Scratches
Discussion in 'Detailing' started by Brobrady, Jun 18, 2016.
  1. Jun 18, 2016 at 10:29 AM
    Brobrady
    Brobrady [OP] Well-Known Member
    I just got some scratches on the side of bed above the rear wheels. A few of them are deep enough to feel with my finger nail. My color is MGM. What should I try first to fix them?
  2. Jun 18, 2016 at 11:13 AM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    If you can feel them with your fingernail, don't try to achieve 100% correction-- you might compromise the clear coat. That's the general rule of thumb.
    You can use something like Mequires ScratchX to minimize the appearance of the scratch, but you'll prob not get very far without a machine. Ultimate Compound/Polish is an additional option to try to blend them a bit.
  3. Jun 18, 2016 at 11:14 AM
    NMTrailRider
    New Mexico
    Depending on how big the scratches are, you can look into skmething like Dr. Colorchip. But that's more for chips than scratches I think.
  4. Jun 19, 2016 at 7:24 PM
    runner05
    runner05 Well-Known Member
    Karl
    You can use touch up paint on deep scratches, then wetsand to remove the excess. Use compound/polish to refine the result.
  5. Jun 20, 2016 at 7:12 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Well first, are you running larger wheels and tires?
    If yes, just accept that this mod will cause paint damage, and unless you go back to stock size wheels/tires you will just continue to develop this damage.
    If no, then you can try to polish out some of the scratches if you can get your hands on a machine, however sounds like they are deep enough where you won't be able to get them all out. If the scratches are just on the flares, you can look into just getting new flares for the rear. Not sure how much that will set you back.
