Screeching/Squeaking sound during acceleration and deceleration.
Discussion in '1st Gen. Tacomas (1995-2004)' started by k2009c, Sep 29, 2022.
  1. Sep 29, 2022 at 11:17 AM
    k2009c
    k2009c [OP] Member
    2003 Silver Tacoma PreRunner Reg. Cab
    Have a 2003 regular cab PreRunner with automatic transmission and 120,000 miles on it. I am having an issue with a screeching/squeaking sound when I let off the accelerator at speeds over 45mph. This also happens when I push the accelerator through the 1st inch of pedal movement but then it goes away. Best way to reproduce is to accelerator to 65mph and then set cruise. It will screech/squeak the whole time, especially when weather is cold. Have replaced steering pump, A/C compressor, and alternator belts but still have noise. Any suggestions as to what this could be? Tried recording but could not get a good quality. Thanks in advance.
  2. Sep 30, 2022 at 12:26 AM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    Noise coming from engine area? Or under truck? Is the sound Rpm dependent, or vehicle speed dependent. Are the belts properly tightened and did you ever replace the idler pulleys?
  3. Oct 3, 2022 at 11:33 AM
    k2009c
    k2009c [OP] Member
    Hard to say. Sounds like engine area as it is more in front than underneath. Double checked that belts are tightened but have not replaced the idler pulleys. Going to start on those next to try and pin it down. Just curious if anyone else had the issue so as to point to the culprit. Thanks.
  4. Oct 3, 2022 at 1:56 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I had that happen. It ended up being the center support bearing (carrier bearing) on the drive line. The rubber gets really dry and starts to crack and split. Not sure if you still have the original one or not. But you can get under there and check the condition of it. If the rubber is trashed. Replace it.
  5. Oct 3, 2022 at 4:35 PM
    Duke_962
    Nwnj
    Does the noise change if you rev the engine in neutral or increase vehicle speed?
  6. Oct 3, 2022 at 4:56 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    How old is fan clutch.....that is one of those high wear items.
    And kinda expensive.....
    Noisiest thing on my truck......mind of its own....
    Fan goes out.....its bad......if you dont catch it....
  7. Oct 5, 2022 at 9:23 AM
    k2009c
    k2009c [OP] Member
    Thanks. Will take a look at both of these and see. I am pretty sure both are still original as previous owner did not do much to this truck.
  8. Jan 21, 2023 at 7:12 AM
    Jrod5k
    Jrod5k New Member
    Jerod
    Maryland
    07 Tacoma 4x4
    @k2009c Did you ever solve the issue ?
  9. Jan 21, 2023 at 8:49 AM
    O'Silver_Taco
    MD
  10. Jan 23, 2023 at 8:13 AM
    k2009c
    k2009c [OP] Member
    Nope still have issue. Fan clutch checked out ok and like stated above, one piece driveshaft so no carrier bearing. Going to get some fresh eyes and ears to take a look and see if they can pin point it.
  11. Jan 23, 2023 at 8:39 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    If you can't find any other cause or solution, try spraying belt dressing on the belts. If the noise lessens or goes away, it means that the belts are not properly tensioned.
