Scott B.'s 2015 AC Build - Expo Style
Discussion in '2nd Gen. Builds (2005-2015)' started by Scott B., Mar 28, 2015.
  1. Apr 20, 2015 at 10:56 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I have been thinking a lot about the suspension. Specifically, how I want to upgrade/lift the truck. There are quite a few options available!
    I have decided to run a 3” lift instead of a drop-bracket lift. I also like the long-travel setups, and may upgrade to one in a few years. For now, though, a semi-custom (mostly) bolt-on setup is in order.
    Front
    I like the Camburg UCAs with a 1.25” uniball. One decision made.
    For the coilovers, I see 2 groups – Bilstein 6112s or King/Fox/Icon. Given the price difference between the two groups (double) I am trying to decide if I really need the better ones (and, if so, which of the 3 is the one get?)
    Rear
    On my other truck, Deaver built me a custom set of leaf springs (taking into account weight and reversed (tension) shackle configuration). They work great! I am going to have them build me a set for this truck. Another decision made.
    However, there are a couple of lingering questions. Convert to spring under? I’ve seen a couple of trucks that did, and they claim additional suspension travel. Not sure I agree with that. I have a picture (unfortunately, no other info) of a truck with an extended tension shackle. If I can find that setup (or build one) I will run it.
    I plan to run a matching rear shock, but want to change the upper shock mount. Changing to the other style mount (not sure what it is called) will open up the selection of shocks. I want them to be long enough to allow for the droop travel of the new springs. BAMF has a nice extended shock tower. Unfortunately, to get maximum upward extension, the shock must move outboard toward the tire. This will be a problem since I do not to run spacers. So, I think I will build a shock mount, or modify the BAMF ones.
    Drivetrain
    I plan to run 285x75-16 tires on 16x7.5 wheels, 4.56 gears with a TruTrac in each end.
    I am not new to off road travel, but am new to Toyotas. My thoughts/decisions/preferences are from past experience with my other trucks and reading about people’s experience with Tacos. Any thoughts, suggestions and/or comments are welcome.
    One last note – I plan to lift the truck in June. 6 weeks should be enough time to gather parts.
  2. Apr 26, 2015 at 5:49 PM
    Scott B.
    Scott
    Georgia
    The deck of the sleeping platform is finished!
    Cubby doors (or hatches):
    The rear part of the deck:
    And starting to fit the carpet:
    I decided to leave the rear part of the deck removable. I do not plan on removing it on a regular basis, but if I ever need to get under the deck for wiring or to fix a drawer, not having 26" of cover will make the job much easier.
    Crom likes this.
  3. Apr 26, 2015 at 5:52 PM
    Scott B.
    Scott
    Georgia
    10 HP!
    This mod is easily worth 10 HP!
    Original:
    New parts:
    A more pleasurable driving experience!
    Crom likes this.
  4. Apr 26, 2015 at 5:56 PM
    Scott B.
    Scott
    Georgia
    Tech Deck
    I installed a Tech Deck and Mirror Riser. Both are really nice products.
    Original: (Don't mind the pollen)
    Radio out - I didn't realize there were so many connectors!
    Backside of radio bezel, about to get the re-enforcement piece epoxied in:
    Epoxy done:
    Everything back together:
    I still need to add the Ram Mount balls - ran out of time today.
    Crom likes this.
  5. May 12, 2015 at 2:05 AM
    DrFunker
    DrFunker Well-Known Member
    :mudding:
    Nice build :thumbsup:
  6. May 12, 2015 at 6:57 AM
    Scott B.
    Scott
    Georgia
    Thanks.
    More on the way - I have started ordering suspension parts!
  7. Jun 1, 2015 at 3:05 PM
    TRoss
    TRoss Web Wheeler
    NorJoJah
    '12 Reg Cab MGM 4 banger 5spd
    1.5" 5100 Billie lift, 1.5" AAL w/5125's, 265/75/16 Duratracs on SR8's, ECG diff bushing
    I detect slackage in this thread! Bump! And oh... I'm next for the expo bed mod lol
  8. Jun 1, 2015 at 3:23 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Bed mod looks good OP!Been considering doing this in the future.Hurst shift lever looks real nice!
