Screw this Forum! (Lift Kits)
Discussion in 'Suspension' started by JRod4928, Aug 17, 2012.
  1. Aug 17, 2012 at 5:53 AM
    JRod4928
    JRod4928 [OP] Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    For making me spend my money!
    Day 0 - When I first saw lift kits on toytec I thought I could get a lift for less than 250-300 dollars (spacers).
    Day 1 - Spacer lifts are the devil
    Day 2 - I need 5100's with stock coils (preloaded) or OME springs set at 0" with AAL.
    Day 3 - Understood the advantages to OME coils...I need at least 700 dollars for new coilovers and AAL to do the job right.
    Day 5 - Realized that rear AAL may be stiffer ride than I'd like, so... started researching new leaf packs
    Day 7 - Considering a new leaf pack and realizing that I'm going to have to spend 1000+ for a quality lift kit, new coilovers and new leaf pack in the back for the best ride quality. (Hoping I won't need UCAs as well)
    Future - Realized I need tips to convince the wife that 2.5" is worth 1000+ dollars.... (Christmas Bonus?) and that spending 4x the amount I thought we'd spend in the beginning is somehow OK :D
    Seriously though - I'm convinced that my plan for the front suspension will provide a good ride. BUT, I'm concerned that AAL will be a stiff ride. Are Dakar leaf packs > OME shocks with 1.5" AAL (or Billy's with 1.5" AAL)? Is it worth the extra 300 dollars for smoother ride on 99.9% highway driving?
  2. Aug 17, 2012 at 6:00 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I don't do much off-roading, and only haul things once in a while. My main concern is preserving a 'near stock' feel of the truck when there is no load in the bed. I don't have plans to add a winch, cap, tool box, etc. in the back. Only a tonneau and maybe a bed extender
  3. Aug 17, 2012 at 6:01 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    sold everything
    So this is day 8? Dont forget about ucas... hahaha.
  4. Aug 17, 2012 at 6:06 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    That's right, haha.
    Yeah I want 2.5" of lift to avoid UCAs.... I'm hoping OME shocks or Billy's set at 0" with 885 coils without the top spacer will give me 2.5"
    REALLY don't want to get UCAs unless I need to
  5. Aug 17, 2012 at 6:13 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I've learned that if you work in "safety" or a variation of the word when discussing a major purchase with the wife it is easier to get her to agree to the purchase. Recently I have purchased a new helmet for use when riding my road bike that was $255. I mentioned that I needed it due to my concerns for "safety" which was true in this case. I then purchased new tires for my mountain bike. I had wrecked earlier in the week and I mentioned to my wife that new tires would make me feel "more safe" when riding the trails.
    Try this when discussing your lift purchase.
  6. Aug 17, 2012 at 6:18 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    I feel safer knowing that my tacoma looks cooler than other tacomas...think she'll buy it?
  7. Aug 17, 2012 at 6:19 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Day 8 - Lift kit installed, can't get proper alignment
    Day 9 - Find out I really do need UCA's, join group buy for LR UCA's and spent another $375.
    It's a long known and proven fact. Join TW = Spend lots of $$ on things you never knew you needed
  8. Aug 17, 2012 at 6:20 AM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    LOL! Good Luck :D
  9. Aug 17, 2012 at 6:21 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
  10. Aug 17, 2012 at 6:22 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You should be able to avoid aftermarket UCA's with a 2.5" lift. ;) Running stock wheels and tires?
    The single AAL should ride just fine especially on pavement. I've had a single AAL since 2008 and I never had any rough riding issues.
  11. Aug 17, 2012 at 6:23 AM
    Pugga
    Massachusetts
    F-150 Mod
    Yep, that's why I stayed under 2" of lift :D
  12. Aug 17, 2012 at 6:27 AM
    Day Cowboy
    Day Cowboy Well-Known Member
    Day Cowboy
    MS
    2011 Tacoma TX TRD 4x4
    AFE Pro Dry Air Filter, Toytec Ultimate 3' Lift, LR UCAs, WeatherTech Floorliners, Wet Okole Seat Covers
    IMO, the adjustable Bilsteins from Toytec will be fine.
