Screeching noise when on idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrnTaco08, Feb 12, 2017.
  1. Feb 12, 2017 at 10:52 AM
    KrnTaco08
    KrnTaco08 [OP] Well-Known Member
    LA
    2017 Taco
    Hi,
    My 2008 Tacoma with 170k plus miles makes a "screeching" high pitch noise when I start the truck in the mornings. The noise slowly goes away when the truck is been running for a few minutes.
    Could've be a belt issue? I have never replaced them since I bought my truck.
    Any answers will be greatly appreciated. Thank you.
  2. Feb 12, 2017 at 10:55 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like belt idler pulley's seizing up. Time to start replacing them
  3. Feb 12, 2017 at 10:57 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Sounds like a good time to replace your belt and check your idler pulley. Belt probably has a bit of a glaze.
  4. Feb 12, 2017 at 10:58 AM
    KrnTaco08
    LA
    2017 Taco
    Thank you. Are they pretty expensive to replace?
    Trying to get an idea before I take it to the shop.
  5. Feb 12, 2017 at 11:05 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    This. Belt most likely, but possible worn pulleys.
    A shop could do it in 5 minutes, but would still charge their minimum shop time so maybe 1/2 hour or 1 hour, plus cost of belt.
    Alternatively, a good serpentine belt should be under $30 and is an easy DIY if you'd like to try.
    Here's a video for replacement (also will help if you just want to pull it and do a visual check of things). At 170K it's likely aged. Do look up some videos on how to test the tensioner pulley to see if it's bad while you're in there.
    KrnTaco08[OP] likes this.
  6. Feb 12, 2017 at 11:25 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    this guy ^ right on the money
  7. Feb 12, 2017 at 12:07 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    I concur :thumbsup:
  8. Feb 12, 2017 at 12:36 PM
    KrnTaco08
    LA
    2017 Taco
    Awesome. Thank you for all the information and I will look into it. I'm glad I joined this forum.
    Appreciate all the replies.
  9. Feb 12, 2017 at 1:30 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Rock auto has some nice little kits that have all the pulleys and a belt for reasonable prices.
  10. Feb 12, 2017 at 3:15 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Not a big problem at all,170,000 miles is excellent for not having ever changed your belt,that's how good Tacoma's are.
  11. Jul 21, 2017 at 12:20 PM
    KrnTaco08
    LA
    2017 Taco
    I agree!
  12. Jul 21, 2017 at 12:30 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Very easy to change the belt.... release tension, swap belt, add tension. Done
  13. Jul 21, 2017 at 12:37 PM
    KrnTaco08
    LA
    2017 Taco
    That's good to hear. I'll be honest, working on vehicles is not my expertise :/
  14. Jul 21, 2017 at 4:35 PM
    TexasWhiteIce
    Texas
    Our trucks are very user friendly with repairs compared to most vehicles. It's really a case of making sure you have the right tools and not rushing
