Screwed Up My First HID Adventure BAAAAADDDD...!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, Nov 13, 2009.
  1. Nov 13, 2009 at 10:36 PM
    memario1214
    memario1214 [OP] Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    OKay, so I was given a set of Xentec HID's as a gift and I know they aren't known as the best out there, but it looked legit so I figured I would give it a shot... I hooked them all up and the only thing I am getting when I try and turn on my lights is that the far right orange light turns on!!! I apparently messed up something big time, but I can't figure out what it is...:confused: What are the three wires going into the original bulb connector? Maybe I have those mixed up? I dunno... Any help here would be exceptional...
    I posted pictures up about two posts down...
  2. Nov 13, 2009 at 10:43 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    The headlight connector has 3 wires ground, hot for low beams and a hot for high beams couldnt tell you which is which without looking
  3. Nov 14, 2009 at 7:29 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
  4. Nov 14, 2009 at 7:32 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Pics! Pics! Pics! Pics! Pics!
  5. Nov 14, 2009 at 8:01 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    im not sure what the hid box on yours looks like but one of the plugs that goes into the box on mine will go in either way.. and if it is upside down then it will not work.. lets see some pictures and maybe somebody can help you out some more
  6. Nov 14, 2009 at 8:22 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    also check your fuses.
  7. Nov 14, 2009 at 1:32 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Okay you photo whores :p, hese's what I'm looking at...
    The stock plug that goes into the halogen bulb...
    Rear view of plug with cover removed to see where wires go...
    Plug-in that came with HID set that is supposed to hook into stock plug...
    The two wires that go into the black box up there...
    Alright, that's what I got, tell me what you know. Hopefully someone can help me out here!!! As far as the rest... It is completely plug-and-play, so I'm pretty sure I didn't screw that up...
  8. Nov 14, 2009 at 1:40 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
  9. Nov 14, 2009 at 2:54 PM
    Taco Ron
    Taco Ron Male Member
    What do you mean "the two wires that go into the black box up there"?
    Do you have instructions? Are those power and ground? Is it a high/low kit or just low beams?
  10. Nov 14, 2009 at 4:05 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Yeah, good call Ron. I went into this project sight unseen... These are in fact lows only. I just ripped the whole shebang out, and I am ordering on Slimcubby's group buy tonight...!
  11. Nov 14, 2009 at 4:18 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You think thats bad? You should've seen what happened when I attempted the BHLM :laugh:
  12. Nov 14, 2009 at 4:31 PM
    Taco Ron
    My experience with a simple low only kit is that you plug the balast into the factory bulb harness then plug the ballast into the HID bulb. Did they come with instructions to say what the other two leads are for? I'm assuming power and ground . . .
  13. Nov 15, 2009 at 9:25 AM
    dktaco
    Josh
    +1 do as mentioned and see what happens!
  14. Nov 16, 2009 at 7:36 AM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Yeah, it's power and ground. When I got them, I called the company they came from to make sure they were hi/lows since I knew nothing about HID's and I got them as a gift. They told me yes, they were hi/lows and so I took their word for it and figured I would have to find some way to ground it... Through trial and error I found they are lows only... Feck
