Scratch rear window weather stripping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDWEST, Mar 24, 2013.
  1. Mar 24, 2013 at 11:47 PM
    TRDWEST
    TRDWEST [OP] Well-Known Member
    Tucson, AZ Area
    2012 DC TRD OFFROAD 4x4
    CVT RTT, VooDoo 10 inch bed rack
    Was in a hurry the other day and for whatever reason the air compressor I was moving out of storage, I positioned the compressor close to the cab in the bed of the truck. Because I wasn't thinking and didn't strap it down, the first stop light I came too the air compressor leaned forward and a wing nut that holds the air breather on the compressor banged up against the window. I pull over and get out and noticed that the wing nut had not only scratched but more so gouged part of the weather stripping that outlines the rear sliding window. Is there a way to fix this other than replacing the whole thing, some RTV filler or something? 2012 DB TRD by the way, thanks
  2. Mar 24, 2013 at 11:48 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Pictures?
  3. Mar 24, 2013 at 11:53 PM
    TRDWEST
    Tucson, AZ Area
    Will have to get one in the daylight too dark outside
  4. Mar 26, 2013 at 8:33 PM
    TRDWEST
    Tucson, AZ Area
    heres a pic of the gouged weather stripping
  5. Mar 26, 2013 at 8:45 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    don’t look that bad(i enlarged the pic) i’d just forge about it. sucks, but unless you can just fill it or something i don’t think its worth fixing.
  6. Mar 26, 2013 at 8:56 PM
    TRDWEST
    Tucson, AZ Area
    thats what i was thinking too, fill it with something, but what would anyone recommend?
  7. Mar 26, 2013 at 9:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    RTV or anything you fill that with is not going to match the color or texture.
    Just ignore it. It's a truck. It sucks, but nobody else is going to even notice that.
  8. Mar 26, 2013 at 11:22 PM
    TRDWEST
    Tucson, AZ Area
    Yeah u guys are right, I am sometimes too much a perfectionist, I'm sure ill see more blimishes in the future when I turn it into an expo rig
  9. Mar 26, 2013 at 11:32 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    I wouldnt worry about it either :)
