Screaking Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uptown1, Nov 7, 2022.
  1. Nov 7, 2022 at 7:19 PM
    uptown1
    uptown1 [OP] Member
    2009 Toyota Tacoma
    Why does my back brakes on a 2009 Toyota Tacoma screak only, when I am backing up? It doesn't do it going forward when I put on the brakes.
  2. Nov 7, 2022 at 9:57 PM
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Maybe your brakes pads or shoes are almost done.
  3. Nov 7, 2022 at 10:58 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    I've had that happen before. Remove the drum and spray everything down with brake cleaner. It should go away after that.
  4. Nov 8, 2022 at 5:42 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Take the drums off and look for broken hardware or shoes worn/out of adjustment
  5. Nov 8, 2022 at 8:28 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    screak?
    Sudsman44 and ToyoTaco25 like this.
  6. Nov 8, 2022 at 10:34 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    This. We had the same thing happening when our 2005 was new (within 2 years of purchase). Under warranty -- the dealer tech said it's common, he pulled off the drums & cleaned it up. Been good since then, except for an occasional (rare) squeak that's mild and goes away quickly.
  7. Nov 9, 2022 at 4:52 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    It's a noise combination between a creak and a squeak. He's trying to best describe the sound.
