Screw in rear tire: Leave it in or take it out?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stretch85, Mar 15, 2013.
  1. Mar 15, 2013 at 11:11 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Are you saying you successfully plugged your boss' big hole?
  2. Mar 15, 2013 at 11:11 AM
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    A true repair will use a patch plug combo as pictured in this thread. The issue with a plug is you have no idea what damage accured with in the tire which can lead to a blow out down the road. The tire needs to be broken down and inspected to insure no damage was done to the inner liner. A true repair will seal the injury as well as the inner liner which is why the patch plug combo is ideal.
    Here's what can happen when a repair is done incorrectly.
    http://www.utsandiego.com/news/2011/jan/11/jury-awards-144-million-wrongful-death-lawsuit/
  3. Mar 15, 2013 at 11:44 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Plug and patch as per Tripps2012's post is the proper way. The patch seals the air in, the plug is soft rubber that seals the carcass against water and dirt. Procedure is to locate leak, mark, mark location of valve stem and any balance weight on the side wall of the tire, dismount the tire, probe hole to make sure everything is out of the puncture and determine the entry angle, clean a large area on the inner tir around the puncture with the proper cleaner, a plug is inserted from the outside in following the entry angle with a liberal amount of "glue",the excess plug is snipped off at both ends, the inside buffed to flush out the plug and provide a clean and rough surface, glue applied and allowed to dry, care needs to be taken buffing as the inner liners are not very thick and buffing into the cords is not a good thing, the patch is applied centered on hole and rolled with serrated wheel tool thingy taking care that the edges of the patch are well adhered, tire is mounted aligning stem with side wall mark, original location of balance weights is verified, inflated, repair checked, marks on side wall removed.
    Slow day, crappy weather, BluTaco has emptied my farkles account.
  4. Mar 15, 2013 at 11:58 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    plug it.. been using plugs for many years without a failure
  5. Mar 15, 2013 at 1:27 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    That sounds wrong, haha. :D
    No, he left the bolt there and it's been fine. Because the bolt was so big, he didn't want to take it out.
    Btw, I like your avatar pic, Tripps2012. :D
  6. Mar 15, 2013 at 3:36 PM
    Skinny Rogers
    Skinny Rogers U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    Have done both and had no probs with either.
  7. Mar 15, 2013 at 4:39 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That is signature worthy right there! :D
