Screeching Clutch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Nov 24, 2010.
  1. Nov 24, 2010 at 9:33 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have 2008 2.7L 5speed base Taco 5lugger with 27k miles. When I am taking off and easing off the clutch I get this screeching noise. Louder noise the more gas I give it while easing off the clutch. It can be avoided by modulating the clutch and throttle very carefully... The truck drives and shifts gears fine. The problem is only the sound. It sounds nasty. Anyone had the same problem or know what it could be?
    I find it HARD to believe that it is the throwout bearing or clutch... I mean hell only 2years old and 27k miles???
    Anyone has the same problem?
  2. Nov 24, 2010 at 9:49 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My company truck does that. 2009 2wd 5 lug 2.7 5speed It has 38K on it and has been making that noise since I started driving it 3K miles ago. The guy that was driving it before had mentioned it awhile back as well, so it's been noisy for awhile. He just never did anything about it. He is the boss's stepson, so I find it hard to believe that he abused the truck. Seems to drive okay, but every now and then I will feel it slip when shifting gears and trying to get on the freeway. This truck has a heavy aluminum shell on it and is full of tools, I'm sure it's got 800-1000 pounds in it all the time. Still disappointed though since the 2004 tacoma that I was driving never did this and it had 130K on it.
  3. Nov 25, 2010 at 1:17 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Saw a couple broken clutches on the forum.. The "outer ring" had separated from the center. It will still work because its pinched between the pressure plate and flywheel.. but would probably make noise.
    Throw out bearings should last 100k on almost anything.. but they CAN fail the first time they're spun.
    Hmm.. screeching eh? Hmm.. What can it be other than the clutch release bearing really? Unless you mean a squeaky clutch pivot.. But sounds like you mean something spinning.
    Hopefully it isn't the input shaft or nose bushing doing something weird.
  4. Nov 25, 2010 at 7:37 AM
    05RedTaco
    Tony
    Scottsdale
    I think most documented problems were with the 6 speed...
    Not Clutch pivot pedal. It screeches when I apply throttle and release clutch. HRM my car was toyota certified vehicle so I will take it to the dealer. This SHOULD be covered by warranty!
    I bet the dealer will blame the noise to either my lift, 31's OEM cruise control or rear diff relocate breather...LOL
    As far as my knowledge goes, I would suspect something in the bell housing assembly to be the culprit. It is just plain hard to diagnose, because it does only when driven and I don't really feel like dropping the transmission in my driveway :/
  5. Nov 25, 2010 at 9:02 AM
    joes06tacoma
    Joe
    Central Coast, CA
    The noise I am talking about is a friction material type noise. It's similar to a really bad brake squeal. It's not a throw out bearing, I own a six speed truck and I know what that sounds like.:mad:
  6. Nov 25, 2010 at 9:05 AM
    05RedTaco
    Tony
    Scottsdale
    Yes brake squeal describes that noise very well...
    I should have bought the desert sand mica 1st gen DC I test drove... :(
  7. Nov 26, 2010 at 12:07 AM
    island808
    Jedediah
    hawaii
    but brake squeel is not friction material... its metal... i guess theres some light squeeking associated with some brake pads.. high metal ones.
  8. Nov 26, 2010 at 3:33 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    I have a 2008 White Toyota Tacoma Regular Cab 2.7L 5speed like you with 74,000 miles and no clutch problems. The clutch should last at least 100k if driven properly.
  9. Nov 26, 2010 at 8:43 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Hey OP, it looks like you should still be under the 3/36K warranty. Time to take it it I think. Let us know what it turned out to be.
  10. Nov 26, 2010 at 9:22 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
