Screw in tire...ok just to patch?
Discussion in 'General Tacoma Talk' started by EmanC19, Dec 11, 2019.
  1. Dec 11, 2019 at 10:18 AM
    HyTrojan
    HyTrojan Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    Toyota says this is normal
    boston23 likes this.
  2. Dec 11, 2019 at 10:21 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    if you buy the tires from them thats kind of the deal.
  3. Dec 11, 2019 at 11:27 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    First thing is to check to see if it punctured the tire as already mentioned. Places Discount, Costco, etc. won't fist it because they will say that it is in the shoulder which is nonsense. Don't use a plug. They are a temporary fix. You need to have it patched from the inside. Find a mom and pop place like a used tire dealer and have them patch it from the inside. That is the best way to fix it.
    outlawtacoma and MoneyMan55 like this.
  4. Dec 11, 2019 at 11:28 AM
    EmanC19
    EmanC19 [OP] Well-Known Member
    San Diego, CA
    2018 Tacoma TRD Sport
    Thanks for the replies and tips. My last car, also had 2 screws in each passenger rear tire. Talk about bad luck
  5. Dec 11, 2019 at 11:34 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    @EmanC19 you gonna sell them wheels??
  6. Dec 11, 2019 at 11:56 AM
    oruacat2
    oruacat2 Well-Known Member
    Kenny
    Bluegrass Country
    2017 white Tacoma TRD Offroad
    none yet
    They're the same GoodYear tires that came new on the truck when I bought it two years ago from the dealership.
    I bought tires from that specific shop in 2012 or so for a previous vehicle, so maybe they're just trying to retain me as a customer.
  7. Dec 11, 2019 at 12:10 PM
    MikeyD.25
    MikeyD.25 Well-Known Member
    That's not bad luck - that's vandalism. Screws don't just screw into tires without some sort of help. :crapstorm:
  8. Dec 11, 2019 at 12:14 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    The correct patching method is a rubber plug in the hole and patch on the inside. Never seen a mom and pop place do it correctly before.
    Boghog1 and MikeyD.25 like this.
  9. Dec 11, 2019 at 1:02 PM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    i had a small rock in between my tread, but did not get a pic of it, i drove 100 mph,, and it came out.. so no need for pic
  10. Dec 11, 2019 at 3:13 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  11. Dec 12, 2019 at 5:11 AM
    Sungod
    St Augustine
    The patch/plug is the industry standard. Unless it is a bike shop, you won't see flat patches.
    When I say mom and pop, I am referring to non chain repair shops that do tires. This includes the used tire guys. However, if the shop doesn't have tire mounting equipment, they can't properly repair tires and will probably slap in a plug and tell you to go somewhere else to get it fixed.
    Amanelot[QUOTED] likes this.
  12. Dec 12, 2019 at 5:45 AM
    Amanelot
    Amanelot Member
    Texas
    https://youtu.be/mdTAalpkSLM
    https://www.tireindustry.org/tire-maintenance/tire-repair
    Industry standard is separate plug and patch.
    My opinion: It's too easy to get a improper flush seat on the combo patch to be considered reliable. Although, TIA doesn't directly state that they cant be used.
    bigmw likes this.
  13. Dec 12, 2019 at 6:12 AM
    Sungod
    St Augustine
    The industry standard is the patch/plug. While the separate plug with to fill the hole is good in concept, it is a not a common repair. Outside of Michelin training, I can't remember ever seeing shop performing that type of repair. I don't even know of a vendor that you can buy those types of supplies.
    I know what you are saying about the risk of getting it to seat with the patch/plug, but the only time you see problems are with someone that doesn't know what they are doing. It isn't fool proof and if you have a fool doing the repair, it is bound to fail.
    One thing funny about the video is that it shows a guy using a cordless drill to ream the hole. That is a huge no-no. Get some wire wrapped around that bit and the tire is destroyed.
    ColoradoTJ likes this.
  14. Dec 12, 2019 at 6:27 AM
    Amanelot
    Amanelot Member
    Texas
    Agree or not, TIA is the standard. And it is what OSHA uses when inspecting/writing citations. Any tire supply vendor worth anything will be able to source rubber plugs. It's not as uncommon as you think
  15. Dec 12, 2019 at 8:20 AM
    #35
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Shops wont touch your tire if the nail/screw is in the sidewall.
    You are fine. 5 min at the shop
    TimC likes this.
  16. Dec 12, 2019 at 10:54 AM
    #36
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    10 bucks at Walmart and you are on your way.
  17. Dec 12, 2019 at 11:04 AM
    #37
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Add more screws. Enjoy the winter traction.
    BlkTaco47 likes this.
  18. Dec 12, 2019 at 11:09 AM
    #38
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    Probably totalled, sorry :/
  19. Dec 12, 2019 at 11:17 AM
    #39
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I am also still on the OEM Goodyears, 47K miles on them now. I have one tire that now has had 3 screws/nails/whatever puncture it. I took it into a local tire shop recently, the guy told me he can't patch it because CA has a tread depth minimum on 1/4", and mine are less than that, so he tried to convince me I need a whol enew set of tires. Fortunately for me, the tire currently has only a slow leak, I only need to fill it up a couple times a week. It's going to be a long time before I can afford a new set of tires :(
    BillsSR5 likes this.
  20. Dec 12, 2019 at 11:22 AM
    #40
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    I had the same thing happen to my wifes car and my last truck a few years ago. Nails or screws in about the same place on both. The big chains wouldnt fix it because they both claimed that if it was within 1 inch of the side wall they wouldnt fix it. Went to the local small independent tire shop and they fixed both of them with plugs with no problem at all and they lasted for a few years, no leakage at all, until I sold both vehicles. When I was younger, I worked at a very busy gas station and probably fixed hundreds of tires with plugs and had very few people return claiming leaks. If you do plan on checking that screw for leaks, dont remove it, just wiggle it around while checking for soapy water and slowly pull on it while checking. Dont just yank it out. If you dont initially get any soapy bubbles slowly pull it out while checking. Hopefully its just a short screw. If it is leaking, whoever plugs it will want to have the screw in there to find its path when removing it so they can put the plug in the same path.
