Scraping noise coming from front drivers side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 305tacoma03, Mar 27, 2023.
  1. Mar 27, 2023 at 2:51 PM
    305tacoma03
    305tacoma03 [OP] New Member
    White 2011 Tacoma
    Spyder Headlights & Taillights, TRD Pro Grille, Cali Raised LED Amber Fog Lights, Hidden Bumper Light Bar, 3 inch lift/leveler, 16 inch Summit Rims, 33 inch BF Goodrich ATs.
    Noticed today a loud scraping noise coming from front driver side, truck is also pulling slightly to the left at the same time that the noise is made, with brakes needing to be pumped in order to engage. I think it is a brake issue but any other ideas would be appreciated.
  2. Mar 27, 2023 at 2:58 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Brakes, check caliper pistons make sure they are working properly also dust plate in back cloud be hitting the rotors
    But I see a possible brake job in the future
    tcjacado and 305tacoma03[OP] like this.
  3. Mar 27, 2023 at 2:59 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Where are you?
    I ask because I have NIB: power stop rotors and power stop ceramic brakes pads
    Think would be to much to ship long distance
    tcjacado likes this.
  4. Mar 27, 2023 at 3:23 PM
    305tacoma03
    White 2011 Tacoma
    Located in Gainesville FL
  5. Mar 27, 2023 at 4:30 PM
    911monty
    911monty Active Member
    Monty
    07 Tacoma TRD Sport
    Check wheel bearings. Bad bearings can cause rotor misalignment, resulting in pads being pushed back and more pedal to close the gap between pads and rotor. Can also cause pull.
    305tacoma03[OP] likes this.
