SCS F5 wheels 16x8, 17x8.5, & 17x9
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Jul 21, 2012.
  1. Jun 14, 2019 at 5:17 AM
    #3841
    BOMBS
    BOMBS Well-Known Member
    2017 Black Tacoma TRD Off Road
  2. Jun 14, 2019 at 6:44 PM
    #3842
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
  3. Jun 14, 2019 at 6:46 PM
    #3843
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    F5s cuz of the Aisin hubs
  4. Jun 14, 2019 at 6:53 PM
    #3844
    90yota
    88 T4R / 15 F350
    Stock....ish
    True. I almost got another set of ray10s but then I would have had to have them bored out to fit over the hub
    ChadsPride and Nevin[QUOTED] like this.
  5. Jun 15, 2019 at 2:50 PM
    #3845
    ChadsPride
    Sponsored by TacomaWorld.com
    F5 all the way, I may be a little biased :D
    Both rigs tho :drool::drool:
    90yota likes this.
  6. Jun 18, 2019 at 6:27 AM
    #3846
    TrailYeti
    TrailYeti Well-Known Member
    Portland, Oregon
    05 TRD OR on SCS F5’s & 315/75r16’s
  7. Jun 19, 2019 at 11:44 AM
    #3847
    CG201
    CG201 New Member
    Christian
    New Jersey
    2021 TRD Pro
    Would I run into any problems running the stock 265/70/R16 size tires on these wheels? I have the OEM 16 inch rims on now and I am looking to upgrade.
  8. Jun 19, 2019 at 12:03 PM
    #3848
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    You should not have any issues with the stock tire size. I do recommend our 4.5" bs size option since you're at stock height.
  9. Jun 20, 2019 at 5:31 PM
    #3849
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    I'm thinking of getting the 16x8s. I have 1.5 inches of lift and will run either 265/75 or 285/75 tires. I plan on doing a CMC and pich weld flatten.
    Are both back spacing doable? 3.5 vs 4.5, that is the question.
  10. Jun 21, 2019 at 8:40 AM
    #3850
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    You can run either backspacing with 265/75/16 with that 1.5" lift. Note that 4.5" will be easier to clear, but 3.5" will look much more aggressive if that's what you're after. 285 is recommended with a 2.5-3" lift.
    The109[QUOTED] and ChadsPride like this.
  11. Jun 23, 2019 at 11:16 PM
    #3851
    cruiserhead
    cruiserhead Well-Known Member
    Curtice
    2018 TRDOR Cement DCSB. 1980 FJ40. 1978 FJ40
  12. Jun 25, 2019 at 6:51 AM
    #3852
    trackdaybro
    trackdaybro Well-Known Member
    Can I clear 16x8 3.5 BS on stock 3rd gen OR suspension and 265s?
  13. Jun 26, 2019 at 8:37 AM
    #3853
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    I did with Hankook Dynapro ATM, but a more aggressive tread might not
    trackdaybro[QUOTED] likes this.
  14. Jun 26, 2019 at 8:40 AM
    #3854
    trackdaybro
    That’s the tire I was going to get. 265/75/16?
    Got any pics?
  15. Jun 26, 2019 at 8:43 AM
    #3855
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
  16. Jun 26, 2019 at 8:44 AM
    #3856
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Just realized you said stock. I had a lift and UCAs :facepalm:
  17. Jun 26, 2019 at 8:45 AM
    #3857
    ChadsPride
    Baby tire :D
  18. Jun 26, 2019 at 8:59 AM
    #3858
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Just a wee lad :rofl:
    ChadsPride[QUOTED] likes this.
  19. Jun 26, 2019 at 9:06 AM
    #3859
    ChadsPride
    Just playin :D I had little tires for a looooooong time
  20. Jun 26, 2019 at 12:28 PM
    #3860
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Helga caught up on leg day :muscleflexing:
