Scout Yoho Slide-in Truckbed Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by YF_Ryan, Apr 8, 2021.
  1. Jul 26, 2022 at 8:29 AM
    #121
    YF_Ryan
    YF_Ryan [OP] Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I started ripping out the shelf where the Goal Zero went. Actually, i pretty much finished. This is the only pic I took though, as it was like 9:30 when I finished last night. These cabinets are NOT made to come apart. Built way better than expected. On the rear and right side in this pic, the shelf sits on those wooden blocks screwed to the wall, but on the front edge and left side, there are grooves in the vertical plywood that the shelf sits in, and is glued into. The cabinets are built BEFORE going in the camper (confirmed with someone who has been to factory). I thought about removing the full cabinet, but that woulda been a pain and don't really like the idea of removing the screws from the structural panels.
    Next up, I need to remove the top of the cabinet that spans from left to right so I can drop the Bluetti down to the floor level through where the shelf used to be... This seriously was not for the faint of heart. Took a lot of cutting, prying, cussing, and breaking tiny pieces apart with plyers... Could very easily break/damage cabinets and shelves around it. And obviously... there is no putting that shelf back in, lol.
  2. Jul 26, 2022 at 11:43 AM
    #122
    Scouttruck
    Scouttruck Member
    YF_Ryan[QUOTED][OP] likes this.
  3. Jul 26, 2022 at 11:47 AM
    #123
    Scouttruck
    Scouttruck Member
    What's the overall goal here. Making room for a larger battery bank?
  4. Jul 26, 2022 at 11:53 AM
    #124
    YF_Ryan
    Kent, WA
    Yup, this guy.
    So I can run these!!! lol. Tested it out last weekend. Now to install it.
    Scouttruck[QUOTED] likes this.
  5. Jul 26, 2022 at 12:04 PM
    #125
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Heh, impressive but how many days does it take to get the burger smell out of your camper (and clothes)? :D
  6. Jul 26, 2022 at 12:07 PM
    #126
    YF_Ryan
    Kent, WA
    Had the windows open and the fan going. I'd go with pretty much no time at all. Definitely had a few splatters to wipe down on the window frame and counter, but not any worse than when we use the propane stove top.
  7. Aug 11, 2022 at 8:43 AM
    #127
    YF_Ryan
    Kent, WA
    Finally got the Bluetti AC200 Max in place. This was even more of a chore than I thought it would be. Didn't realize the top of the cabinet was notched and glued to the vertical front plywood of the cabinet. No way to get it off without destroying it so I had to cut a hole in the top. I messed up a bit on my line, obviously, but oh well. I'm no wood worker hahaha. Not seen in pics, I drilled 4 one inch holes in the plywood wall between the Bluetti and Toilet storage area to increase air flow to side of Bluetti. I also have a small block of wood keeping it away from the wall on the right to allow air flow, as the cooling fans exit the left and right sides just below the handles. And no, you can't get the Bluetti back out without tools. At least not how I did it.
    The Bluetti hadn't been used since our last trip and was still at 100%. I used it to run the jig saw and only brought it down 2%. Plugged in the solar and was getting 123 watts. Charged back up quickly.
  8. Aug 29, 2022 at 8:31 AM
    #128
    YF_Ryan
    Kent, WA
    So the Bluetti did awesome on a 4 night trip down at the Dunes. We had brought our generator figuring we'd need to recharge, but NOPE! Even without ideal positioning of the camper/solar panel it consistently got back up to 93-95% each day. This included running it down to about 73% at one point after running the air fryer to bake some meatloaf! The kettle was used numerous times, and the electric griddle once for breakfast sandwiches. And of course, we had the Dometic 75 liter fridge running at 32 degrees keeping food and drinks nice and chilled.
    Oh yeah, and the bed mat made a great patio, too. Helped keep the sand a little more under control.
    GoldenTaco27 and Gen3TacomaOBX like this.
  9. Sep 9, 2022 at 11:18 AM
    #129
    YF_Ryan
    Kent, WA
    Today is the one year anniversary of owning our Scout Yoho. We've spent 39 nights in it so far, and loved every one of them.
    Last week I dropped off the camper at the factory in Yakima, WA to have some work done. They wanted to figure out an intermittent leak I have (2x in one year only), and swap some rusting hardware for me. Sounds like the early models could get water in the extrusions, so they've started adding weep holes to make sure the water can escape. They replaced al the end caps with new ones (with weep holes) thinking that might have been my issue. They resealed and re-installed my door frame, added another rubber seal to it, sealed the window I installed myself (surprised they took the time since it wasn't even a product of theirs), they recaulked a bunch of the external seams, installed a new, improved skylight, and even cleaned up my messy caulking job I did on one of my clearance lights. O yeah, and they replaced my propane door with one with a second latch that will hold tighter against the bulb seal. I feel they went above and beyond anything I would have expected. And on top of that, they originally figured they'd need to keep it for a month, it was done in 2 days!!