  9. Jun 1, 2015 at 7:41 PM
    Scott B.
    Scott
    Georgia
    Definitely slacking this thread - but that is because I have been ordering parts!!!!!!!!
    The lift should be going on by the end of June.
    Oh, and I just sent the rear diff to ECGS for new gears. I will post some pictures once I get it back together.
  10. Jun 12, 2015 at 12:38 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
  11. Jun 20, 2015 at 6:31 PM
    Scott B.
    Scott
    Georgia
    Getting back to updating this thread:
    Here's a shot of the Tech Deck with Ram Mount balls installed, and my phone holder.
    medic2230 and Crom like this.
  12. Jun 20, 2015 at 6:38 PM
    Scott B.
    Scott
    Georgia
    I did a little debadging...
    Before:
    After:
  13. Jun 20, 2015 at 6:46 PM
    Scott B.
    Scott
    Georgia
    Rear Gear, TrueTrac
    So, the other day, I was looking at the truck and had a wrench in my hand.
    Low and behold, look what came out! ;)
    I sent the chunk off to ECGS for a set of 4.56 gears and a TrueTrac.
    A close-up of the pattern:
    Crom likes this.
  14. Jun 20, 2015 at 10:56 PM
    Greenbean
    Zack
    Western NC
    Sweet!
    Congrats on gears and locker....
    What you doing to the front diff?
  15. Jun 21, 2015 at 5:30 AM
    #35
    Scott B.
    Scott
    Georgia
    I would really like to put in another TrueTrac, but they don't make one. :( It is ARB or nothing. Given my plans for the truck, I don't think I really need an ARB, so I am thinking about leaving it open.
    Maybe Eaton will make a TrueTrac one day...
  16. Jun 21, 2015 at 5:39 AM
    #36
    Scott B.
    Scott
    Georgia
    Gas Tank Skid Plate
    I got a Pelfreybilt aluminum skid plate for the gas tank.
    The SR5 trucks don't come with any skid plates - I thought the gas tank would be a good place to start.
    I decided on aluminum to save weight. This truck is not going rock crawling, so the aluminum should hold up just fine to the projected use/abuse.
    As delivered:
    Since the SR5 did not come with a skid plate, I had to get replacement tank straps that the mounting studs:
    Toyota part numbers:
    77610-04020 - strap
    77602-04020 - strap
    90179-08241 - nut (4 required)
    Before:
    New straps installed:
    Final product:
    It is a well build piece that should last the life of truck.
    Crom likes this.
  17. Jun 21, 2015 at 7:23 AM
    #37
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Looking good! Definitely escalated with the wrench and gears eh. Looking forward to see the rest of the truck!
  18. Jun 21, 2015 at 6:03 PM
    #38
    TRoss
    TRoss Web Wheeler
    NorJoJah
    Nice! I've been perplexed about running aluminum or steel skids. The weight savings in alloy is very attractive tho.
  19. Jun 21, 2015 at 6:06 PM
    #39
    Greenbean
    Zack
    Western NC
    That looks great and honestly is a VERY smart idea....
    I might be adding that to my truck down the road.
  20. Jun 22, 2015 at 6:09 PM
    #40
    Scott B.
    Scott
    Georgia
    Brake Controller
    I added a brake controller since I tow a Little Guy off road teardrop. Besides, the factory already installed a 7-pin connector, so the hard work was done!
    I ordered the controller from eTrailer - great customer service. I saw they had a wiring harness that clips into the factory harness. I ordered one of those also, for true plug-and-play.
    Parts:
    I wanted to mount it where I could easily get to it while driving (for adjustments or emergency stops.) Since my truck has an automatic transmission, there is a "storage tray" where the manual trans emergency brake handle goes. Looked like the perfect spot for the controller.
    With the tray removed:
    Since the mounting surface is not horizontal, I made a template for a new mounting bracket:
    And built a new bracket out of aluminum:
    Controller mounted:
    Tray trimmed to fit:
    It works fine like this, but I think I will clean up the trimming a little bit. Not that anyone would see it other than me...
