Scosche kit bounces!
Discussion in 'Audio & Video' started by blacksandtaco, Jun 6, 2009.
  1. Jun 6, 2009 at 3:47 PM
    blacksandtaco
    blacksandtaco [OP] Well-Known Member
    I checked up and down in the other dash kit threads and didn't see anything specific to this. For all you Scosche kit owners, please weigh in on this issue and let me know what you think.
    I have a DNX7140 installed and used the Scosche kit because I like the look much better than the Metra. Heres the problem, when I hit noticeable bumps in the road, the entire dash kit rattles up and down. Not the trim piece, the entire thing. I have everything mounted securely, I triple checked because I'm really anal about my installs. I noticed that there is maybe an 1/8 inch gap between the dash kit and the AC/Heater control panel and I know this gap didn't exsist with the factory radio. I'm wondering if it has anything to do with the plastic side brackets not being able to support the weight or if I might have just got a bad kit. Do you notice any play on your kits?
  2. Jun 6, 2009 at 4:43 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Not good news. I was looking at grabbing one of the Schosche kits for my DD. Besides the Metra, what other options do we have?
  3. Jun 6, 2009 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Can the Scosche peice be reinforced with Fiberglass to add strength? Shouldnt be to hard to do?
  4. Jun 6, 2009 at 5:09 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    i switched from a metra to a Scosche DD cause i liked the look and its been just fine. No squeaks or anything..
  5. Jun 6, 2009 at 5:17 PM
    jmasterj
    jmasterj Samsonite...I was way off!
    07 TRD Off Road
    I have a DNX5120 and it is fine. Did you put the orange clips in the scosche kit from the factory radio?
  6. Jun 6, 2009 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If someone covers shipping, sends me their unit, and gives a couple bucks, I'll fiberglass reinforce it for them. :)
  7. Jun 6, 2009 at 6:33 PM
    blacksandtaco
    I did use the orange clips. The head unit doesn't squeak, I just notice it moving up and down very slightly when hitting bumps. Its not hugely noticeable but bothersome nonetheless. I'm not sure if fiberglass would help. I'm going to take the AC panel off and observe a little more closely. I wonder if the open, plastic holes on the brackets, where you mount the kit to the toyota has something to do with it. Almost seems like those holes should be closed nand smaller in diameter. I might try to add rubber gromet rings or rubber washers to it somehow. I have both kits because I'm the type of person that needs to try all options before I can make my decision and I absolutely hate the black trim piece on the Metra kit. Has anyone with the Metra kit painted the black trim bezel to match the rest of the kit? Anyone know if there are any other options besides Metra or Scosche?
  8. Jun 6, 2009 at 10:40 PM
    sibanez
    sibanez Well-Known Member
    Camp Hill, PA & New Orleans, LA
    2002 4x4 SR5 XCab
    Leer camper Thule rack
    To be honest, the Metra kit isn't exactly sturdy either. I just did an install with a Pioneer BT7900 and the little plastic brackets that replace the sturdy metal ones that hold the HU assembly in the dash are a joke I actually ran some SecondSkin dampener on the back of the Metra kit in a few places to tighten up the gaps and hopefully absorb any vibrations. We'll see, but so far I'm not impressed with the kit. At least the color/texture is close.
  9. Jun 6, 2009 at 10:45 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Oh, both kits totally suck. They should make a metal one.
  10. Jun 6, 2009 at 10:47 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    i used the factory metal brackets with my scosche kit as i thought the plastic peices looked pretty flimsy. only problem i have is the little finishing piece wont fit around the HU but thats not b/c of the brackets
  11. Jun 7, 2009 at 7:51 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    I have an 08 with a single DIN Scosche kit and it works fine. Nice tight fit. No rattles or squeeks.
    Did you put on the factory mounting clips from the OEM radio? How about the 4 bolts behind the AC contorls? Did you put them back in?
  12. Jun 7, 2009 at 8:23 AM
    blacksandtaco
    Yeah I have all clips, screws, bolts etc in and tight. I used the metal brackets at first but couldn't get the trim piece on either and didn't like the open look around the face of the unit, so put the plastic ones back on.
  13. Jun 7, 2009 at 8:49 AM
    sibanez
    2002 4x4 SR5 XCab
    Yes, it is a single DIN Pioneer, but the install was in my 'new' 2005 Tacoma. The install would have definitely been better with a double din unit. I had a Metra kit in my 2002 Tacoma with a singl DIN stereo and it was a much better fit.
  14. Jun 11, 2009 at 8:23 PM
    blacksandtaco
    Sibanez - how's the secondskin working. Did that stiffen things up any?
  15. Jun 11, 2009 at 9:01 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    I have had two scosche dash kits(single D and DD) the pioneer head unit i put in first was in single Din and it was a nice and tight fit. Now that i have an Alpine DD screen, it makes it heavy enough to bounce on some larger bumps. I feel like a JACK-A$$ though cause i lost the orange/yellow tabs, and the Toyota parts dept. still has yet to call me on them coming in(2 months)
  16. Jun 11, 2009 at 9:08 PM
    blacksandtaco
    I have the clips in and it still bounces a bit. AAAAHHHHHH!:mad:
  17. Jun 12, 2009 at 3:50 AM
    Rocketball
    Scott
    Westminster, MD
    I think it's time to fiond a new parts department to deal with...... :cool:
  18. Jun 12, 2009 at 5:40 AM
    sibanez
    2002 4x4 SR5 XCab
    I'm working on a how-to for my complete audio review and will post more detail, but I am very happy with the SecondSkin so far. It's been easy to work with and I can definitely feel and hear the difference in the doors.
  19. Jun 12, 2009 at 6:14 AM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    metra kit looks way better!! it even has the stock texture.
  20. Jun 12, 2009 at 7:01 AM
    blacksandtaco
    Sibanez - how bout the secondskin behind the metra kit? Is it more stable now?
