Scrambled Dash Screen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baker18, Aug 16, 2024.
  1. Aug 16, 2024 at 9:03 PM
    Baker18
    Baker18 [OP] World's Okayest Geologist
    Arizona
    2020 Tacoma SR
    Geeze I sure have been active here lately lol.
    So today I started up my truck and my dashboard LCD screen was scrambled. I didn't take a photo, but it looks identical to what's shown in this topic.
    https://www.tacomaworld.com/threads/screen-appears-scrambled.749367/
    I turned off the truck and waited for the screen to turn off, then turned it back on and it was normal. Truck is a 2020 SR Access Cab with roughly 31,800 miles on it.
    It looks like most of the folks who encountered this issue had the same experience as me in that it fixed itself. But I figured I'd ask around to see if anyone else found an actual cause or solution to this?
    For what it's worth, I ran over to AutoZone and had them test the battery and sure enough, one of the cells was bad. So I swapped out the battery with a new one as my current battery was the original, so I'm lucky I got 4 years out of it in the Arizona heat.
    Any thoughts would be much appreciated!
  2. Aug 16, 2024 at 10:35 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Dude you got 4 years in Arizona?.... duuuude go buy a lottery ticket like NOW.
    I swap out batteries in 3 vehicles every other year whether they need it or not.
    Chew and Baker18[OP] like this.
  3. Aug 16, 2024 at 10:39 PM
    Baker18
    Arizona
    2020 Tacoma SR
    Hahaha maybe I have good luck with batteries? I have a 20 year old Civic I put a new battery in before leaving Oregon (so January of 2020), and the battery finally died in December of 2023. I'm seriously shocked it lasted that long because unlike my Tacoma, it's not parked under a carport or in a garage. It's been parked outside in the sun since I arrived in Arizona back in February 2020. Wild!
    I might buy a lottery ticket though. I could use the extra money to mod my Taco, I mean, be a responsible adult ;)
  4. Aug 17, 2024 at 8:40 AM
    2021SR5V64WD
    And to help your fellow man, and locate and buy them a brand new 2023 that is still on the lot somewhere.
    Access Cab preferred, any color other than Lime, White, or Black.... but this luzer-chooser won't be picky.
    Baker18[QUOTED][OP] likes this.
  5. Aug 20, 2024 at 4:36 PM
    Baker18
    Arizona
    2020 Tacoma SR
    Wanted to bump this to see if others have experienced this recently? Seems like it's mostly 2020s with a few 2021s thrown in. I can't find any super recent threads about it, so I'm wondering if it's just a periodic glitch or if I should look into it more?
  6. Aug 20, 2024 at 5:47 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Check out post #42. Might be a connector issue.
    https://www.tacomaworld.com/threads/dashboard-display-issue.707976/page-3
  7. Aug 20, 2024 at 5:54 PM
    Baker18
    Arizona
    2020 Tacoma SR
    Sometimes it feels like I just can't win with this truck lol.
    Would a connector issue be like an entire wiring harness or something along those lines? Admittedly I am not any sort of expert when it comes to vehicles, so apologies if this is a dumb question.
    I did have aftermarket fog lights installed the day before this happened at what I believe is a reputable shop. But it seems like this has affected people with and without aftermarket mods.
  8. Aug 20, 2024 at 6:01 PM
    TA2016
    Oregon
    If it were me, I would start by crawling under the dash and check all the connectors to the Combo meter to make sure they are tight. If you don’t feel comfortable doing it yourself you might have a mechanic or friend help you.
    I always like to unhook the Negative battery cable before doing electrical work.
  9. Dec 7, 2024 at 6:26 PM
    TheGrayNorthWest
    TheGrayNorthWest Well-Known Member
    Older thread, but wanted to share my experience with this issue as well. 21 OR, and I had it happen to me twice recently. Both times I was parked on a hill at an angle where the sun was directly hitting the LCD screen for a prolonged period on warm days. I put it in the shade and the issue when away and hasn't returned.
    If it happens again, I would check the screen to see if the sun was cooking it. That seemed to be my issue.
    Chew likes this.
  10. Mar 5, 2025 at 9:43 AM
    L33TZOR
    L33TZOR New Member
    Ron
    20 Taco Sport Ed
    N/A
    I decided to jump onto the forum, and i am faithful to forums and i still wish my forum was up but free forums somehow flew the coop. Checking this post i was going to start with fuses and maybe even replacing the truck battery. I havent had hard starts but wifey is accustomed to a US Made suv. This is her gift since shes been wanting a truck. Anybody have any suggestions?
    Fuzzy garbled dash lcd screen but truck seems to start and drive fine.
