Scott B.'s 2015 AC Build - Expo Style
Discussion in '2nd Gen. Builds (2005-2015)' started by Scott B., Mar 28, 2015.
  1. Aug 18, 2016 at 6:10 AM
    #121
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    Thanks! Are you going to Appalachian Rendezvous? I see you lurking on AR and Expo portal
  2. Aug 18, 2016 at 6:12 AM
    #122
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I am! I was the 14th person to sign up!
    Are you going?
  3. Aug 18, 2016 at 6:14 AM
    #123
    m.reed.1
    Adam
    Sacramento, CA
    A few
    YEP! #44 , im trying to get the new rear shocks purchased and mounted before then... can't beat the price of the 5165's
  4. Aug 18, 2016 at 6:18 AM
    #124
    Scott B.
    Scott
    Georgia
    We are going to try camp closer to the campfire this year. The last 2 years we were off to the left - way left. Nice area, but it seemed so far away.
    When are you getting there? We should be there lunchtime on Thursday.
  5. Aug 18, 2016 at 6:21 AM
    #125
    m.reed.1
    Adam
    Sacramento, CA
    A few
    I'll be leaving Virginia Beach area around 4pm on Thursday (5 hr drive) and making the run down... I'll contact the POC and see if I'll still be able to register that night when I arrive.
  6. Aug 24, 2016 at 6:25 PM
    #126
    Scott B.
    Scott
    Georgia
    The shocks are model # 25-187748:
    13.1" 5165 Reservoir
    Travel: 13.1"
    Col. Length: 17.9"
    Ext. Length: 31.0"
    Mounting Upper: EB1*
    Mounting Lower: EB1*
    Sleeves: 1/2"
    Boot: No
    Valving: 255/70
    Shaft Dia: 14mm
  7. Aug 24, 2016 at 6:26 PM
    #127
    m.reed.1
    Adam
    Sacramento, CA
    A few
    Thanks man! Are you using the stock mounting locations?
  8. Aug 24, 2016 at 6:31 PM
    #128
    Scott B.
    Scott
    Georgia
    Lower - yes.
    Upper - I will be cutting the stock one off, fabricating a custom one, with the top of the shock higher than the stock position.
  9. Sep 5, 2016 at 7:10 PM
    #129
    Scott B.
    Scott
    Georgia
    Headrest Mod
    The headrests on the front seats have (had) a very forward lean. I assume it is a new government regulation "designed to keep us safe" in the event of an accident. (Not going to debate the merits of government regulations...)
    The problem, however, is since I like to keep the seatback in a fairly vertical position (the upright seatback is much safer than a reclined seatback in an accident) the headrest pushed my head forward when driving - very uncomfortable. I have read others complaining about the same thing.
    The solution was quite simple - bend them back a few degrees. OK, easier said than done. The headrest frame is quite strong. However, by clamping the vertical support in a vice, and carefully putting all my weight into it, I was able to bend each leg, and re-position the rests to a more upright position.
    In this picture, the driver side seat has been re-positioned, the passenger side has not.
    Crom likes this.
  10. Sep 7, 2016 at 1:24 PM
    #130
    Scott B.
    Scott
    Georgia
    Transmission Cooling, Part 1
    Heat and dirt kill automatic transmissions. Our trucks have small external coolers and minimal filtration. In an effort to extend the service life of my transmission, especially since I tow a trailer off-road, I made a couple of simple changes/improvements to Toyota's sealed transmission system.
    Part 1 replaces the factory transmission oil cooler with a much larger one. The larger cooler has a greatly increased fluid cooling capacity, which will yield lower operating temperatures. Permanent internal damage to an automatic transmission can start to occur at a fluid temperature of 220 degrees, and does occur at a temperature of 240 degrees. Towing a trailer, slow going off-road, even sitting in traffic all load the transmission, which increases fluid temperature. Aside from decreasing the load on the transmission, the best way to lower the fluid temperature is to increase the size of the cooler.
    Here you can see the factory cooler (under the horns)
    I picked up a bigger cooler from Derale
    To mount the new cooler, I fabricated mounting brackets from aluminum flat bar. I used one factory threaded hole, and drilled three new holes.
    Testing the cooler fit
    The finished product. I moved the horns to the passenger side.
    Plumbing was simple - a direct replacement of the factory cooler plumbing. I just used the longer hose that came with the new cooler.
    Unfortunately, I do not have my transmission temperature gauge plumbed and wired yet, so I don't know exactly how much cooler the fluid is.
    Crom likes this.
  11. Sep 7, 2016 at 1:32 PM
    #131
    blackradon
    blackradon Well-Known Member
    james
    YEG, Canada
    2014 sky silver metallic
    That's awesome! I had a XJ and put a larger oil cooler in it from Napa auto parts looks a lot like that one you got.
    Did you have to add more tranny fluid?
  12. Sep 7, 2016 at 1:36 PM
    #132
    Scott B.
    Scott
    Georgia
    I haven't checked the level yet, as I am about to drain and fill. Looking at it, I'd guess that the new cooler holds an additional 1/2 quart or so of fluid.
    Crom likes this.
  13. Sep 7, 2016 at 1:39 PM
    #133
    blackradon
    james
    YEG, Canada
    Ah! You are still in the middle of installing it still. More fluid is good! keep up the good work man, I enjoy reading your updates:thumbsup:
    Crom likes this.
  14. Sep 7, 2016 at 1:47 PM
    #134
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    Crom likes this.
  15. Sep 7, 2016 at 2:17 PM
    #135
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Very nice Scott!
  16. Sep 7, 2016 at 3:10 PM
    #136
    TakeNoteS
    TakeNoteS Well-Known Member
    Luke
    Kalama Washington
    2022 Silver Taco SR5 LB 4X4
    quick question.... I came across your build and noticed you put on 6112s with the rears as well. I am looking into getting these just like you were.... My question is how is the ride on them? Right now I have a 6 in pro comp lift with factory shocks and well they suck... do your 6112s ride nice and smooth? :hattip:
  17. Sep 7, 2016 at 3:53 PM
    #137
    Crom
    Nick
    San Diego, CA
    Millions
    Scott, all your mods are so clean and elegant. You give me something to shoot for. :)
    If you ever have to make further modifications to the head rests consider the way I went about it. Which is to slip a 1/2" box wrench into a bench vice, then put the head reset stanchion through the wrench. Slip a piece of pipe over the stanchion and you can bend it really easy.
    Pics in this post: Front seat head rest modification, bend stanchions, July 2015
    Look forward to your future posts.
  18. Sep 8, 2016 at 10:00 AM
    #138
    Scott B.
    Scott
    Georgia
    Thanks! I am glad someone is reading these!
    I would really like to put a deeper pan on - add maybe 2 quarts of fluid. But, I do not know of anyone making one. And my welding skills are not yet good enough to build my own.
  19. Sep 8, 2016 at 10:01 AM
    #139
    Scott B.
    Scott
    Georgia
    The rear shocks are 5160s, not 6112s. The 5160s have a reservoir, the 6112s do not.
    Yes, they ride really nice. To be fair, I have never had racing shocks (King, Icon, Fox) so I can't make a direct comparison. But, I have no reason to change/upgrade my Bilsteins - I am very happy with them.
  20. Sep 8, 2016 at 10:03 AM
    #140
    Scott B.
    Scott
    Georgia
    Thank you.
    Thank you.
    I certainly enjoy building the truck, then going out and using my new mods. :)
    Crom[QUOTED] likes this.
