 AM
    tatortot46
    Downingtown PA
    09 tacoma
    Ok so now I need to check on paint colors. Does anyone no if there is a paint code forum between years?
  6. Jan 17, 2012 at 11:07 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i think i read that the silver Streak Mica. was ’05 to ’08 and that the silver on ’09+ are the same but a tad different from the ’05 to ’08 silver. so if you have a ’09 and he has ’11 silver should be the same.
    edit: i could be wrong and they could all be the exact same.
  7. Jan 17, 2012 at 9:44 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    As I stated above... They are all Silver Streak Mica (1E7) from 2005+.