    Unless you will be hauling alot, the AAL would be your best option. New leaf packs can be as stiff/stiffer than AAL.
    And with all that, you have only spent $320 (Front adjustable shocks, nuts/bolts, and rear AAL.) Even if you only adjust for an inch of lift, it is still enough to clear a little larger tire than stock. Since you won't haul much and don't do much offroading, it will suffice for your needs (Looks only).
  13. Aug 17, 2012 at 6:28 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Plan is to run 32.5" tires - maybe on 18's, or 17's not sure. Good to hear about AAL...i'm thinking of getting AAL and IF ride is poor, buy leaf packs - AAL is only 80 bucks instead of 400 for leafs
    I MAY shoot for 2.5, and hope it all works out. (don't install the top plate spacer). If I need UCAs even with 2.5", I'll just say screw it, buy the UCA's and put the top plate spacer in to get 3" lift.
    *Crosses fingers*
  14. Aug 17, 2012 at 6:33 AM
    Pugga
    Massachusetts
    F-150 Mod
    An another note, obviously a replacement leaf pack would be your best option but, since you have a nice, new 2012, an AAL would probably be more than sufficient. When I upgraded, I found someone selling a new TSB leaf pack, inserted an AAL into the leaf pack and have been running it for about 1.5 years. They haven't sagged a bit, the ride is great and it was a lot less expensive than a leaf pack replacement. I'm using the Icon 3-leaf progressive AAL and have been very happy with the results. The AAL gives you 1.5" of lift without the overload leaf, 2" with the overload kept in place. The AAL is around $185 and comes with new U bolts.
  15. Aug 17, 2012 at 6:37 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    You're right, I could probably get by with that...
    however, I'd like to get rear shocks to avoid over-extending the stock rear shocks in the event that I do top out.
    And front coils are optional, but from what I've read, they seem worth it. Pre-loading the stock coil results in less up-travel - so i don't want to be bottoming out all the time in the front either.
    That's where the extra $$ comes in, I'd like to do this right the first time :cool:
  16. Aug 17, 2012 at 6:40 AM
    Day Cowboy
    Day Cowboy
    MS
    Pugga is right. The AAL is going to be your best option and I think you will be pleased with it. On my above mentioned price, that didn't include new U-bolts ($69). Still puts you only being out of pocket $400. Plus, if my memory is correct, your truck should have come with 17" wheels right? Lots of options there with that size (paint stock wheels, new wheels, or leave stock). I was satisfied with my stock TRD wheels as no one around me has them.
    "You're right, I could probably get by with that...
    That's where the extra $$ comes in, I'd like to do this right the first time :cool:"
    I would go with OME then. But the adjustable Bilsteins would be fine for a mall crawler.
  17. Aug 17, 2012 at 6:47 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Very interesting...I'll have to look into this - I'm intrigued. :D
  18. Aug 17, 2012 at 6:48 AM
    Day Cowboy
    Day Cowboy
    MS
    :D
  19. Aug 17, 2012 at 6:48 AM
    BOONDOCKSAINT
    BOONDOCKSAINT Well-Known Member
    Central Louisiana
    WHITE 2016 DC OFF ROAD 4X4
    That's funny as Hell. Maybe because I'm experiencing the same thing. I started out only wanting to level out the front end, my thinking I need spacer's read post after post that they are junk get billy's 5100 (me what the Hell are billy's). Learned about billys, but now you need after market coils not to preload and aal if you do that to avoid the bro lean. (Me preload, aal, bro lean WTF! I just want my front end level didn't know I was going to need a language class in addition.) Start learning all the terminology billy's, eibach, OME, aal, and uca's and start to realise that what started out as me just trying to get a look for aesthetic reasons that may cost me $200 is now closer to $900. All I do is read myself into circles on this site when all I want is my truck level. (Me F it stock it is) or until a read another post or get a suggestion and change my mind............again :-/
  20. Aug 17, 2012 at 6:52 AM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    Is there a discount available at DSM or Toytec?
