Screw from H E L L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoguy, Oct 28, 2009.
  1. Oct 28, 2009 at 9:52 PM
    Tacoguy
    Tacoguy [OP] Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    I was going to clean my MAF sensor tonight, however upon trying to remove the screws to access it, one of my screw heads got stripped. The one was easy to get to but the other one just would not be cooperative.
    Any suggestions on what to do?
  2. Oct 28, 2009 at 9:54 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Don't clean the MAF...lol
    I would not clean the MAF. Instead clean the throttle body. From what I have read the MAF has tiny wires that are brittle & can easily break & should never be touched. You can spray MAF cleaner on the sensor from the throttle body side on a 2nd gen Tacoma. That is what I did.
  3. Oct 28, 2009 at 9:55 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    pick up a tap and die kit at pep boys to get the screw out...
    i hate the MAF sensor screws too...
  4. Oct 28, 2009 at 9:57 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    oh, and on the gen 1 taco, you have to take the MAF sensor out to clean it...
    i clean mine every 20,000 miles
  5. Oct 28, 2009 at 10:06 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Stupid question.. MAF sensor. Maf stand for?
  6. Oct 28, 2009 at 10:15 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  7. Oct 28, 2009 at 10:19 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    MAF=mass airflow sensor
    Below is a DIY on how to properly clean it, along with the throttle body.
    http://4runners.org/writeups/throttle/index.html
    Be sure to use MAF cleaner for the MAF and don't use a Q-Tip to clean the wires in the sensor, damaging them would be a costly mistake.
  8. Oct 28, 2009 at 10:32 PM
    SACTOWN
    Greg
    Doh... Thanyou!!!!
  9. Oct 28, 2009 at 11:28 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    What kind of head is on it anyways, hex, phillips, flat head?
    In most cases if you have a Dremel tool you can put on a thin cutting wheel. Then you can make a diagonal cut so you can use a flat head screw driver.
    Just make sure to have a steady hand and make a nice cut, and be careful not to damage the MAF.
  10. Oct 29, 2009 at 3:01 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    How did you strip the head? Were you using a power drill? Those screws are pretty tough. I got mine out with a hand held screwdriver. Use the suggestion above and cut a slot in it with a dremel tool and use a flat head to remove the screw. Spray some penetrating oil on it first.
    Did you buy some MAF sensor cleaning spray? I got some from AutoZone that worked pretty good. My truck only had 65K miles, but was pretty dirty. You can definitely see a difference when you clean it. I saw a lot of gunk fall off after I sprayed it. Just be careful and do not touch any of the sensor wires with you fingers. Good luck.
