SCS F5 wheels 16x8, 17x8.5, & 17x9
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Jul 21, 2012.
  1. Feb 22, 2016 at 5:46 PM
    #1741
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I wouldn't mind seeing more pictures... this thing is gorgeous, and we're all Toyota fans here.
    Also, is that an Icon build? or your own restoration?
  2. Feb 23, 2016 at 9:28 AM
    #1742
    Mauiboi84
    Mauiboi84 Well-Known Member
    Jon
    2016 Toyota tacoma sr5
    4.50 sorry for the late reply
  3. Feb 23, 2016 at 10:35 AM
    #1743
    Quicksand
    Quicksand Well-Known Member
    Khan
    2016 Quick Sand Tacoma TRD Offroad
    Thanks, truck is badass
  4. Feb 23, 2016 at 6:19 PM
    #1744
    MRJ
    MRJ Well-Known Member
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    Got my F-5s a couple weeks ago. Last week had them wrapped in Cooper ATPs (265/75-16), mounted, aligned, and headed for the mountains.
    Now, I just have to make an appt to have the damage done by DT repaired...
    SCSPerformance[OP] and Dean724 like this.
  5. Feb 23, 2016 at 7:16 PM
    #1745
    ZSpeed07
    ZSpeed07 Well-Known Member
    Milwaukee, WI
    2007 silver access cab Tacoma Trd off-road
    image.jpg Got mine on after work wrapped them in some 285/75/16 cooper discover stt pro... I'll have to get better pic in the day light but there on and they are awesome
  6. Feb 23, 2016 at 7:28 PM
    #1746
    1madmnky
    1madmnky Well-Known Member
    Tony
    Kansas via Fullerton 714
    2010 Tacoma 4X4 DCLB
    Hella Supertones
    Does anyone have this mounted on stock suspension?
  7. Feb 23, 2016 at 7:35 PM
    #1747
    goblue82
    goblue82 Well-Known Member
    The Dude Abides
    Southern California
    Click muh sig
    The center cutout. What fills in that space? It look like a black plate? I can't quite make out whats in the void? Anyone?
  8. Feb 23, 2016 at 7:38 PM
    #1748
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    The hub?
    goblue82[QUOTED] likes this.
  9. Feb 23, 2016 at 8:16 PM
    #1749
    jayuu
    jayuu Well-Known Member
    Central Maine Highlands
    2017 Black TRD Sport DCSB 6 sp manual
    Yes. 265/75/16 with Cooper A/T3s. Picture is post #1435.
  10. Feb 23, 2016 at 8:16 PM
    #1750
    jayuu
    Yes.
    goblue82 likes this.
  11. Feb 23, 2016 at 8:34 PM
    #1751
    MRJ
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    #1755 on stock suspension. Had some rubbing at full lock. Zip-tied fender liners tight to cab mount and did very minor trimming of the fender flares. Already had the mud flaps removed.
  12. Feb 23, 2016 at 8:52 PM
    #1752
    1madmnky
    Tony
    Hella Supertones
    Nice, how do you like the tires? rubbing?
    Thanks, fender rubbing maybe due to back spacing?
  13. Feb 23, 2016 at 10:25 PM
    #1753
    MRJ
    Bucky
    Kent, WA
    '12 pyrite mica 4x4
    Snugtop SuperSport
    I went with 4.5" BS. Definitely pushed the wheels and tires out a bit further than stock. I imagine the contact would be significantly worse with the 3.5" BS on stock suspension.
  14. Feb 23, 2016 at 11:27 PM
    #1754
    Mauiboi84
    Jon
    Thanks
  15. Feb 24, 2016 at 4:59 AM
    #1755
    jayuu
  16. Feb 24, 2016 at 8:29 PM
    #1756
    NotRed
    NotRed Well-Known Member
    Please post up pics after you get them on, very interested in seeing what that color looks like on a SuperWhite.:popcorn:
    edit: just looked up and discovered you have the Silver not the White - still interested in how she looks.:thumbsup:
  17. Feb 24, 2016 at 8:43 PM
    #1757
    scocar
    scocar hypotenoper
    So am I!
    Here's one of the best pics I could find for my truck color and tire size, still stock suspension.
  18. Feb 24, 2016 at 8:47 PM
    #1758
    NotRed
    That looks bitchin'! Since I have a SuperWhite, kind of hard deciding which color to go with . . . problems, problems :notsure:
    Thanks
  19. Feb 24, 2016 at 8:57 PM
    #1759
    scocar
    scocar hypotenoper
    Just go back to the beginning of this thread and start looking for the white trucks. And google tacoma super white SCS F5.
    It took me quite a while to dig up the matches I found, including black trim. Only inaccuracy is the short bed.
  20. Feb 25, 2016 at 12:14 PM
    #1760
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    anyone running the 17x8.5's on a 3rd gen? if so what size tires/lift combo? I'm considering buying the F-5's just not sure about 16 or 17"
