Screeching sound when I turn steering wheel...
Discussion in 'Technical Chat' started by acmair, Apr 12, 2010.
  1. Apr 12, 2010 at 8:53 PM
    acmair
    acmair [OP] Well-Known Member
    Andrew
    '10 BSP PreRunner Dbl Cab Short Bed SR5
    I have two Corollas, with 108K and 190K miles. They both make horribly annoying screeching sounds when I turn the steering wheel. I added power steering fluid and it made it a little better temporarily. I know its not a Tacoma, but maybe the reason might be the same.
    Anyone know what the problem might be, or what the easiest way to fix it is?
    Thanks
  2. Apr 12, 2010 at 8:55 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    is it a belt screech? tighten up the belt or replace it.
  3. Apr 12, 2010 at 8:57 PM
    acmair
    Andrew
    It only happens when I turn the steering wheel. What connection does that have to any belt? I think the power steering pump is powered by the serpantine belt, but how would that matter?
    Could be though. I'll check it out! Any other suggestions?
  4. Apr 12, 2010 at 9:01 PM
    WhatThePho?
    Andre
    HCMC, VN
    2006 STi
    My belt screech when I go full lock on turning. Tightened it and it stopped. Now it screech when I start up.
  5. Apr 12, 2010 at 9:03 PM
    acmair
    Andrew
    Lol same! It used to screech when I turned all the way, now it screeches all the time. So I should check the tensioner i guess...
  6. Apr 12, 2010 at 10:36 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    your powersteering is possibly leaking, have you checked if your powersteering fluid has decreased when you added more?
    i know because my 04 accord had that problem, air getting into the ps hose
  7. Apr 12, 2010 at 10:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Belt issue. Had a 91 corolla. Sometimes did it at full lock. Always did it on start up when cold.
  8. Apr 14, 2010 at 4:29 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    X2 on it being a loose belt.
