SCS Ray 10’s Dark Bronze-SOLD
Discussion in 'Wheels & Tires Marketplace' started by RustBucketFJ40, Oct 15, 2020.
  1. Oct 15, 2020 at 5:52 PM
    #41
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Hmmmmmmmmmmmmmmmmm wonder if there will be fitment issues on the Pro with these?
  2. Oct 15, 2020 at 5:55 PM
    #42
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Looks like $250 to $280 each
  3. Oct 15, 2020 at 5:55 PM
    #43
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thank you
  4. Oct 15, 2020 at 6:05 PM
    #44
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    We'll figure something out then, if @Unchained 5150 decides to buy them. Appreciate the offer to help out! :thumbsup:
    Thezinz[QUOTED] likes this.
  5. Oct 15, 2020 at 6:06 PM
    #45
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You may or may not depending on if you go off road at all.
  6. Oct 15, 2020 at 6:07 PM
    #46
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I plan on using Skinny 255/75/17's
    4x4Taco09 likes this.
  7. Oct 15, 2020 at 6:10 PM
    #47
    El Duderino
    Jeremy
    HI->PNW
    You should be okay
  8. Oct 15, 2020 at 6:15 PM
    #48
    RustBucketFJ40
    RustBucketFJ40 [OP] Well-Known Member
    New York
    2016 Black TRD OR AC
    That might work, I was thinking of doing the same thing but I couldn’t figure out the fitment for sure. I’m stock height now and have some Fox pro take offs to put on but even with that and maybe a wescott kit that’s not much lift to work with.
  9. Oct 16, 2020 at 8:10 AM
    #49
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    A shared invoice or purchase receipt would squelch all doubt.
  10. Oct 16, 2020 at 8:13 AM
    #50
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    That fits on stock no problem. That IS the size I bought from you, right? I'm not sure what the offset on OEM is compared to these, but that is something to check out.
    If I recall correctly, 3rd gen is able to run 255/80R17 on stock without rubbing.
  11. Oct 16, 2020 at 8:17 AM
    #51
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Buy my Wilco :stirthepot:
  12. Oct 16, 2020 at 8:18 AM
    #52
    neatoneto
    neatoneto Well-Known Member
    CT/Mass
    2020 TRD Off Road DCSB
    @Unchained 5150 I'm always going between CT/NY and North of Boston if you need someone to pick these up. Only thing is I won't be doing it for another week or so.
  13. Oct 16, 2020 at 8:19 AM
    #53
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thank you I am still up in the air currently on this.
  14. Oct 16, 2020 at 8:35 AM
    #54
    CttAznRanger
    Brandon
    Boston, MA
    You said you were holding onto it for a bit, since the state of your truck is up in the air...
  15. Oct 16, 2020 at 8:37 AM
    #55
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Hmmmmmmmmmmmm that was not my quote
  16. Oct 16, 2020 at 8:44 AM
    #56
    CttAznRanger
    Brandon
    Boston, MA
    Not direct quote, no. Paraphrased.
    Otherwise I would have done something like this:
  17. Oct 16, 2020 at 10:07 AM
    #57
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    With a 9" rim, that tire will be on the verge of too narrow for the rim. Looking at Discount Tire's info (Cooper STT Pro) the max "recommended" wheel width is 9" for that tire size.
    Also, being that the wheel is 9" and has a HUGE offset (lots of poke), you may be looking at slight rub with a skinny tire. Hard to say without fitting it up. And I doubt you'll find too many comps on this site, as most don't run skinnies on such a wide wheel.
  18. Oct 16, 2020 at 10:11 AM
    #58
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    It's funny I was thinking the same thing as -38 will poke out a lot really. I guess after seeing you write it, it now makes more sense. @RustBucketFJ40 sorry going to have to pass on these beauties. Good Luck with the sale.
  19. Oct 16, 2020 at 10:13 AM
    #59
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Here's a good website that lets you compare wheel and tire sizes. You can see how much "poke" you'll get compared to your current setup.
  20. Oct 16, 2020 at 10:17 AM
    #60
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wow sticks out quite a bit.
    Bertw192[QUOTED] likes this.
