Scott B.'s 2015 AC Build - Expo Style
Discussion in '2nd Gen. Builds (2005-2015)' started by Scott B., Mar 28, 2015.
  1. May 24, 2018 at 6:58 PM
    #201
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Thank you. I certainly do enjoy it.
  2. Jun 14, 2018 at 6:09 PM
    #202
    Scott B.
    Scott
    Georgia
    I have started metal working...
  3. Jun 14, 2018 at 10:18 PM
    #203
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Excited!!
  4. Jul 26, 2018 at 8:44 AM
    #204
    medic2230
    Murph
    Bama! Roll Tide
    In for metalwork!
    gixxerphil likes this.
  5. Aug 29, 2018 at 6:43 PM
    #205
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    How thick was your foam padding?
  6. Aug 30, 2018 at 6:02 AM
    #206
    Scott B.
    Scott
    Georgia
    IIRC, it was about 1/8". Thin, and fairly dense.
  7. Sep 10, 2018 at 6:38 AM
    #207
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Scott,
    What transmission fluid did you use? Assume Toyota since you are adding to existing. About how much for this procedure?
  8. Sep 17, 2018 at 11:52 AM
    #208
    Scott B.
    Scott
    Georgia
    I use Valvoline MaxLife DEX/MERC full synthetic ATF. It is Toyota WS compatible, so adding it to any existing fluid is OK.
    I have always done this myself, and have no idea what a shop would charge for the work.
  9. Sep 17, 2018 at 6:59 PM
    #209
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    $60 at AAMCO if I supply filter and seal. Going to use Tacoma specified fluids for this one. Want to change later and use Maxlife but need supervision to make sure I get it right.
  10. Sep 18, 2018 at 5:46 AM
    #210
    Scott B.
    Scott
    Georgia
    $60 doesn't sound too bad.
    Our trannys do not have a filter, rather a screen. Still a good idea to replace it occasionally.
  11. Sep 18, 2018 at 3:49 PM
    #211
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    No issues noted. No metal shavings in pan or screen and fluid looked fine. This after Moab and Colorado with trailer. Really expected no less. Will probably switch to the Valvoline on the next service. Watching all the going ons with Scotty. Regearing is eventually in the works so want to see how his next venture works out. I don't intend to be climbing rock walls but with all the armor and towing a trailer it is really getting heavy. How well did your regearing work out (that was quite a feat to take that on). I do not have the expertise to do what you did but maybe after Scotty redoes his we will have a group of people who have more than a general idea of what they are doing.
    stronghammer likes this.
  12. Sep 18, 2018 at 3:57 PM
    #212
    stronghammer
    stronghammer STTDB
    Scotty
    Huntsville, Alabama
    2011 MGM DCSB TRD Sport 4WD
    Hope so. Want to learn and work with all of our group. I like learning.
  13. Sep 19, 2018 at 6:38 AM
    #213
    Scott B.
    Scott
    Georgia
    It worked out fine.
    I did the front and rear independently, due to work traveling. I pulled the rear, sent it to ECGS, and went out of town. Upon returning, I installed the re-geared third member. I did all the work by myself.
    For the front, I swapped units. I ordered one from ECGS, and spent a Saturday pulling the original one out, and installing the re-geared unit. Again, I did all the work by myself. An extra set of hands (just for a couple of minutes) would have made installation quicker.
  14. Sep 20, 2018 at 12:05 PM
    #214
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    2014 DCSB TRD Off Road
    A little a this, a little a that...
    How do you like the 4.56s? I have the same wheel/tire and engine/tranny set up as you. I don’t feel like I NEED the extra gearing, but it sure would be nice. Curious about your experience in daily driving and off roading.
  15. Sep 20, 2018 at 12:46 PM
    #215
    Scott B.
    Scott
    Georgia
    I like them. My truck is heavier than stock, with shell, sleeping platform and all the stuff I carry everyday. Also, I tow a teardrop both on and off road.
    I don't feel over-geared with them - and more importantly, I don't feel under-geared. I am able to use the entire powerband of the engine.
    I would absolutely do it again.
    SIZZLE[QUOTED] likes this.
  16. Sep 21, 2018 at 3:45 PM
    #216
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Any change to gas mileage? Also are there any issues at cruising along at 70 or more with trailer attached?
  17. Sep 21, 2018 at 8:45 PM
    #217
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    I’m also curious to know what your RPMs are at 70 mph in 5th gear. It’s nice I have the bottom end, what do you have to sacrifice at the top? Thanks so much for your input.
  18. Sep 24, 2018 at 8:45 AM
    #218
    Scott B.
    Scott
    Georgia
    Gas mileage certainly did not improve - but I don't think it really dropped, either. I will have to go look at my notes.
    I can easily cruise 80 with the trailer. In fact, it is hard not to when the speed limit is 75...
  19. Sep 24, 2018 at 8:47 AM
    #219
    Scott B.
    Scott
    Georgia
    No trailer, level road, 2400-ish.
    I don't feel like I have sacrificed anything at the top. It is a truck, not a sports car. But, I have never felt under powered.
    True, it's not the 300 HP V8 I put in my Ranger....
  20. Sep 24, 2018 at 9:42 AM
    #220
    SIZZLE
    SIZZLE Pro-party
    Novato, CA
    Thanks for the input, Scott. At 70 mph I’m around 1900 but the second I dip into the throttle the torque converter unlocks, especially uphill or loaded down. I think I’d be better off being deeper into the power band and I wouldn’t have to go down to 4th so often.
