SCS F5 wheels 16x8, 17x8.5, & 17x9
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Jul 21, 2012.
  1. Nov 27, 2018 at 4:48 PM
    #3561
    ChadsPride
    Sponsored by TacomaWorld.com
    Rustoleum 2 in 1 paint primer. Just a semi gloss (I know it looks pretty glossy)
    We were rotating my tires and it was a good time to knock it out.
    Just about 5 minutes prep per wheel (don't really need to sand it down totally bare but always could if you wanted to)
    aiir_iik[QUOTED] likes this.
  2. Nov 28, 2018 at 11:28 AM
    #3562
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Just ordered a set of 16/4.5BS/0 offsets! TRD Tacoma Pro 16" wheels will be for sale once these are on! How are these wheels with moderate off road? I know they are light but strong. Has anyone taken them off road with solid results?
    ChadsPride likes this.
  3. Nov 28, 2018 at 11:58 AM
    #3563
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    @hoarder23 beats on them like a red headed step child and they haven’t folded on him
    ChadsPride and ejewels[QUOTED] like this.
  4. Nov 28, 2018 at 12:00 PM
    #3564
    ejewels
    CT
    So my trd tacoma pro wheels are 16x7, +13 offset. These f5s are 16x8. Does that mean they will be an 1" thicker, but also the diameter will be slightly smaller lessening my lift from tires? Also, since these stick out a bit further than my pro wheels, the thickness shouldn't matter in terms of coming too close to the internals like my JBA UCAs? Because there is more offset?
    In other words:
    Current TRD Tacoma Pro Wheels: 16x7 / 13 offset / BS unknown
    F5s: 16x8 / 0 offset / 4.5BS
    Wouldn't this mean that even though I gain an inch in width, its now pushed out a half inch further so the distance to the internals like the UCAs will be about the same?
  5. Nov 30, 2018 at 1:36 PM
    #3565
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Sand on matte black on (quick)sand
    ChadsPride, scs_vuth and KaptainH like this.
  6. Dec 2, 2018 at 6:40 AM
    #3566
    1977
    1977 Tacoliscious
    Newman
    Coloradical
    02 TRD XC
    Black Rhino • Bilstein • OME • Falken
    16 x 8, 3.5 bs on a 265/75. So glad I did the 3.5", lift is 5100's, 887's, JBA and ECGS up front, Ikon 3 Leaf Progressive AAL rear with 3º Shims. Rides like butta!
    It's an '18 and came with dust caps up front.
    Just got it sorted, need to get some better pics.
    Moto5 and ChadsPride like this.
  7. Dec 2, 2018 at 1:08 PM
    #3567
    steveng
    steveng Active Member
    steven
    Blue Tacoma Off-road 2017
    47BD7DCC-28AF-4669-AA77-A40F852AFFE3.jpg Finally got my wheels and tires mounted up! Had to remove front mud flaps and still have rubbing on front fender and a little on cab mount on full flex. Have an icon stage 4 coming in from wheelers so hopefully that fixes some of the rubbing. Still have to do alignment as well, but stoked on the new combo! Mahalo to everyone on here for helping. Tires-ST MAXX 265-75-16 and 3.5 BS F5
    637A690F-1EF9-47AD-9719-3AF6804E7271.jpg FFD4EED7-27EA-4AEC-969D-9A54DE7E0059.jpg Also ended up with the same problem as some others I saw with scratches when being balanced at the shop. Was pretty bummed but can’t really tell until you get close. Anybody have any tips on how to cover them up?D44FD409-C014-4CDA-B0D0-AAA58847AB18.jpg
    Beef Nachos and ChadsPride like this.
  8. Dec 2, 2018 at 7:37 PM
    #3568
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Get ready for some trimming!
  9. Dec 2, 2018 at 9:31 PM
    #3569
    kevjitzoo
    kevjitzoo Well-Known Member
    Kevin
    Seattle, WA
    2019 Toyota Tacoma TRD Offroad
    Will 16x8 3.5bs F5's have any rubbing issues with 265/75 16 on a Stock 3rd Gen Tacoma OR?
