Screwing into a Snugtop interior
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loretta, Jul 12, 2022.
  1. Jul 12, 2022 at 4:51 PM
    Loretta
    Loretta [OP] Well-Known Member
    Joey
    2016 Tacoma Double Cab Long Bed
    Hey All,
    I'm hoping to put some curtains on the inside of my snugtop. I'd love to just put a couple screws in to hold a length of bungee that the curtain would hang on. Does anyone have any experience screwing into a fiberglass top? Anyone know how thick they are? Will screwing a self tap screw into fiberglass cause any significant damage? Is there a chance it'll crack?
    I'm hoping to just put a very short screw in that won't go all the way through but will go in far enough to hold the weight of a curtain.
    Anyone done this?
    thanks!!!!
  2. Jul 12, 2022 at 4:52 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lured by title. Disappoint
  3. Jul 12, 2022 at 4:54 PM
    tcjacado
    tcjacado Well-Known Member
    The shell is super thin. Might want to think about some 3m products that are peel and stick or get that stuff called "alien tape".
    OldGregg and Gen3TacomaOBX like this.
  4. Jul 12, 2022 at 5:31 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I wouldn't attempt to screw into the fiberglass.
    If the interior is exposed fiberglass, I'd try roughing up the surface and using something like this:
    https://www.mcmaster.com/adhesive-mount-studs/ with a heavy-duty epoxy.
    If the interior is carpet, I'd try using the hook side of hook'n'loop (velcro) sewn onto the top edge (and maybe bottom also) of your curtain.
    Gen3TacomaOBX likes this.
  5. Jul 12, 2022 at 5:38 PM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    Do not tap screws into your top. I use 3m products but I put a little dab of gorilla glue to Make sure they stay put. I used that set up on my old truck top for 10 years and never had one fall.
    Steves104x4 and Gen3TacomaOBX like this.
  6. Jul 12, 2022 at 5:57 PM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    Do not puncture your fiberglass!
  7. Jul 12, 2022 at 6:00 PM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Jul 12, 2022 at 6:07 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    @CT Yankee said it. If you have the raw fiberglass interior (no carpeting/headliner inside your shell) then you should sand (to rough the surface slightly) and epoxy (or even glue) in the attach points.
    Hanging window covering is NOT a reason to penetrate the fiberglass shell. I have plenty of experience working with fiberglass boats and trailers and "screwing" into fiberglass is rarely a thing. Perhaps pre-drilling a pilot hole, drilling a final size hole then using a bolt, washer and nut with appropriate sealant or rubber gasket washer (if waterproofing is required) BUT that isn't appropriate for your drapes.
    Steves104x4 likes this.
  9. Jul 14, 2022 at 8:18 PM
    3rdGenJen
    3rdGenJen Well-Known Member
    2021 Cement Gray TRD OffRoad Access cab
    Snugtop Rebel, Rek Gen mudflaps, FM transmitter for Sony CD player
    Another option: if you have the carpeted headliner, you can use velcro/hook and loop stuff to stick things to that headliner. I got some doublesided hook and loop tape and glued it onto some items for use when sleeping in the bed, like a small lantern, small plastic box to hold crap, even my fishing rods. You could sew on or just use fabric glue to put some of that on curtains. No need for a curtain rod.
  10. Jul 21, 2022 at 4:02 PM
    Loretta
    Joey
    Found someone who used the existing window hardware to mount small curtain rods and am going to do that! thanks yall
    joey
  11. Jul 22, 2022 at 5:52 PM
    spp
    spp OC, Kalifornia
    OC California
    I once in 1983 made privacy curtains for my Stockland shell on my 1983 Toyota PU that snapped in place.
    Took cloth with male shap on it and used epoxy to fix it in place. After 7 years they still worked.
    If you have the carpet lined SnugTop as I do Velcro can be an easy quick solution.
