Screw in rear tire: Leave it in or take it out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stretch85, Mar 15, 2013.
  1. Mar 15, 2013 at 10:39 AM
    stretch85
    stretch85 [OP] Active Member
    Raleigh-Durham, NC
    2011 V6 4x4 TRD Sport
    My TPMS light went on the other day and I found that my right rear tire was down to 25 PSI. Checked for damage and found this little guy embedded in it. it appears to be a short wood screw with wide threading. I filled the tire back up to 30 PSI and it seems to be holding there even after driving around for a few days.
    So my question is: Should I pull it and try plugging the hole (never done it before), snip the head of the screw off so it's below the tread level to avoid further damage (which might make it much harder to remove in the future), or just leave it alone?
    Help me oh wise ones! :D
  2. Mar 15, 2013 at 10:40 AM
    dtmccray
    dtmccray Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Take it to tire shop have them patch it do not let them plug it.
  3. Mar 15, 2013 at 10:41 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'd pull it and plug it if it were me. I keep a plug kit under the rear seats though and am very familiar with how to do it. It's not hard, an auto or tire shop might even do it for you if you drove into one. Should only take them a couple minutes tops.
  4. Mar 15, 2013 at 10:43 AM
    Pugga
    Massachusetts
    What's wrong with plugging it? I'd throw a plug in that thing and never think twice about it. I realize the patches are better but don't see a problem with a plug in that case.
  5. Mar 15, 2013 at 10:45 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    I've had this happen before take it to a tire shop you trust and have them check it iv'e been lucky and mine have all ways been on the tread not in between. It would suck if you pull it out or mess with it and it goes flat. You could take some soapy water and spray it on there and lightly wiggle the screw to see if it bubbles if not you maybe safe to pull it out. It really comes down to you.
  6. Mar 15, 2013 at 10:46 AM
    BigHeadTaco
    BigHeadTaco GFY
    Big Head
    Full OME lift 885's with Dakar leaf springs. LR UCA's. ImMrYo relocation bracket.
    patch with bubble gum
  7. Mar 15, 2013 at 10:46 AM
    dtmccray
    millbrook alabama
    01 money pit
    Plugs can cause more damage if you don't know how to use them. I consider plugs a temporary fix and it doesn't cost much to have it patched.
  8. Mar 15, 2013 at 10:47 AM
    aaronbuell
    aaron
    windsor NY
    I've had lots of tires plugged too whats wrong with that?
  9. Mar 15, 2013 at 10:50 AM
    Pugga
    Massachusetts
    If you really butcher it, or the hole is too large, it can lead to belt separation if I'm not mistaken. A small hole like that from a nail I wouldn't think would be a problem. To each their own but I wouldn't hesitate to throw a plug in there :notsure:
  10. Mar 15, 2013 at 10:50 AM
    dtmccray
    millbrook alabama
    01 money pit
    Any time you jam a rough file between the steel wires in your tire you damage them not much but damage is damage. I have used plugs when I needed to but given the choice patch it.
  11. Mar 15, 2013 at 10:56 AM
    Watari06V6
    Watari06V6 Faster than a speeding ticket
    Wounded Knee
    TRD-V6-SR5-06
    just plug her already geeezz
  12. Mar 15, 2013 at 10:56 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I always end up plugging holes. It usually works. My former boss got a great big bolt put through his rear passenger tire like 8 months ago, and it's still there. Never had a problem with it. :D
  13. Mar 15, 2013 at 10:57 AM
    Pugga
    Massachusetts
    Ever see those plug/patch combos? They seem like the best route for longevity but I've never used them. They have a patch, then a plug thing sticking out from the middle so you force that through from the inside. The plug seals the hole and the patch is like added security.
  14. Mar 15, 2013 at 10:57 AM
    stretch85
    Raleigh-Durham, NC
    Thanks guys! I'll probably play it safe and have a shop patch it for me later today or tomorrow since it's not an immediate concern. What's a fair price do you think?
  15. Mar 15, 2013 at 10:57 AM
    wareagle1
    wareagle1 Well-Known Member
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    These are what we used back when I worked at a tire shop. Best of both worlds.
  16. Mar 15, 2013 at 10:58 AM
    wareagle1
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
    $10 or less.
  17. Mar 15, 2013 at 10:58 AM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    Find the dirtiest, most hole-in-the-wall ghetto-ass tire shop you can and take it there and let them put a patch on it for $5.00.
    +10 points if they are ghetto enough to take beer as payment.
    Seriously though a plug should be fine for a while but keep an eye on it. Technically a plug is doing the same thing as the screw but softer material...:rolleyes:
  18. Mar 15, 2013 at 11:00 AM
    C O R E
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    OOP!
    Giggity.... Allllllright.
  19. Mar 15, 2013 at 11:01 AM
    RickG
    RickG It seemed like a good idea at the time...
    Southern NH
    2010 SR5 4x4 Pyrite Mica
    Color matched grille, Access tonneau, OEM Temp/compass, De-badged, OEM hitch, Custom rear storage/dog deck, LED foot well lighting, Illuminated 4x4 switch
    If the tire has some miles on it already go ahead and plug it (...learn how first though). Yes, you will be making that tiny screw hole bigger, but you'll probably throw the tire out before there's a problem. If the tire is new, or almost so, I'd dismount it and do a proper patch.
  20. Mar 15, 2013 at 11:07 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