  10. Dec 2, 2018 at 9:48 PM
    #3570
    steveng
    steven
    Check my last post above. My setup is currently stock
  11. Dec 2, 2018 at 9:49 PM
    #3571
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
    You can ask them next time to pin plate your wheel on the balance.. that will never happen again.
  12. Dec 2, 2018 at 9:51 PM
    #3572
    steveng
    steven
    Thanks! Scratches aren’t too bad but still sucks that all 4 were scratched before they were even on the truck. I told them to be careful when balancing so it doesn’t scratch but they said it has never happened before . Gonna try cover it up with some black epoxy or paint
  13. Dec 2, 2018 at 9:58 PM
    #3573
    dc2’s
    California
    Added a driver
    Yes they were careless.. Sorry man.. you should ask the SCS if they have touch up paint.
  14. Dec 4, 2018 at 7:06 PM
    #3574
    thelate1
    thelate1 Well-Known Member
    PA
    2013 DCLB Sport 4x4
    Regarding center caps for the F5’s...
    I’m curious if anyone can confirm that the brushed w/ red TRD lettered caps fit diameter wise? I’m contemplating machining a groove in mine to fit a cap of some sort.
  15. Dec 4, 2018 at 7:25 PM
    #3575
    12tackoma
    12tackoma Member
    2012 Tacoma trd
    Total Chaos Uca Bilstein 6112 with toytec top mounts at 3" 285 70 17 duratracs
    Sharpie it
  16. Dec 4, 2018 at 8:07 PM
    #3576
    1977
    1977 Tacoliscious
    Newman
    Coloradical
    02 TRD XC
    I work at a dealership and was standing there with my tech when he mounted my tires, we don't have a 6 lug pin plate so we had to use the center ring. After explaining to him the wheels were easy to scratch on the balancing machine, he proceeded to lift it up and set it down right on the thread post of the balancer and guess what? He scratched it! Super small but I suspect that's how it's happening, they are heavy so when the techs lift it onto the machine, they first rest it on the threads before moving it into position. Needless to say, he didn't scratch the other three. By the looks of the pic above, the same thing happened here.
  17. Dec 4, 2018 at 11:19 PM
    #3577
    dc2’s
    California
    Added a driver
    I been a tech for more then 15 years now and yes I do understand about the wheels being heavy because of the tire size.. but there is always a back or front cone/collet that holds the wheel in place and slides on the threaded shaft therefore If the tech just sat the wheel down on the shaft prior to pushing the wheel to the back of the faceplate of the balancer then that was the technicians bad for not setting the wheel on the cone prior to pushing the wheel back and securing it with the lock hub nut.
  18. Dec 5, 2018 at 5:53 AM
    #3578
    1977
    1977 Tacoliscious
    Newman
    Coloradical
    02 TRD XC
    Yeah, that’s why he didn’t do it on the next 3, lol. If you do it with a wheel that has a center cap, likely not issue with most wheels, especially OEM because the finish is more durable. With The F5, a little extra precaution is required by the installer.
  19. Dec 7, 2018 at 9:45 PM
    #3579
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
    F5’s with Cooper AT3 XLT’s in 295/75r16. Really digging these wheels! 183FDCF8-8E09-4EED-955C-8EC29FCCE07A.jpg
    nixpnw, thebaker, ChadsPride and 2 others like this.
  20. Dec 8, 2018 at 5:57 PM
    #3580
    TrailYeti
    Portland, Oregon
    Replaced the black SCS decals with white to add a little contrast.
    Working with SCS has been a great experience. I had no issue with availability, they offer a quality product at a relatively good price price, have super fast shipping and excellent customer service.
    I sent Vuth an email inquiring about these white decals after I received the wheels and he sent them out same day at zero cost to me.
    Montanahunter and ChadsPride like this.
