SCS RAY10 wheels 16x8 & 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, May 22, 2016.
  1. Jan 19, 2019 at 9:10 PM
    #4461
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    No lift? Any rubbing? Looks perfect
  2. Jan 20, 2019 at 9:26 AM
    #4462
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    @SCSPerformance
    Probably not the right forum, but would the 17" Ray10 fit on a 2008 Hummer H3 Alpha? It appears the bolt pattern is the same, but I have no idea about the hub bore, BS, and offset.
  3. Jan 20, 2019 at 10:06 AM
    #4463
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    Anyone know where I can buy a 3 pack of
    Lug nuts for my spare?
  4. Jan 20, 2019 at 5:01 PM
    #4464
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Find out what the hub size is on the H3. If it's similar to the Silverado/Sierra then you culd run our 17" wheels with these hub rings.
    http://www.ezaccessory.com/Hub_Centric_Ring_O_D_106_I_D_78_1_Chevy_PU_p/hr106-7810.htm
    Email contact@scs-performance.com to order individual lugs.
    Bertw192[QUOTED] likes this.
  5. Jan 20, 2019 at 5:29 PM
    #4465
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    From what I've read, it's 101mm. Do they make 101 to 106 adapters... seems too small of a difference.
  6. Jan 20, 2019 at 5:30 PM
    #4466
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    I'm not sure so you would have to research that on your own.
  7. Jan 20, 2019 at 9:42 PM
    #4467
    paleh0rse
    paleh0rse Well-Known Member
    Raleigh, NC
    2019 Cement Tacoma TRD Off-road DCLB
    Here ya go:
    http://www.motorsport-tech.com/wheel_adapters.html
    101 to 106mm is actually quite substantial considering the fact that 106 -> 108 rings are fairly common to accommodate many aftermarket rims.
  8. Jan 22, 2019 at 6:11 AM
    #4468
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    Even on a flat tire, they still look damn good...
    Tachord, dskakie, ksanti808 and 3 others like this.
  9. Jan 25, 2019 at 8:05 PM
    #4469
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Looking at the same set up. What size tires and lift if you not mind?
    Sorry saw the post further down. I have been looking at the same lift. How much did the 887 coils give u up front and rear with the aal? I only have 265/75/16 falkens. Thanks for any info.
    Also...how is the ride?
  10. Jan 25, 2019 at 8:53 PM
    #4470
    JARStacoma
    Alaska
    What size tires on your 2888 coils? Thanks! Truck looks great btw!
    RobP62[QUOTED] likes this.
  11. Jan 25, 2019 at 8:56 PM
    #4471
    Captainehh
    Captainehh New Member
    I am a first gen Tundra guy, so this is my first post as a Tacoma World member. After doing some digging in this thread, several people mentioned Michael's Toyota of Bellevue as a potential work-around to the Ray10 mania that is encapsulate in this thread.
    Low and behold, I called and spoke to Chris in the parts department and he indicated he had several sets of 16's and one set of 17's in stock! Same day that I called, I purchased the 17's. Chris had them shipped the following day and they arrived on my doorstep one day later via UPS! I could not be happier with his attention to detail and good old fashioned customer service. He is a Toyota truck guy through and through and it shows.
    I would highly encourage you to contact Chris at Michael's Toyota of Bellevue and see if he might be able to pull a rabbit out of a hat for you as well!! He actually cares and it very clearly shows!
  12. Jan 26, 2019 at 5:33 AM
    #4472
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thanks but actually I went with a Bilstein 6112/5160 kit, up all the way, and a HS 3 Leaf AAL.
    It's almost 3" in the back and closer to 2.5" in the front.
    265/70R17 Ridge Grapplers.
  13. Jan 26, 2019 at 11:41 AM
    #4473
    r6chan
    r6chan Well-Known Member
    Johnson City, TN
    2017 DCSB OR/wTech-Package
    I researched and researched... I ended up going with the 3 leaf pack from Headstrong Offroad. I pull my mowing trailer from time to time so the progressive leafpack is a great option. The ride of of the overall truck is almost stock, which I love. The front with the OME 887s paired with the bilsteins helps a lot with “nose dive” under breaking. Plus, you don’t have to, but if I went 888s I would have felt obligated to go with upper control arms too. The 887s gave me about 2 1/4 after minimal sag. The combo of having a lighter tire (c load) 285/70 17s (psi about 33) made the ride soft. I drive about 45 miles round trip to work at 45-55 mph with moderate hills and get anywhere from 18-19 mpg.
    I also opted to go with the East Coast Gear Supply (ECGS mod) to help with any front vibrations that could have been a possibility. It replaces the needle bearing where your driver side cv joins your transfer case. It was annoying with my last truck (2012 TRD sport SB) and didn’t want to deal with that again. I’m not sure if I needed it but the truck is silky smooth.. honestly better than stock. I hope this helps. If you have any questions PM me. Your about the 5th person who has asked about this setup in the past couple of months.
    Overall I would do it again!
    RobP62 likes this.
  14. Jan 26, 2019 at 7:16 PM
    #4474
    JARStacoma
    Alaska
    Thanks for the info. I have been in contact with headstrong and thought I was going to go with the 888’s but sounds like the 887’s are good to go. I wanted at least 2” up front but not much more due to uca’s. I did the ECGS bushing on my old tundra and still have the tool. Hope it will work for my Tacoma front diff as well. Thanks for your info.
    r6chan likes this.
  15. Jan 26, 2019 at 10:19 PM
    #4475
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Great review! :thumbsup:
    r6chan[QUOTED] likes this.
  16. Jan 28, 2019 at 9:52 AM
    #4476
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Restock soon :spending:
    Edit: under the crop they note shipping starts 2/4
    Facts Only likes this.
  17. Jan 28, 2019 at 10:02 AM
    #4477
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    why do you have to cut the picture on the "UNTIL" part! lol
  18. Jan 28, 2019 at 10:03 AM
    #4478
    Facts Only
    Facts Only Well-Known Member
    State Of Jefferson
    17 TRDOR DCLB Quicksand
    Feb 4th
  19. Jan 28, 2019 at 10:03 AM
    #4479
    dskakie
    Dan
    Northern CA
    2016 TRD OR DCSB
    Hahahaha I thought about that while cropping! Says shipping starts 2/4
    batong_23[QUOTED] likes this.
  20. Jan 31, 2019 at 1:35 PM
    #4480
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    Should an alignment be made after coming from stock wheels and tires and moving to ray10s with one tire size up? 265/70/17
    RobP62 likes this.
