SCS RAY10 wheels 16x8 & 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, May 22, 2016.
  1. Jan 9, 2018 at 7:50 PM
    #3241
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
  2. Jan 9, 2018 at 8:51 PM
    #3242
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    You bet, the red ones I had on were 4” and it looked fine. The gold ones are 6” and do look better. Just make sure you clean the area with an alcohol prep to clean the area to remove wax/soap and such.
    RobP62[QUOTED] likes this.
  3. Jan 9, 2018 at 9:05 PM
    #3243
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Well, I don't want them larger than the SCS decals I'm putting on.
    Thanks for the install tip!
    :cheers:
    JuanitoBonito[QUOTED] likes this.
  4. Jan 10, 2018 at 4:43 AM
    #3244
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    So my thoughts thus far are some gold trd bedsides like these, with my state logo, and 'scs edition' on it! I already hit up a vinyl vendor to see if he can do the metallized gold film. If not I'll just get these on eBay and slap an scs sticker beside it.
    @SCSPerformance can you guys do the metallized gold? And smaller sizes by chance?
    seoulja99 and RobP62 like this.
  5. Jan 10, 2018 at 7:14 AM
    #3245
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Man that's a freaking excellent idea! I hope you don't mind if I copy some of this from you? I already have some black SCS decals waiting to go on once the weather breaks and I can wash the truck.
    I'm also on the Maryland Taco thread and there is a guy there that makes a bed side decal that incorporates our state outline with the state flag as the image. I was going to do the same thing you are are doing and go with copper text and black outlines to pull in whatever other black decals I add. I saw a Nitto decal on ebay too. And I want to keep adding to the collection.
    Also, there are a couple guys on here that do vinyl. One I have used is @rrentrop. His stuff is quality and very reasonable. He may be able to help. Another guy I read a lot about for custom work is @CBoy808. A lot of guys say his work is top notch. I am betting either of them could help us out.
    Since I am at it, I will have to remove the factory pinstripes since they are silver to match the bed decals. I like pin strips though. If I could find a copper and black that would be cool.
    Then ultimately ( I saw this on a guys QuickSand Taco on here that live in Hawaii) I want to add racing stripes down from the front bumper to the back. I even want perforated vinyl in Orange to match the paint to lay over the glass on the moon roof so that it looks like it has stripes where it would be black glass.
    I know, I know, I have a vivid imagination. But your ideas are definitely inspiring me! :thumbsup: :cheers:
  6. Jan 10, 2018 at 7:50 AM
    #3246
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Only thing that kinda sucks on those trd decals is if they don’t cut the paper straight, it kinda makes it a pain to put on straight. While I was trying to put them on a previous truck, I’d look at the bottom cut line to try and put them on straight. Even with using a piece of tape as a guide. It wasn’t too bad just trying to warn ya...
    RobP62 likes this.
  7. Jan 10, 2018 at 7:56 AM
    #3247
    NightProwler
    Harlan
    Maricopa, Az
    Yeah, I had that same problem with the current ones I have. Ones a little bit crooked. Ha.
  8. Jan 10, 2018 at 8:19 AM
    #3248
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, I think the vinyl tends to stretch a little. Would a solid sheet with them printed on help in that regard? I know that's not the preferred method but.....
    When I tried to put my first SCS decal on the back window, with it being 95 degrees, and me kneeling in the bed trying to reach over the rolled up X2 tonneau, I buggered the shit outta that. I hear some guys use the "wet" method for all their decals including window and bedside. I am not sure how that works though. How do you get them to dry out? Or do you just wait and over time they dry? If it is a better method and the results are guaranteed, I may do it like that from now on.
  9. Jan 10, 2018 at 8:27 AM
    #3249
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Every by vinyl sticker be ever done has gone on easy for me. I have a good hand for that kinda of stuff which I guess helps a little....or I’m just lucky. I believe when you use some water you just want to mist it onand whip as needed. It should then just dry out on its own in the sun......YouTube it
    RobP62 likes this.
  10. Jan 10, 2018 at 8:30 AM
    #3250
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    When it comes to decals on the window, I tend to just apply them as I don't care if they arnt perfect. As far as something like the "TRD" bedside decals or something, I will use the wet method. This is the basic breakdown...
    • Clean surface prior to starting (soap) to remove any dirt and other contaminants
    • Peel the decal adhesive backing piece off
    • Soak the decal in soapy water, you want to do this over water so that the slight oil base can keep it more slick
    • Soak the area completely with more soapy water that you plan to apply the decal to (bedside, door, etc.)
    • Position the decal as needed, by it being wet you can move it freely and apply more soap/liquid as needed to keep it moveable
    • Once position is acquired, take out a squeegee or credit card and slowly start from the middle and press off the water and bubbles behind the decal
    • Take a heat gun or a hair dryer and apply low heat to the decal. This will cause the decal to shrink slightly causing tiny bubbles.
    • With the small bubbles exposed, use your squeegee/credit card and continue to move these bubbles out. The key here is to bake the decal as the sun would, but you can still squeegee the bubbles out as the decal placement is still fresh
    • Repeat the heat/squeegee bubbles a few times. You will likely notice after a while there might be a few that you cant get out. Sometimes the sun can help remove these bubbles as the decal naturally sets.
    • Worst case, you can always take a small needle and pop the remaining bubbles.
    This sounds like a lot, but honestly its a pretty easy process and can be relaxing depending on the quality of the vinyl.
    sjwhitaker and RobP62[QUOTED] like this.
  11. Jan 10, 2018 at 8:46 AM
    #3251
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Great instructions, thank you very much!!!!!!!!!! :cheers:
    Coot83[QUOTED] likes this.
  12. Jan 10, 2018 at 9:27 AM
    #3252
    samwoo2go
    samwoo2go Well-Known Member
    SoCal
    2018 Taco TRDOR DCSB Cement
    This might be covered somewhere in these 163 pages so sorry if it has already been asked.
    What is the rubbing situation with 265/75/16s on these with stock 3rd gen trdor suspension given the negative offset?
    Are we talking mudflap removal, trims?
  13. Jan 10, 2018 at 10:29 AM
    #3253
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Should be none.....and if it does. It will be ever so slight.
    DavesTaco68 and RobP62 like this.
  14. Jan 10, 2018 at 1:18 PM
    #3254
    samwoo2go
    SoCal
    Thanks man!
    RobP62 likes this.
  15. Jan 10, 2018 at 2:15 PM
    #3255
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Sorry, but we don't have any vinyl in that finish. If you send in your vinyl, I can cut it for you.
    Belmonster and RobP62 like this.
  16. Jan 10, 2018 at 2:23 PM
    #3256
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :eek: :thumbsup: :spy:
  17. Jan 10, 2018 at 7:56 PM
    #3257
    Spackler
    Spackler Well-Known Member
    Yes, mudflap removal.
    RobP62 likes this.
  18. Jan 10, 2018 at 8:01 PM
    #3258
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
    I can't wait to get my hands on some Ray 10 17' Dark Bronze :)
    RobP62 likes this.
  19. Jan 10, 2018 at 10:37 PM
    #3259
    samwoo2go
    SoCal
    Anyone have pictures of the gunmetal on cement?
    Can’t decide between gunmetal or black
    RobP62 likes this.
  20. Jan 11, 2018 at 12:25 PM
    #3260
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    Here ya go... All good choices.
    Matte Dark Bronze
    8F0E8B20-8C29-4E24-B8C9-9BEE2A37B8B4_zps_d8ab7b3d127237b22fb481560a72b11221785af4.jpg
    Matte Jet Black
    Matte Gunmetal
    Anycj_23, arnette64, dskakie and 6 others like this.
