Scraping turn left at speed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigFoote, Jan 30, 2021.
  1. Jan 30, 2021 at 2:28 PM
    BigFoote
    BigFoote [OP] Member
    Robert
    2005 Tacoma 4x4
    I have a 05 4x4, when I turn left I was hearing a noise that sounded like the bearing going out. Last week, my ABS started tripping when breaking on a dry road at low speed. The ABS light came on and ABS no longer activates.
    I replaced the wheel bearing today, it had puked its grease all over the ABS speed sensor. I cleaned it well and assumed that may have caused the ABS issue.
    Now I hear a new noise turning left at speed. In the 30-40mph range, I get a scraping noise. I did some slow speed circles and it was sorta clicking, kinda like a bad u joint but I can no longer reproduce that.
    Any ideas? I tried to record the noise but it's hard to hear over engine noise.
    https://youtu.be/p3C1EbAPbq8
  2. Jan 30, 2021 at 2:31 PM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Maybe the ecgs needle bearing?
  3. Jan 30, 2021 at 2:57 PM
    BigFoote
    Robert
    2005 Tacoma 4x4
    Is there a good way to tell if it's the source?
  4. Jan 30, 2021 at 10:45 PM
    Bigpat_ca
    Sacramento, CA
    I haven’t experienced it personally but a quick search in the forum should help you
  5. Jan 30, 2021 at 11:03 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    If the noise goes away in 4WD then it’s likely the needle bearing
