Scraping disk brakes
Discussion in 'General Automotive' started by Krazie Sj, Sep 21, 2010.
  1. Sep 21, 2010 at 1:14 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    So the wifes 2001 WG Rear drivers disk brake has a scraping sound like a rock stuck in the disk. It's only apparent at low speeds and doesn't seem to affect braking power.
    Any clue what in the happy fuck that could be?
    There's no squeaking from the brakes or pulling to any side.
  2. Sep 21, 2010 at 1:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Drain the tranny fluid, and dump it into the coolant...
    :p Take it to a car wash, and spray it out really good. It could be a rock stuck in it. If it doesnt go away, It may be the noise maker telling you it needs new [ads.
  3. Sep 21, 2010 at 1:31 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Should I be using a pressure washer or just a good solid hose with a nozzle?
    And anyways, I'm not doing an oil change. If anything I'd remove the spare tire and mount it where the radio antenna is.
  4. Sep 21, 2010 at 1:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, A pressure washer is fine, but keep the nozzel about (sorry) aboot 6" away...not sure what that is in CM's or whatever shit you use to measure....
  5. Sep 21, 2010 at 1:41 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    hey,i did that........it made my waterpump start shifting:p
  6. Sep 21, 2010 at 1:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    GAH!!!
  7. Sep 21, 2010 at 8:36 PM
    2gtacoma
    2gtacoma Well-Known Member
    Daniel
    H-town
    05 -PreRunner sr5
    URD Maf Cal, Airaid intake, Gibson exhaust, Urd short shifter,Trd shift knob, 2.25 lift,Satoshi grill, Trex eyelids
    to me sounds like the wear indicator is letting you know its getting low. Why dont you take off the rear tire and inspect it.
  8. Sep 21, 2010 at 8:54 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2....sounds like worn out pads.
  9. Sep 21, 2010 at 11:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What vehicle is this?
    Drive in reverse and put the brakes on, should dislodge any rocks/debris.
  10. Sep 21, 2010 at 11:29 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I KNOW!
    Take it to a professional and have them take a look at it.
  11. Sep 22, 2010 at 12:12 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    2001 Grand Cherokee.
    I'll get the wife to try the reverse thing tomorrow.
    I thought wear pads were supposed to squeak? Not sound like an iron dick rubbing up against the rusted leg of a giant...
  12. Sep 22, 2010 at 4:57 AM
    larryde09
    Larry
    Boston, MA
    On older cars I've had some pads squeek and some make a grinding noise. Then I had one that I ignored the squeek for too long and it turned into grinding...oops!
  13. Sep 22, 2010 at 5:40 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    This just happened on my girlfriend's car, the pads were shot. No squeek, just grinding metal on metal. I'd check sooner rather than later otherwise you'll put some nice digs in the rotors and will end up buying them also.
  14. Sep 22, 2010 at 5:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    "Squealers", as they are called, do make the squeal sound. But if the pads are worn enough and the squealers are none existent, then it does sound like and iron dick rubbing up against the rusted leg of a giant.
  15. Sep 22, 2010 at 5:51 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    do they look like this?
  16. Sep 22, 2010 at 5:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    Now that's impressive
  17. Sep 22, 2010 at 7:08 AM
    Janster
    Jandy
    Lancaster, PA
    Oh dear god.... Grand Cherokee brakes SUCK major ass. We had a 99 and my mother-in-law currently has it. When we first bought that thing (used)- the first thing we replaced was the rotors & calipers on the front (TSB calipers). Not 3 years later, replaced the front rotors again. They warp soooo frigin easy. Then, after selling it to my mother-in-law.....had to change the rear rotors/calipers because they were all messed up (gouged/chewed up). It's been fine since, but she only drives it 3k miles a year. We're eventually gonna get rid of the damn thing!!!
    Did you inspect the rear rotors? They might be all gouged up and/or too thin.
    On ours....we didn't get any warning of the rears being gouged. The pads were fine and the last time we checked them (maybe 2 years), everything looked good. Seems sometime in that 2 years, those rear rotors went to shit (wearing thin). That's just my experiences...
  18. Sep 22, 2010 at 7:25 AM
    65tacodude
    65tacodude Well-Known Member
    Wade
    Manteno, IL
    '18 Tundra Platnium
    OEM running boards and roof rack. Yellow fog bulbs and WeatherTech mats and window visors.
    Ive seen this in school buses before...and worse..
  19. Sep 23, 2010 at 9:05 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    I'll have a look at that. I knew the pads were already warped because when braking it kinda pulsed (Not ABS style pulse, but fucked up rotor pulse).
    The thing that is concerning me now is that I took it for a drive yesterday with the window down and it makes a lighter sounding scraping sound when driving at low speeds. Sound goes away at around 20mph and oddly enough when turning right. And comes up again if you hit a bump.
    This is the weirdest vehicle I've ever seen...
  20. Sep 23, 2010 at 9:16 AM
    Janster
    Jandy
    Lancaster, PA
    The sounds go away when you step on the brakes? So you know for sure it is the brakes?
    Have you visited the jeepsunlimited forum? There will be a shit-ton of information regarding the GC and its wonderful personality. :D
    The WJ section
    http://www.jeepsunlimited.com/forums/forumdisplay.php?f=21
