scraping noise when backing up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccpalmer, Mar 15, 2017.
  1. Mar 15, 2017 at 1:12 PM
    ccpalmer
    ccpalmer [OP] Member
    I have a 2006 Tacoma xtracab 2WD, 94,000 miles. I hear a faint scraping noise when backing up. I only hear it when I am applying a little gas while backing up. If I don't apply gas while backing up I don't hear it. It sounds like it is a faint scrape about every wheel rotation.
    I did have a shop look at it; they couldn't hear the noise (it was snowing and I hadn't determined that it was only when applying gas) but they did check the brakes and they were all fine.
    Any ideas? Thanks.
  2. Mar 15, 2017 at 1:13 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    rock stuck in dust shield?
  3. Mar 15, 2017 at 1:13 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    got new tires or wheels? Might be a little tire rub on the mud flaps...
    DustStorm4x4 likes this.
  4. Mar 15, 2017 at 1:44 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Other parts that could be rubbing and making the noise are brake drum, driveshaft. And if you got super fat tires then also check the inboard clearance from shock mounts and leaf springs, etc.
  5. Mar 16, 2017 at 5:23 AM
    ccpalmer
    No new tires, and they are small tires so no rubbing. Where could the driveshaft be rubbing?
  6. Mar 16, 2017 at 5:51 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Check the u-joints, and grease them.
