SCS SR8 wheels 16x8 & 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Jan 8, 2015.
  1. Jul 31, 2018 at 3:56 PM
    #2221
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    If I recall correctly, he ran our 17x8.5 size.
  2. Aug 2, 2018 at 3:38 PM
    #2222
    HandsomeTom
    HandsomeTom Well-Known Member
    Tommy
    Kansas City
    2017 Quicksand TRD SPORT
    8===D
    Get a vibration at 80mph with the sr8 + wildpeaks. Anyone else?
  3. Aug 2, 2018 at 4:59 PM
    #2223
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Yes, that's the size.
  4. Aug 7, 2018 at 8:13 PM
    #2224
    XPLODE
    XPLODE Member
    Will the sr8 with 265 70 17 Wildpeak rub with no lift?
  5. Aug 8, 2018 at 12:41 AM
    #2225
    12dcsport
    12dcsport Well-Known Member
    Pa
    17 DC OR
    I'm not positive either way. The offset of these wheels pushes them out a lot farther than stock. I've seen guys do it, but can't say for sure whether they rub or not. Maybe look around on here, someone might have an answer.
  6. Aug 8, 2018 at 4:23 AM
    #2226
    XPLODE
    XPLODE Member
    Thanks, I've been looking but I haven't come across a solid answer
  7. Aug 8, 2018 at 6:31 AM
    #2227
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    265's shouldn't rub just driving around town. They may rub while off-road but then just beat some of the plastic back or whatever
  8. Aug 8, 2018 at 8:42 AM
    #2228
    XPLODE
    XPLODE Member
    Just an update, finally got them installed and if anyone is wondering they do rub. The fix is to take off front mudflap. No rub until you turn more than 45 degrees.
  9. Aug 8, 2018 at 8:45 AM
    #2229
    12dcsport
    Pa
    17 DC OR
    Good to know! Thanks for the update.
  10. Aug 8, 2018 at 11:13 AM
    #2230
    BYJOSHCOOK
    Josh
    Check Out My Builds
    If anybody wants to "spruce" up the look of the SR8's get some vinyl stickers like this. They look awesome. Got mine from @CBoy808
    I'll have to get a better pic with the entire truck in it
    Jayjayb96 and CBoy808 like this.
  11. Aug 8, 2018 at 3:27 PM
    #2231
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    If you're due for an alignment, try to max out the caster setting. Figure out where it's rubbing and do some light liner trimming. There are tons of guys who run this setup with little to no rubbing issues.
  12. Aug 9, 2018 at 7:06 AM
    #2232
    XPLODE
    XPLODE Member
    Thanks, it only rub when turning 45 degree(with flaps on) But i took them off and no more rubbing.
  13. Aug 9, 2018 at 7:12 AM
    #2233
    KTM753
    KTM753 Well-Known Member
    So I pulled the trigger on 17" Ray 10s this week when they were available. In my haste and fear of missing out, I didn't order any lug nuts. Can you run the stock lug nuts? or do you absolutely need ET M12x1.5 lug nuts ?
  14. Aug 9, 2018 at 7:46 AM
    #2234
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Stock lugs will not work. You can order some from Amazon tho
  15. Aug 9, 2018 at 2:23 PM
    #2235
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    The stock lugs will not with aftermarket wheels like ours. You can purchase our ET M12x1.50 off of our website.
    Jayjayb96 likes this.
  16. Aug 17, 2018 at 7:30 PM
    #2236
    Mitch09
    Mitch09 Well-Known Member
    NC
    16' SR5 4x4 DCSB Super White
    Enjoying my SR8s!
  17. Aug 30, 2018 at 6:39 PM
    #2237
    Jbrentb
    Jbrentb Well-Known Member
    Jake
    Wilmington NC
    Black 2016 Trd OR Dcsb
    17x9 mayhem prodigy’s with -6 offset duratrac 265/65-17, fox2.5 coil overs, fox 2.0 rear shocks, OME uca, custom vf tune, Urd spec-u exhaust, high flow catted dump tubes, mbrp muffler, S&B cai, Green lane off road skid and stump bumper, ss3 fogs, pro grill and tail lights, tint, led interior reverse and plate lights, bhlm retrofit HID headlights, Meso turn signals, gashole, and coin holder. hardtop on bed and mat. Blacked out meso everything!!!
    Is there an option to have the screws painted? Or could this happen when I ordered mine?
  18. Aug 31, 2018 at 6:02 AM
    #2238
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Just take an 2 hours to remove them all and paint them before install? Save you some money :notsure:
  19. Aug 31, 2018 at 7:16 AM
    #2239
    Jbrentb
    Jake
    Wilmington NC
    Yea I could. Just like them to match the gun Metal if possible
  20. Sep 6, 2018 at 11:44 PM
    #2240
    trail medik
    trail medik Well-Known Member
    brian
    2014 pyrite mica trd
    none yet, and I stress YET
    HELP!! Cant decide between gunmetal/black or 16/17 for my pyrite dcsb!!!! Oh what to do?
    angeldavid216 likes this.
