Screw Drivers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaCZman, Aug 15, 2024.
  1. Aug 16, 2024 at 11:04 AM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    To add on to the above.
    JIS drivers work on Phillips heads.
    Phillips drivers DO NOT work on JIS heads.
    So JIS has a lot more use then just on a vehicle. And they don't strip out Phillips heads, which Phillips drivers strip out Phillips heads as that is what the Phillips bits are designed to do to limit torque input.
    Not to say that JIS will save you from a rusty seized Phillips screw, but it is less likely to leave you needing a left hand drill bit.
    OldSchlPunk[QUOTED] likes this.
  2. Aug 16, 2024 at 11:39 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    I am extremely annoyed when the "backout drill bit" is needed ...
  3. Aug 16, 2024 at 2:17 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    That's right. Phillips will make a mess out of your screws.
    https://youtu.be/36DLtwJYSGs?si=FUQhaCIzvPSM4Fb3
  4. Aug 16, 2024 at 2:20 PM
    scocar
    scocar Patron of the Farts
    They heard about seat spacers, trying to retain their crash rating.
  5. Aug 16, 2024 at 2:59 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It actually was for a seat lowering kit. I don't need to pad my chair with phone books to sit at the big table.
  6. Aug 16, 2024 at 3:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    JIS for screws like the fuel door clip and fog lights.
    Medium flat blade screwdriver with thin shank for general prying and brake shoe adjustment. Also good for wheel hub dust cap removal (not applicable to 4x2).
    Pocket flat blade screwdriver for general prying (oil filter cap O-ring, oil drain plug gasket, electrical connectors and bulb sockets).
    Pocket Philips or JIS screwdriver for small electronic parts e.g. MAF sensor removal
  7. Aug 16, 2024 at 3:32 PM
    RichochetRabbit
    Not when your Mommy lifts you up into the chair with the tray. :D
  8. Aug 16, 2024 at 5:22 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    It still counts!
  9. Aug 16, 2024 at 8:38 PM
    CB350G
    CB350G Trust you inner Hobbes
    Western PA
    2023 SR Access Cab 3.5V6 A/T 4x4 MGM
    WTT: hood for skewp WTT: seats for util pkg
    TW keeps costing me money. First I’m out $3.99 for the LH screw driver, now it’s the Japanese screw drivers! When will it end? :rofl:
    CS_AR[QUOTED] and Brikan like this.
  10. Aug 16, 2024 at 8:54 PM
    RichochetRabbit
    Pooow widdwe baby ...
    MOD for a penny, MOD for a pound -- CB350G
