Screws in Bed Side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jackassmcpunk, Mar 9, 2012.
  1. Mar 9, 2012 at 9:52 AM
    jackassmcpunk
    jackassmcpunk [OP] Active Member
    Patrick
    Boston
    Hey Everyone,
    I want to add some light duty tie-downs onto the side of the composite bed. What are the best type of screws to go into the plastic?
    Thanks!
  2. Mar 9, 2012 at 9:54 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    IMO I would not use screws. I would drill it out, use wide washers or something else behind the bed to displace the weight, and then use small bolts.
    Once you crack the bed it's fubar.
  3. Mar 9, 2012 at 9:55 AM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    07 sport, ARB rear locker, leveling kit
    ARB rear locker Leveling Kit Custom Rear Bumper Tires and Rims Air tank fully plumbed into truck
    I would use bolts with some big fender washers behind them, you want to spread the load out as much as possible.
    Screws won't last very long and will eventually pull out.
  4. Mar 9, 2012 at 9:56 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Buy some actual bolts with nuts and washers to alleviate any chance of them just pulling out... Just my thoughts.
    And BTW the bed is a composite not platstic
  5. Mar 9, 2012 at 9:57 AM
    nfs257
    Beat me to it... LOL
