SCS Ray10s - Machined lip or no?
Discussion in 'Wheels & Tires' started by StainlessSteelRatt, May 25, 2018.
  1. May 25, 2018 at 7:34 PM
    StainlessSteelRatt
    StainlessSteelRatt [OP] Well-Known Member
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Icon, SPC, OME Dakar, Mobtown
    So I'm pretty much sold on getting some 17" Matte Gunmetal Ray10s for my black 3rd gen DCSB, but I'm now having a rough time deciding whether to get them with the machined lip or not. I know it might be a while until they're available again, but I'd like to have this decided before they are.
    For you folks running Ray10s on your black rigs, would you mind posting up some pics to help a fella out?
    Pics of other color Ray10s are welcome here too, if something else looks better on black rigs I'm certainly open to ideas!
    ETA: I found one pic, if someone wouldn't mind doing a quick photoshop with a silver ring instead of black that would be really helpful as well.
  2. May 25, 2018 at 9:21 PM
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    0F620071-EFB1-404A-9998-D57EEE6615F3.jpg 3FC183D5-E843-42BF-BA65-DCEB5D6BAA16.jpg Found these on the google machine. Not black but you get the idea.
  3. May 25, 2018 at 9:30 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    I was pretty much convinced on the regular black rim, but then I realized that the machined lip Ray10s look a LOT like the Tacoma TRD faux beadlocks, which I also like quite a bit. I need a 17" wheel though as I like the better tire selection you can get with those.
  4. May 25, 2018 at 9:34 PM
    KrnTaco08
    LA
    2017 Taco
    Yeah, they kinda do look like the TRD beadlocks at a quick glance.
    Plenty of tires out there for you to choose. 16s won’t be bad either if you want “meatier” tires
  5. May 25, 2018 at 9:41 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    I'm currently running 265/70/16 KO2s on my stock 16" wheels, and they are HEAVY bastards. You can only get E-rated tires in those, and they're over 50# each.
    On a 17" wheel, 265/70/17 KO2s are actually lighter weight for a larger tire. Tires and wheels combined weigh roughly the same when my current 16" setup is compared to the Ray10s with C-rated KO2s.
    That point may be a bit moot, as I'm seriously considering switching to Falken Wildpeaks at some point.
  6. May 25, 2018 at 9:44 PM
    KrnTaco08
    LA
    2017 Taco
    Or my current set up..
    285/70/17 KO2 C rated 50lb tires
  7. May 25, 2018 at 9:45 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    :thumbsup:
    255/75/17 Hankooks, They weight 1 pound more the stock trd sport rims with 265/65/17 Kumho 51s
  8. May 25, 2018 at 9:52 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    Boy do I have questions for you!
    What kind of performance difference are you experiencing with the 285s compared to stock? I'm battling the urge to go that big because I do offroad, and I'm concerned that the gearing won't "feel right". Larger tires mean less torque getting to the ground, but is it enough to really make that much of a difference?
    My 2016 has the AT too, and I feel like I have plenty of power now, but how much would the larger tires really change that?
    I have slightly more lift than the pic I posted (just over 2.5" on Icons), I also have SPC UCAs with my caster set at 3.6 IIRC, so fit shouldn't be an issue at all.
    Tell me your story man, I'm all ears!
  9. May 25, 2018 at 9:53 PM
    StainlessSteelRatt
    Ed
    Colorado
    2016 TRDOR DCSB 4X4
    For comaprison's sake, here's a 2nd gen with the TRD faux beadlocks I found:
