SCS RAY10 wheels 16x8 & 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, May 22, 2016.
  1. Sep 17, 2018 at 5:21 AM
    #4181
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    You selling the quicksand matched ones you got on your truck now?:boink:
  2. Sep 17, 2018 at 7:35 AM
    #4182
    Max713
    Max713 Well-Known Member
    Max
    Eugene, OR
    2017 MGM TRD OR
    C4 Fab, love it.
  3. Sep 17, 2018 at 7:37 AM
    #4183
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Newp...keeping those.
    These are for a new build.
    Kpatt9 and Toynado[QUOTED] like this.
  4. Sep 18, 2018 at 5:34 AM
    #4184
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    What metal rings?
  5. Sep 18, 2018 at 9:28 AM
    #4185
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Clips into the center cap from inside of the wheel. Basically holds the plastic tabs in place
  6. Sep 18, 2018 at 10:31 AM
    #4186
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Yours came with the rings or did you swap them over from your stock wheels?
    Mine don't have the rings. No issues with fit of the caps either. :notsure:
  7. Sep 18, 2018 at 1:53 PM
    #4187
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    :eek::cookiemonster::jerkoff:
  8. Sep 19, 2018 at 8:33 AM
    #4188
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    So as an update...all the yellow zinc came off. No longer yellow anymore :mad: kind of annoyed by it.
  9. Sep 19, 2018 at 8:36 AM
    #4189
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Damn seriously. I guess you could clear coat them before install
  10. Sep 19, 2018 at 8:45 AM
    #4190
    Gunshot-6A
    Conner
    Everett, WA
    More importantly, I haven't done anything since I put them on that would really cause them to wear off. Unless they sun in the Utah sun... I washed my truck with a mild powerwasher the other day, but zinc coatings shouldn't wear off that easy.
    Edit: Just found this:
    " It's a finish that was originally developed for automotive fasteners and is very thin compared to any other zinc (galvanized) finish you'll run across. There shouldn't be any clearance issue. It's called an aqueous coating dispersion and is sometimes described as a galvanic wash.
    It's really thin... specifically so that it won't gall threads normally. You'll sometimes see it referred to as yellow zinc chromate.
    Might not work so well on the hard brake lines as it rubs off really easily. Usually a pencil eraser will remove most of it without much effort so anyplace where you'd have the brake line rubbing against anything else like the frame or a fastener would remove the finish in no time. "
    90yota[QUOTED] likes this.
  11. Sep 19, 2018 at 9:02 AM
    #4191
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    These are for the bolts right?
  12. Sep 19, 2018 at 9:08 AM
    #4192
    Gunshot-6A
    Conner
    Everett, WA
    Yep. For my aftermarket yellowed bolts...which are now silver...I should have known better when the install wore all the yellow off the hex corners.
    The wheels themselves have been solid and durable for everything I've put it through!
    May have to give this stuff a go.
    Coot83[QUOTED] and 90yota like this.
  13. Sep 19, 2018 at 10:04 AM
    #4193
    NCtaco914
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    They came with them. Maybe something Vin added to them down the road. Was curious if anybody actually didn't put them back in and had problems. The tabs alone seem more than enough to me
  14. Sep 19, 2018 at 6:43 PM
    #4194
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Bummer to hear that but I bet something like that should work.
  15. Sep 19, 2018 at 9:46 PM
    #4195
    Dee_Rail
    Dee_Rail Well-Known Member
    Dee
    SoCal
    '18 Tacoma Off Road 4x4
    Ordered on Saturday, received today, and installed today.
  16. Sep 19, 2018 at 10:12 PM
    #4196
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    18th birthday is coming and up if anyone has some ray10s in 16s they'd be willing to part with I've got cash in hand and it would be pretty sweet :rofl::rofl:
  17. Sep 20, 2018 at 8:15 AM
    #4197
    Kpatt9
    Kade
    SLC, UT
    2013 DCSB
    Dayummmm 285s?
  18. Sep 20, 2018 at 8:29 AM
    #4198
    Dee_Rail
    Dee
    SoCal
    265/70-17. Not lifted yet.
  19. Sep 21, 2018 at 6:14 AM
    #4199
    24vEngineer
    24vEngineer Well-Known Member
    Slow Cal
    2017 TRD Sport 4x4
    None to report
    Looking good
    SCSPerformance[OP] likes this.
  20. Sep 21, 2018 at 6:57 AM
    #4200
    24vEngineer
    Slow Cal
    2017 TRD Sport 4x4
    None to report
    :thumbsup:
    SCSPerformance[OP] and Kpatt9 like this.
