Scraped bottom on a speed bump - now MPG is suffering.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wh013mi1k, Oct 11, 2012.
  1. Oct 11, 2012 at 6:13 AM
    wh013mi1k
    wh013mi1k [OP] Well-Known Member
    2012 DCLB TRD SPT V6
    Leading out of the gate: I am mechanically-retarded. So I just have to set the expectation low because I'm simply looking for guidance.
    Last month I purchased my first Taco ('12 DCLB V6). Because I'm Type-A, I keep a mileage and MPG log and update it at every fill up. Since I purchased it I've been getting 18.1-18.4 MPG per tank.
    HOWEVER, earlier this week I had to drive from RI to VA for a funeral and once arriving in VA I bottomed out the truck on a speed bump. Ever since then (on the trip back and 1 tank around town) I've been getting 16.8-17.3 MPG.
    Does this sound right? What normally scrapes when you go too fast over a speed bump? I haven't gotten it on a lift yet, don't see any visible damage, and will be taking it to the dealer for another unrelated issue (bad weatherstripping) - what should I point to or suggest to look at? Or am I being too fickle?
    Thanks for any and all guidance.
  2. Oct 11, 2012 at 6:15 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    How did you bottom out a truck on a speed bump? Wtf?
  3. Oct 11, 2012 at 6:16 AM
    wh013mi1k
    Wasn't bottom out as much as scraped the bottom of the truck right behind the front tires - I didn't accelerate but wasn't on the brake either.
  4. Oct 11, 2012 at 6:16 AM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    right a 4x4 bottoming out on a speed bump? how
  5. Oct 11, 2012 at 6:17 AM
    Nunavut
    Nunavut Eh oh, Canada go.
    Canada
    Could you of damaged the catalayic converter?
  6. Oct 11, 2012 at 6:18 AM
    wh013mi1k
    Explain? Remember, car retarded. It WAS about 15 degrees colder in VA than RI... if that makes any sense.
  7. Oct 11, 2012 at 6:19 AM
    wh013mi1k
    You've probably never been to northern Virginia. They have speed HUMPS there in addition to speed bumps.
  8. Oct 11, 2012 at 6:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you bottomed out the suspension, any scraping you heard was probably just the mud flaps hitting the speed bump. My mud flaps would scrape the speed bumps occassionally at my old apartment complex. There's nothing else low enough on the truck to scrape over a speed bump. As far as the MPG loss, it's likely just due to the highway run. I typically experience a drop in MPG on extended highway runs also. When you get back to your normal routine, your mileage should go back to where it was.
  9. Oct 11, 2012 at 6:20 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    It sounds like you scraped the stock (ridiculously long) mud flaps on the speed bump. I doubt any structural part of your truck actually touched the speed bumps.
  10. Oct 11, 2012 at 6:21 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Probably scraped the mud flap? And, as mentioned, winter fuel blend could be the reason for the drop in mpg
  11. Oct 11, 2012 at 6:21 AM
    wh013mi1k
    You know, that's a great point. I looked all over the running boards and undercarriage but never checked the mud flaps... I love this site.
  12. Oct 11, 2012 at 6:23 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    There is a cross beam between the two main frame rails, be about middle of cab, just behind/ under the back of the engine. If you hit something it'd probably be that. Check for scrabbing damage on it. It'd be easy to see.
    Your mileage drop sounds consistance with the switch to winter fuels @ gas stations. I wouldn't be concerned unless it drops lower. Since your vehicle is brand new, you should get a slight boost in mpg's after your engine has broken in. Around 7,000 - 10,000 Miles.
  13. Oct 11, 2012 at 6:26 AM
    wh013mi1k
    I was completely unaware of the winter fuel blend - gonna have to google that. BUT, that cross beam that you mention was the first thing I checked when I got underneath it and didn't see anything at all.
    I'm willing to bet my paycheck that it was the mudflaps (my memory of the sound is consistent with what plastic scraping vs. metal scraping would sound like). I just have to wait until lunch for me to run out there and look for the rub marks.
  14. Oct 11, 2012 at 6:33 AM
    bjhn83
    bjhn83 Well-Known Member
    Bradley
    Columbia, MO
    05 SR5 DCSB Grandpa Shell
    3" Toytec lift, 285/75/16 BFG AT KO's on Pro Comp 7089's, Yellow fog lights, Satoshi
    Yea scraped/damaged mud flaps can set you back 2-3 MPG, (thats why most guys take them off anyways) but if you get a sweet rockstar or monster sticker to put on the rear window it should get you back up to your normal mileage, and will even add 5-10 horsepower!
    :D
    But for real you seem like a nice enough guy so don't take that joke personally. I'd say its winter fuel mix like stated above.
  15. Oct 11, 2012 at 6:34 AM
    wh013mi1k
    There's not enough room on my rear window with all of the Hello Kitty decals I put on before my trip.
  16. Oct 11, 2012 at 6:39 AM
    Larry
    Larry CARL
    CARL
    not sure about the ethanol part...
    winter fuel was around before the idiots in DC started pushing the corn gas on us.
    and, I believe the percent of ethanol must be posted on the pump by law.
    use more than 10% on some vehicles and it will mess them up good. Even the 10% plays havoc on many boat motors and fuel tanks/fuel systems.
    Ethanol is one of the dumbest things ever.
  17. Oct 11, 2012 at 6:42 AM
    DrewH
    DrewH Well-Known Member
    You hit your mudflaps. The two aren't related.
  18. Oct 11, 2012 at 6:46 AM
    bjhn83
    Bradley
    Columbia, MO
    Haha that's your problem. The stickers are too much added weight, ruining your mileage. Problem solved.
  19. Oct 11, 2012 at 6:46 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Different states, different brands, different gas, different mpg. Not all gasoline is made exactly the same so it could just be VA gas vs RI gas.
  20. Oct 11, 2012 at 6:51 AM
    wh013mi1k
    This would be the only time in history Rhode Island didn't suck the worst out of all the states. I should inform the media.