    I know some folks have had issues with their Scouts, obviously I've had a few of my own, but being an early adopter I'm not surprised at all. They've made a ton of improvements just in the couple years they've been in production, and have taken good care of me. But I'm lucky, I'm here in WA state, only 2 hours and 15 minutes from their factory. Those early adopters on the east coast, I wish you all the best and hope your campers treat you well! *crosses fingers*
  10. Sep 9, 2022 at 11:37 AM
    #130
    YF_Ryan
    Kent, WA
    Almost forgot!
    I entered my truck in the Overland Truck Show tomorrow in Snoqualmie, WA. If anyone is interested in checking out a Scout Yoho on a 2nd Gen Taco in person, they are more than welcome to stop in and say hi. I'll be there from 11AM to 5PM. And supposedly there is other stuff going on too, so could be fun for the whole family!
    305965231_10112706223039078_802581210433_d603c632c4d24abbbfb06b2bdb796fbe6c18881c.jpg
  11. Sep 9, 2022 at 12:40 PM
    #131
    YF_Ryan
    Kent, WA
    a2lowvw likes this.
  12. Sep 11, 2022 at 2:10 PM
    #132
    TheOnlyPajooned
    TheOnlyPajooned Well-Known Member
    Don
    The 'Couve, WA
    2012 DCLB Sport
    she got big shoes bro
    If they're using your image, you should ask them for compensation or ask them if they offer sponsorships/affiliate links or something :thumbsup:
  13. Sep 11, 2022 at 6:11 PM
    #133
    YF_Ryan
    Kent, WA
    They had asked back at the rally if they could use the images from my TW postings. I said yes. Not realizing they meant my buddy Kyle's photos! Lol. He was happy to see them online though. I had them give him credit and they updated within a couple minutes. He actually worked for them when he took the pics, I think.
  14. Sep 27, 2022 at 9:24 PM
    #134
    .劉煒
    .劉煒 Well-Known Member
    2016 Inferno DCSBTRDORMT
    Looks like a cool setup - been thinking about something like it for a ski resort dirtbag-ish rig.
    YF_Ryan[OP] likes this.
  15. Oct 5, 2022 at 5:53 PM
    #135
    Scouttruck
    Scouttruck Member
    thoughts on E-rated tires for the Tacoma scout combo is it overkill?
  16. Oct 6, 2022 at 7:38 AM
    #136
    YF_Ryan
    Kent, WA
    I feel much safer knowing I have the E-rating. I mounted the new tires before picking up the camper, but it was easy to see how much stiffer the tires are. For example, when airing down for sand driving and such, I need to air down far further before getting as much sidewall flex as I want. I'm sure this translates over well to driving with the camper on, as it should help keep the tires from wallowing as much in cornering.
    I recently loaded my camper on my dad's gen 1 Colorado with SL tires at full rated pressure. The tires were horribly squat. Luckily I was only moving my camper from my driveway to my backyard.
  17. Oct 17, 2022 at 7:47 AM
    #137
    YF_Ryan
    Kent, WA
    Shameless plug: Posted a couple pics in the calendar contest. < click that link will take you to the picture below on the calendar contest. Likes = Votes :fingerscrossed: Thanks all!!
  18. Nov 13, 2022 at 2:53 PM
    #138
    YF_Ryan
    Kent, WA
    Loaded up the Scout Thursday night so we could take off immediately after work Friday. Having the camper 95% loaded all the time makes it a breeze to get ready.
    Scouttruck likes this.
  19. Feb 23, 2023 at 4:53 PM
    #139
    Scouttruck
    Scouttruck Member
    Finally had a chance to upgrade the stock tires. I'm really happy with them.
    The tires are the Goodyear Wrangler ULTRA TERRAIN AT 265/75R16 load range E. They are 3 peak snow rated and are similar to the Goodyear DuraTracs.
    LarryDangerfield and YF_Ryan[OP] like this.
  20. Feb 24, 2023 at 7:41 AM
    #140
    YF_Ryan
    Kent, WA
    You are one of the few on TacomaWorld AND the Scamp Campers Owners group. :)
    If I were to want a slightly less aggressive tire, I'd definitely give these a go. I like the tires with the extra tread on the sides like that. Just looks bestter, IMO.
